[postgis-users] Core dumps
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Feb 7 09:10:43 PST 2011
On 04/02/11 07:20, Peter Hopfgartner wrote:
> We do have code dumps enabled on our developement servers and, from time to time, some PostgreSQL/PostGIS process dumps core.
> Could some useful feedback be provided to the developers from these dumps? Is the back trace enough, like the following:
> Program terminated with signal 11, Segmentation fault.
> #0  0x00000035eee79c00 in strncat () from /lib64/libc.so.6
> (gdb) bt
> #1  0x00002b9176d04282 in lwmessage_truncate ()
>     from /usr/lib64/pgsql/postgis-1.5.so
> #2  0x00002b9176cc95a1 in pg_parser_errhint ()
> #3  0x00002b9176ccf2eb in LWGEOM_in () from /usr/lib64/pgsql/postgis-1.5.so
> #4  0x000000000068b1fd in InputFunctionCall ()
> #5  0x000000000068be6a in OidInputFunctionCall ()
> #6  0x00000000004dfead in coerce_type ()
> #7  0x00000000004e0733 in coerce_to_target_type ()
> #8  0x00000000004e1d29 in transformAssignedExpr ()
> #9  0x00000000004e1ea5 in updateTargetListEntry ()
> #10 0x00000000004b8627 in transformStmt ()
> #11 0x00000000004bab0e in parse_analyze ()
> #12 0x00000000005da07c in pg_analyze_and_rewrite ()
> #13 0x00000000005da7f8 in ?? ()
> #14 0x00000000005db55b in PostgresMain ()
> #15 0x00000000005b1d8d in ?? ()
> #16 0x00000000005b2b3c in PostmasterMain ()
> #17 0x00000000005603be in main ()
> Regards,
> Peter
Right, so these point to a bug in the parser position calculation on the
WKT/WKB input for a particular (and in fact, only for an invalid)
geometry. If you can find the offending geometries and post the WKT/WKB
here, we should be able to fix this reasonably easily.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
