[postgis-users] How to improve this query?
Jorge Arévalo
jorge.arevalo at deimos-space.com
Mon Feb 7 10:07:18 PST 2011
Hello,
update TABLE_A set INT_FIELD = TABLE_B.INT_FIELD from TABLE_C, TABLE_B
where TABLE_B.STR_FIELD = TABLE_C.STR_FIELD and TABLE_A.INT_FIELD2 >=
TABLE_B.min and TABLE_A.INT_FIELD2 <= TABLE_B.max and
st_intersects(TABLE_A.wkb_geometry, TABLE_C.the_geom);
Tables description:
++++++++++++ TABLE A
CREATE TABLE TABLE_A
ogc_fid serial NOT NULL,
wkb_geometry geometry,
INT_FIELD2 integer,
INT_FIELD integer NOT NULL DEFAULT 0,
CONSTRAINT TABLE_A_pk PRIMARY KEY (ogc_fid),
CONSTRAINT enforce_dims_wkb_geometry CHECK (st_ndims(wkb_geometry) = 2),
CONSTRAINT enforce_srid_wkb_geometry CHECK (st_srid(wkb_geometry) = 23030)
WITH (
OIDS=FALSE
CREATE INDEX TABLE_A_geom_idx
ON TABLE_A
USING gist
(wkb_geometry);
CREATE INDEX TABLE_A_INT_FIELD2
ON TABLE_A
USING btree
(INT_FIELD2);
++++++++++++ TABLE B
CREATE TABLE TABLE_B
STR_FIELD character(50) DEFAULT NULL::bpchar,
min integer NOT NULL DEFAULT 0,
max integer NOT NULL DEFAULT 0,
oid integer NOT NULL DEFAULT 0,
CONSTRAINT TABLE_B_pk PRIMARY KEY (oid)
WITH (
OIDS=FALSE
CREATE INDEX TABLE_B_idx
ON TABLE_B
USING btree
(STR_FIELD);
CREATE INDEX TABLE_B_max_idx
ON TABLE_B
USING btree
(max);
CREATE INDEX TABLE_B_min_idx
ON TABLE_B
USING btree
(min);
++++++++++++ TABLE C
CREATE TABLE TABLE_C
the_geom geometry,
WITH (
OIDS=FALSE
CREATE INDEX TABLE_C_index
ON TABLE_C
USING gist
(the_geom);
CREATE INDEX TABLE_C_string_idx
ON TABLE_C
USING btree
(STR_FIELD);
Tables data:
- TABLE_A: 896888 entries. The geometries are single polygons
(squares, actually), coordinates are floating point numbers
- TABLE_B: 88 entries.
- TABLE C: 69352 entries. Geometries are single polygons too, but much
bigger than the polygons from TABLE_A.
As you can see in the query, I'm interested in the polygons of TABLE_A
that intersects the big polygons in TABLE_C.
Query plan (explain <query> output):
"Hash Join (cost=3.98..986808.75 rows=209049 width=497)"
" Hash Cond: (TABLE_C.STR_FIELD = TABLE_B.STR_FIELD)"
" Join Filter: ((TABLE_A.INT_FIELD2 >= TABLE_B.min) AND
(TABLE_A.INT_FIELD2 <= TABLE_B.max))"
" -> Nested Loop (cost=0.00..955055.47 rows=470360 width=543)"
" Join Filter: _st_intersects(TABLE_A.wkb_geometry, TABLE_C.the_geom)"
" -> Index Scan using TABLE_C_string_idx on TABLE_C
(cost=0.00..8044.56 rows=69352 width=1517)"
" -> Index Scan using TABLE_A_geom_idx on TABLE_A
(cost=0.00..12.61 rows=4 width=493)"
" Index Cond: (TABLE_A.wkb_geometry && TABLE_C.the_geom)"
" -> Hash (cost=2.88..2.88 rows=88 width=63)"
" -> Seq Scan on TABLE_B (cost=0.00..2.88 rows=88 width=63)"
With that information, how could I make the update faster? It takes
more than 24hours to finish.
Many thanks in advance
Best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://www.twitter.com/jorgeas80
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
