[postgis-users] postgis visual client
John Callahan john.callahan at udel.edu
Tue Feb 8 09:25:12 PST 2011
I'm sure this has been asked many times but haven't found a definitive or
consensus answer...
Is there a postgis client that supports spatial, ad hoc queries and returns
those results to a map?  This would include simple (and more complex) SELECT
statements but also other queries with spatial results, such as finding
nearest neighbors, intersect, union, etc...
The best idea I found was to create a view from the ad hoc query and then
use a desktop GIS to display that view.  You'd need to update the view (and
refresh the GIS screen) to run a new query.   I know QGIS (and other FOSS
GIS packages) allows you to create a definition query (a where clause to
subset the layer) and does support database views.  I haven't seen a place
where QGIS supports ad hoc queries.  Searching the web, I did find
references to some work done using OpenMap libraries back in 2004, and the
mezoGIS package from around 2005/2006.
Does anyone know of a GUI tool to use, hopefully one that works for Postgres
9 and PostGIS 2?  Thanks.
- John
PS - Thanks for the recommendations on the PostGIS in Action book.  I just
purchased it and looking forward to learning what I can.
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110208/44eb7472/attachment.html>
