[postgis-users] efficiently testing for points near polygons
David Kaplan
david.kaplan at ird.fr
Thu Feb 10 09:10:42 PST 2011
Here is a new version of my previous clipping functions that fixes a
mistake regarding polygons with holes and changes the order of things so
that there is no longer the problem of sometimes not clipping when it
should (at the price of being somewhat slower for grids much larger than
the polygon).
Cheers,
David
On Thu, 2011-02-10 at 16:20 +0100, David Kaplan wrote:
> Hi,
> Thanks for this response. Regarding the indices, I was mainly asking if
> an index on the point column has any value as the bounding box of a
> point is trivial.
> Based on the suggestions you mentioned, I decided to dump my
> multipolygons to polygons and splice up my continent polygons to make
> the querying faster. This dramatically speeds things up (a factor of
> 100).
> Along the way, I made some fairly generic functions for generating grids
> and splicing up polygons along a linestring grid. I imagine that
> someone has already created these, but as far as I know they aren't in
> the stable version of postgis, so I am attaching them for those
> interested. If they prove of value, perhaps they would be worth adding
> to postgis...?
> The main functions are ST_MakeLinestringGrid and ST_CutPolyByLinestring.
> As an example of their use:
> SELECT ogc_fid, ST_CutPolyByLinestring(wkb_geometry,
> ST_SetSRID(ST_MakeLinestringGrid(5),ST_SRID(wkb_geometry)))
> FROM gpoly;
> This will cut all polygons in wkb_geometry along a 5 deg. by 5 deg. grid
> and return the individual polygons. wkb_geometry must be POLYGON and
> not MULTIPOLYGON.
> ST_CutPolyByLinestring works perfectly for simple cases, but for very
> irregular polygons, sometimes things don't get cut as they are supposed
> to. This is because when the grid is intersected with the polygon,
> there appears to be enough rounding error that ST_Polygonize sometimes
> doesn't think the remaining pieces of the grid always touches the edges
> of the original polygons. Perhaps ST_SnapToGrid will help? If anyone
> has ideas to fix this problem, please let me know. For my uses, this
> doesn't have much impact as enough cutting goes on to improve bounding
> boxes on most polygons.
> Cheers,
> David
> On Tue, 2011-02-08 at 15:42 +0100, Nicklas Avén wrote:
> > Hallo
> > The overall performance will be better if you use ST_Dwithin instead of
> > buffer and intersects. But if the buffer is done once and will never
> > happen again maybe there is not much gain from that.
> > The bounding boxes is very important here. The index works by first
> > finding overlapping bounding boxes and then from that do a recheck and
> > calculate if the real geometries actually is intersecting (or within the
> > given distance)
> > Because of that it is better the smaller your geometries are which means
> > you should absolutely not union them together. If you have whole
> > continents in one polygon the index will be totally worthless because
> > most points will fall inside the bounding box anyway. So it might be
> > difficult to get good performance out of a dataset with very big
> > geoemtries, but there are techniques to slice them up and index the
> > smaller parts instead. To get a good description about that "PostGIS in
> > Action" is a good source of knowledge (http://manning.com/obe)
> > /Nicklas
> > On Tue, 2011-02-08 at 14:47 +0100, David Kaplan wrote:
> > > Hi,
> > > I have a large set of oceanic point data that I need to test to identify
> > > all points that are within a certain distance of land. I initially
> > > tried doing the most obvious thing I could think of - buffer land
> > > polygons and test points for intersection, but this is taking too long
> > > for the full dataset and is giving me strange "terminating connection
> > > due to administrator command" errors. I imagine that there is something
> > > in my initial strategy that doesn't scale well, but it is hard for me to
> > > identify what is the best strategy. Hopefully someone already knows the
> > > answer and can give me a hand.
> > > Here are some concrete questions that I hope someone can help me with:
> > > 1) How exactly are indexes used for point data? AS BBox doesn't make
> > > much sense (at least to me), I imagine that this somehow groups
> > > identical points so that operations only have to be done once for each
> > > distinct point. Is this the case?
> > > 2) I initially made a function to test for proximity to land:
> > > CREATE OR REPLACE FUNCTION near_land(geo geometry)
> > > RETURNS boolean AS
> > > $BODY$
> > > SELECT bool_or( ST_Intersects($1,wkb_geometry_5km_buf) )
> > > FROM gshhs_h_l1;
> > > $BODY$
> > > LANGUAGE 'sql' STABLE;
> > > This works fast for small amounts of data, but I have a feeling that
> > > this prohibits using indexes for the full dataset and therefore could be
> > > causing much of my slowness. Is this so?
> > > 3) Would it be best to ST_Union all my polygons before making the
> > > comparison, knowing that the polygons don't overlap? Or is this no
> > > different than just doing the intersect and then using bool_or?
> > > 4) Would using long transaction support help me avoid the "administrator
> > > command" errors? I don't really know what long transaction support
> > > does, but my transaction certainly is long...
> > > Thanks for the help.
> > > Cheers,
> > > David
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
David M. Kaplan
Charge de Recherche 1
Institut de Recherche pour le Developpement
Centre de Recherche Halieutique Mediterraneenne et Tropicale
av. Jean Monnet
B.P. 171
34203 Sete cedex
France
Phone: +33 (0)4 99 57 32 27
Fax: +33 (0)4 99 57 32 95
http://www.ur097.ird.fr/team/dkaplan/index.html
http://www.amped.ird.fr/
Type: text/x-sql
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110210/93f36382/attachment.bin>
