[postgis-users] Error in raster import with WKTRaster
Mathieu Basille
basille at ase-research.org
Fri Feb 11 05:52:42 PST 2011
Hi Jorge,
Thx for the answer! Seems I did a nice mess with the install, because I
did install it with the --with-raster configure option! I'll try to fix
it as soon as possible (I'm not on the same computer right now, so that
it'll have to wait a bit). Do you think it would be safer to reinstall
everything, in order to have a fresh install?
I will also check the NAs of the map (that's weird, too: there are no
NAs on this map, but I guess they are internally set anyway). What
puzzled me is that it worked for other maps with the same procedure...
I'll let you know, thx again!
Mathieu.
Le 11/02/2011 05:15, Jorge Arévalo a écrit :
> Hi Mathieu,
> On Fri, Feb 11, 2011 at 1:20 AM, Mathieu Basille
> <basille at ase-research.org> wrote:
>> Dear users,
>> I have a problem while trying to import a raster into PostGIS
>> (2.0.0SVN), using WKTRaster (0.1.6d), on a Debian system.
>> This is a raster exported from GRASS as GeoTiff, using a float32 format
>> (this is a density map). I then used:
>> mathieu at Caribou$ /usr/lib/postgresql/8.4/bin/gdal2raster.py -r
>> RoadDensity_2002_2006_CV_UTM19_25m.tif -t
>> roaddensity_2002_2006_cv_utm19_25m -s 26919 -k 50x50 -I>
>> RoadDensity_2002_2006_CV_UTM19_25m.sql
>> and finally to import into PostGIS, as the postgres user:
>> postgres at Caribou:/home/mathieu$ psql -f
>> RoadDensity_2002_2006_CV_UTM19_25m.sql geodb
>> BEGIN
>> psql:RoadDensity_2002_2006_CV_UTM19_25m.sql:2: NOTICE: CREATE TABLE
>> créera des séquences implicites «
>> roaddensity_2002_2006_cv_utm19_25m_rid_seq » pour la colonne serial «
>> roaddensity_2002_2006_cv_utm19_25m.rid »
>> psql:RoadDensity_2002_2006_CV_UTM19_25m.sql:2: NOTICE: CREATE TABLE /
>> PRIMARY KEY créera un index implicite «
>> roaddensity_2002_2006_cv_utm19_25m_pkey » pour la table «
>> roaddensity_2002_2006_cv_utm19_25m »
>> CREATE TABLE
>> psql:RoadDensity_2002_2006_CV_UTM19_25m.sql:3: ERREUR: la colonne « nan
>> » n'existe pas
>> LIGNE 1 : ...','rast',26919, ARRAY['32BF'], false, true, ARRAY[nan], 25.0...
>> psql:RoadDensity_2002_2006_CV_UTM19_25m.sql:4: ERREUR: la transaction
>> est annulée, les commandes sont ignorées jusqu'à la fin du bloc
>> de la transaction
>> psql:RoadDensity_2002_2006_CV_UTM19_25m.sql:5: ERREUR: la transaction
>> de la transaction
>> psql:RoadDensity_2002_2006_CV_UTM19_25m.sql:6: ERREUR: la transaction
>> de la transaction
>> And it continues for every line (or until I stop it). In the end, the
>> table is not imported at all. (sorry if parts of the ouputs are in
>> French: the first error message is simply: "the column "nan" does not
>> exist", and the next ones says "the transaction is cancelled, all
>> commands will be ignored until the end of the bloc of the transaction")
>> Note that this is the exact same approach that I am generally using,
>> without any problem for other maps (including density maps as float32).
>> I am new to PostGIS and the SQL world, so it might be an easy one...
>> Yet, I still have no idea what's wrong here. I welcome any pointer!
>> All the best,
>> Mathieu.
>> ~$ whoami
>> Mathieu Basille, Post-Doc
>> ~$ locate
>> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
>> + Centre d'Étude de la Forêt
>> Département de Biologie
>> Université Laval, Québec
>> ~$ info
>> http://ase-research.org/basille
>> ~$ fortune
>> ``If you can't win by reason, go for volume.''
>> Calvin, by Bill Watterson.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> The error is caused because the NODATA value for the band is not a
> number. Probably, the GetNodata function for this band returns NULL,
> and this situation is not managed in the loader code. Let me check it
> and open a new ticket if needed.
> Anyway, you're using PostGIS 2.0SVN. With this version you don't need
> WKTRaster 0.1.6d separately. Actually, WKTRaster 0.1.6d is not longer
> mantained, and it probably will cause errors (like this) if you use it
> with PostGIS from trunk.
> The raster extension (now "PostGIS Raster" instead of WKTRaster) is
> included as official part of PostGIS. You can enable it by compiling
> PostGIS in this way:
> ./configure --with-raster
> make
> make install
> createdb<your_database>
> createlang plpgsql<your_database>
> psql -f postgis/postgis.sql -d<your_database>
> psql -f spatial_ref_sys.sql -d<your_database>
> psql -f raster/rt_pg/rtpostgis.sql -d<your_database>
> Now, you can load raster data in<your_database> with the new version
> of the loader script: raster2pgsql.py (in
> <postgis_src_root>/raster/scripts/python). Same syntax than the older
> gdal2wktraster.py script.
> Further information at
> http://gis4free.wordpress.com/2010/10/01/wkt-raster-is-now-postgis-raster/
> Best regards,
~$ whoami
~$ locate
~$ info
~$ fortune
