[postgis-users] ST_DWithin Performance
Carl S. Yestrau Jr.
carl at featureblend.com
Sat Feb 12 21:02:53 PST 2011
Hi Paul,
~700K records get returned if I drop the LIMIT. Thanks for the feedback.
On Sat, Feb 12, 2011 at 2:42 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> How many records get returned when you drop the LIMIT? If you have to
> sort 700K things into order, I can see that taking a second or two.
> P.
> On Sat, Feb 12, 2011 at 2:16 PM, Carl S. Yestrau Jr.
> <carl at featureblend.com> wrote:
>> When I removed the "ORDER BY created_on DESC" the results were almost
>> instantaneous (which makes sense as it just returns the first 'x'
>> result defined by LIMIT). I don't have access to the machine at the
>> moment, but can get the plan for that if it's helpful.
>> I'm pretty confused why things are so slow. The only thing I can think
>> of is possibly the data density, I have over 700K records within a 20
>> minute window.
>> On Sat, Feb 12, 2011 at 12:27 AM, strk <strk at keybit.net> wrote:
>>> On Fri, Feb 11, 2011 at 02:27:16PM -0800, Carl S. Yestrau Jr. wrote:
>>>> Table schema:
>>>> Table "public.geobits"
>>>> Column | Type |
>>>> Modifiers
>>>> id | integer | not null default
>>>> nextval('geobits_id_seq'::regclass)
>>>> uuid | uuid | not null
>>>> raw | text | not null
>>>> search_config | regconfig |
>>>> ip | inet | not null
>>>> user_agent | text |
>>>> created_on | timestamp without time zone | default now()
>>>> location | geography(Point,4326) | not null
>>>> parent_id | integer |
>>>> language_code | text |
>>>> group_id | integer |
>>>> Indexes:
>>>> "geobits_pkey" PRIMARY KEY, btree (id)
>>>> "geobits_uuid_key" UNIQUE, btree (uuid)
>>>> "geobits_created_on_index" btree (created_on)
>>>> "geobits_group_id_index" btree (group_id)
>>>> "geobits_location_index" gist (location)
>>>> "geobits_parent_id_index" btree (parent_id)
>>>> "geobits_search_config_index" gin (to_tsvector(search_config, raw))
>>>> Foreign-key constraints:
>>>> "geobits_group_id_fkey" FOREIGN KEY (group_id) REFERENCES groups(id)
>>>> "geobits_language_code_fkey" FOREIGN KEY (language_code)
>>>> REFERENCES languages(code) ON DELETE SET NULL
>>>> "geobits_parent_id_fkey" FOREIGN KEY (parent_id) REFERENCES
>>>> geobits(id) ON DELETE SET NULL
>>>> Referenced by:
>>>> TABLE "geobits" CONSTRAINT "geobits_parent_id_fkey" FOREIGN KEY
>>>> (parent_id) REFERENCES geobits(id) ON DELETE SET NULL
>>>> Slow Query:
>>>> EXPLAIN ANALYZE SELECT id, created_on FROM geobits WHERE
>>>> ST_DWithin(location, ST_GeographyFromText('SRID=4326;POINT(180 90)'),
>>>> 1000) ORDER BY created_on DESC LIMIT 10;
>>>> QUERY PLAN
>>>> Limit (cost=205352.10..205352.10 rows=1 width=12) (actual
>>>> time=4078.057..4078.090 rows=10 loops=1)
>>>> -> Sort (cost=205352.10..205352.10 rows=1 width=12) (actual
>>>> time=4078.053..4078.064 rows=10 loops=1)
>>>> Sort Key: created_on
>>>> Sort Method: top-N heapsort Memory: 17kB
>>>> -> Seq Scan on geobits (cost=0.00..205352.08 rows=1
>>>> width=12) (actual time=0.015..3100.471 rows=708661 loops=1)
>>>> Filter: ((location &&
>>>> '0101000020E610000000000000008066400000000000805640'::geography) AND
>>>> ('0101000020E610000000000000008066400000000000805640'::geography &&
>>>> _st_expand(location, 1000::double precision)) AND
>>>> _st_dwithin(location, '0101000020E6100000000
>>>> 00000008066400000000000805640'::geography, 1000::double precision, true))
>>>> Total runtime: 4078.127 ms
>>>> (7 rows)
>>> The "geobits_location_index" gist (location) index is not being used,
>>> for some reason. Why do you say ORDER BY is the culprit ? Does
>>> the plan come out differently w/out that ?
>>> --strk;
>>> () Free GIS & Flash consultant/developer
>>> /\ http://strk.keybit.net/services.html
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
