[postgis-users] Error in raster import with WKTRaster
    Jorge Arévalo
    jorge.arevalo at deimos-space.com
    Mon Feb 14 01:43:47 PST 2011
2011/2/12 Mathieu Basille <basille at ase-research.org>:
> Dear Jorge,
> Thx for this. Shall I do anything about it? I uploaded the problematic
> raster for Pierre here:
> http://ase-research.org/tmp/postgis/
> Pierre, are you working on this?
> Sorry if I'm a bit confused, I'm not quite sure what's the best to do as I'm
> not familiar with the PostGIS Raster organisation...
> And I don't want to add more work for the people involved in PostGIS Raster
> than required.
> All the best,
> Mathieu.
Hi Mathieu,
I think is enough. The loader should know how to deal with that.
About PostGIS Raster, basically there's a roadmap
(http://trac.osgeo.org/postgis/wiki/WKTRaster/PlanningAndFunding) and
a list of known bugs and new required features
(http://trac.osgeo.org/postgis/report/17).
So, if you found a new problem (like your case) or a lack of
something, you can use the list to ask for it, and a new ticket will
be created when needed (like your case, again).
Apart from this, the only thing you need is patience :-)
Thanks again for reporting this, and best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
> Le 12/02/2011 09:17, Jorge Arévalo a écrit :
>> 2011/2/11 Mathieu Basille<basille at ase-research.org>:
>>> Dear Jorge,
>>> The NoData value seems indeed at the origin of the problem:
>>> $ gdalinfo RoadDensity_2002_2006_CV_UTM19_25m.tif | grep NoData
>>> NoData Value=nan
>>> In my other density maps, there was no 'NoData value' (the same command
>>> returns nothing). It thus seems that I have some NAs in my map, which
>>> are not handled correctly.
>>> After his request, I sent the map to Pierre Racine who is going to have
>>> a look at it to find the problem.
>>> Thanks a lot,
>>> Mathieu.
>> Hello,
>> I've created a new ticket for this:
>> http://trac.osgeo.org/postgis/ticket/828
>> Best regards,
> ~$ whoami
> Mathieu Basille, Post-Doc
> ~$ locate
> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
> + Centre d'Étude de la Forêt
> Département de Biologie
> Université Laval, Québec
> ~$ info
> http://ase-research.org/basille
> ~$ fortune
> ``If you can't win by reason, go for volume.''
> Calvin, by Bill Watterson.
