[postgis-users] postgis/mapserver
Nicklas Avén
nicklas.aven at jordogskog.no
Mon Feb 14 10:38:39 PST 2011
An more lightweight and probably faster alternative to GeoServer for
WFS-T is tinyows, found at http://www.tinyows.org
/Nicklas
On Mon, 2011-02-14 at 10:26 -0800, pcreso at pcreso.com wrote:
> The appropriate protocol for a data editing capability is WFS-T which
> is not supported by Mapserver. See
> http://weblogs.java.net/blog/2006/01/09/geoserver-wfs-t
> This enables a db transaction to be maintained for the data editing
> process. This is supported by Geoserver, as described in the link
> above. If you are working with Python in a mapserver/postgis
> environment, you can also do this via python directly.
> Cheers,
> Brent Wood
> > Hello
> > I know that we can connect to postgis database from
> mapserver
> > but can we edit or create tables in postgis using
> mapserver!!!
> > is it possible using sql !!!
> > How can we use pywps for spetial traitement such as
> interpolation in this
> > case!!!
> > thanks a lot for your help
> postgis-users mailing list
