[postgis-users] syntax to pick correct, single result from subquery
karsten vennemann
karsten at terragis.net
Wed Feb 16 01:03:13 PST 2011
Ok I am fighting with this SQL task:
I have a polygon layer "quad" and a point location layer "r_model_cells" in PostGIS. In each of the quads there will be one or more of the pints located.
Now I would like to update a field 'quad_id' in he point layer "r_model_cells" with the id of the quad it is located within. Thus I can get all point ids and respective quad ids they are via this query
select quad.quad_id qid, r_model_cells.record_id rid from ca.quad, ca.r_model_cells
where st_within(r_model_cells.merc_geom,quad.merc_geom);
but how can I use this query to update a column my field quad_id in he point layer. I can'get my snytax together :(
I also have this so far
update ca.r_model_cells set quad_id =
(select quad.quad_id from ca.quad, ca.r_model_cells
where
quad.merc_geom && r_model_cells.merc_geom
and intersects(quad.merc_geom,r_model_cells.merc_geom));
But this query will rerieve more then one records in the subquery ...
Thus I get ERROR:
more than one row returned by a subquery used as an expression I want to limit to one which correcponds to the point in question....
Any ideas what my syntax should be ?
Note: Right now I can do it via two queries below
select quad.quad_id qid, r_model_cells.record_id AS rid
into temp_rid
where st_within(r_model_cells.merc_geom,quad.merc_geom) ;
and then
qid from (select temp_rid.qid qid, temp_rid.rid, r_model_cells.record_id from temp_rid, ca.r_model_cells
where temp_rid.rid =r_model_cells.record_id ) as bubu ;
Cheers
Karsten
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110216/fdf1688a/attachment.html>
