[postgis-users] shp2pgsql
ibrahim saricicek ibrahimsaricicek at gmail.com
Wed Feb 16 06:57:04 PST 2011
Hi;
I prefer try also on ogr2ogr.
You can find it in FwTools, you have to download it from;
http://fwtools.maptools.org/
And can get help from;
http://www.bostongis.com/PrinterFriendly.aspx?content_name=ogr_cheatsheet
On Wed, Feb 16, 2011 at 4:29 PM, Mehmet Erkek <merkek at reidin.com> wrote:
> Hi everyone,
> Wishing you all a fruitful day,  here is a problem we have and we are
> hoping to get some help:
> We are converting a shapefile to postgis with shp2pgsql. Conversion is done
> without problem. However, it produces boundaries with fewer points than we
> expect, thus it produces sharper boundaries and sometimes overlaps with
> neighboring boundaries.
> Is there way to make  it produce outputs with more points and much closer
> to original shapefile?
> I appreciate any comment on this.
> Thanks.
> *Mehmet Erkek*
> www.REIDIN.com <http://www.reidin.com/>
> This message is for the designated recipient only and may contain
> privileged, proprietary, or otherwise private information. If you have
> received it in error, please notify the sender immediately and delete the
> original. Any other use of the email by you is prohibited. Please Consider
> the Environment Before Printing This Email
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110216/3f038373/attachment.html>
