[postgis-users] Retrieve the portion of line external to polygon
strk
strk at keybit.net
Wed Feb 16 10:08:03 PST 2011
On Wed, Feb 16, 2011 at 06:47:53PM +0100, Andrea Peri wrote:
> Look this simple example
> the difference between the line and the same line intersected with the
> polygon is equal to the line :)
> select 1, ST_Difference(ST_GeomFromText('LINESTRING(10.9 2, 11
> 8)'),ST_Intersection(ST_GeomFromText('LINESTRING(10.9 2, 11 8)'),
> ST_GeomFromText('POLYGON((12 2, 10 10, 20 21, 21 5, 12 2))')))
> the trick is that in the intersection point between polygon and line, the
> vertex added move the line so the difference fail to
> remove the internal portion.
Ok, I think I know what's going on.
The original linestring isn't noded with the polygon boundary.
When computing the intersection, a node is added.
Such a node will NOT fall on the original line anymore, due
to precision constraints.
See this:
CREATE TABLE a AS SELECT
'LINESTRING(10.9 2, 11 8)'::geometry as g;
CREATE TABLE b AS SELECT
'POLYGON((12 2, 10 10, 20 21, 21 5, 12 2))'::geometry as g;
CREATE TABLE c AS SELECT
ST_Intersection(a.g, b.g) FROM a, b;
SELECT ST_Covers(a.g, ST_StartPoint(c.g)) FROM a,c; -- false
SELECT ST_Covers(a.g, ST_EndPoint(c.g)) FROM a,c; -- true
What you could do is _snap_ the original line to the intersection,
or to node the input before proceeding.
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
