[postgis-users] ST_Value from Polygon
Andreas Forø Tollefsen
andreasft at gmail.com
Thu Feb 24 06:53:14 PST 2011
Great.
Thank you so much. I should have noticed that these were unioned numbers.
Btw. are there any way of getting the count of pixels within a polygon
without actually aggregating them or union them?
Andreas
2011/2/24 Paragon Corporation <lr at pcorp.us>
> Andreas,
> Sorry should have recognized what you're doing. The intersection returns a
> polygon which is a union of the clipped raster pixel squares. So you need
> to use Sum of area instead and then divide by the area of a pixel to get the
> equivalent of your count.
> So
> SELECT gid, SUM(ST_Area((foo.geomval).geom))/ [put your pixel area size
> here] as ct
> FROM (SELECT globshort.rid, priogrid_land.cell, priogrid_land.gid,
> ST_Intersection(globshort.rast, priogrid_land.cell) AS geomval FROM
> globshort, priogrid_land) AS foo
> WHERE gid >= 139358 AND gid <= 139365
> GROUP BY gid
> ORDER BY gid
> *From:* Andreas Forø Tollefsen [mailto:andreasft at gmail.com]
> *Sent:* Thursday, February 24, 2011 8:33 AM
> *To:* PostGIS Users Discussion
> *Cc:* Paragon Corporation
> *Subject:* Re: [postgis-users] ST_Value from Polygon
> I am a bit unsure whether my results are actually correct. According to a
> total count using the below query, I get very different results between the
> cells.
> Since the raster does actually cover the whole vector cell, i would assume
> that the count should be similar in all cells. Meaning, the pixel count
> should be the same.
> What i get is different, and it seems that the query is not providing me
> with the number of pixels within the grid cell.
> Any idea why this is so different?
> SELECT gid, count((foo.geomval).val) as ct
> GROUP BY gid
> ORDER BY gid
> Result:
> 139358;632
> 139359;1030
> 139360;912
> 139361;731
> 139362;760
> 139363;1230
> 139364;1314
> 139365;1014
> The attached image shows the raster pixels within one cell.
> 2011/2/24 Andreas Forø Tollefsen <andreasft at gmail.com>
>> Thanks!
>> That solved it.
>> This will probably take a lot of time. I have 259200 polygons measuring
>> 0.5 x 0.5 decimal degrees while the raster dataset is of global cover and
>> has a pixelsize of 0.00277777777777778x0.00277777777777778.
>> Andreas
>> 2011/2/23 Paragon Corporation <lr at pcorp.us>
>>> Andrea,
>>> Try
>>> SELECT DISTINCT ON(gid) gid, (foo.geomval).val, COUNT((foo.geomval).val)
>>> AS ct
>>> WHERE gid > 151000 AND gid < 151010
>>> GROUP BY gid, (foo.geomval).val
>>> ORDER BY gid, ct DESC
>>> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
>>> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Andreas
>>> Forø Tollefsen
>>> *Sent:* Wednesday, February 23, 2011 4:05 AM
>>> Hi. Thanks Regina and Leo,
>>> I have been testing the raster and geom intersection a bit. I guess what
>>> i need is to use the ST_Intersection together with a max(count) function.
>>> So my result will be the rastervalue with the highest count within each
>>> of the grid cells.
>>> However, as far as i know, there is now Max(COUNT) function in
>>> postgresql.
>>> Any idea how i can modify the below query to only return the rastervalue
>>> within the grid cell occuring most frequently?
>>> Consequently i want only one row for each gid, and the maximum occuring
>>> rastervalue.
>>> SELECT gid, (foo.geomval).val, COUNT((foo.geomval).val) AS ct
>>> GROUP BY gid, (foo.geomval).val;
>>> gid; val; ct
>>> 151001;14;381
>>> 151001;150;9
>>> 151001;50;7
>>> 151001;140;91
>>> 151001;40;1
>>> 151001;70;2
>>> 151001;130;4
>>> 151001;200;48
>>> 151001;100;3
>>> 151001;;0
>>> 151001;190;1
>>> 151001;20;203
>>> 151001;11;111
>>> 151001;210;16
>>> 151001;30;105
>>>> Have you looked at ST_Intersection. I'm not sure how large your grids
>>>> are so might still be a bit too slow.
>>>> http://www.postgis.org/documentation/manual-svn/RT_ST_Intersection.html
>>>> Below is a link to our slides from our North Carolina GIS meeting that
>>>> may answer some of your questions (shows some Raster examples) as well as
>>>> the 3D ones people have asked.
>>>> http://www.postgis.us/presentations
>>>> Hope that helps,
>>>> Regina and Leo
>>>> Forø Tollefsen
>>>> *Sent:* Tuesday, February 22, 2011 4:28 AM
>>>> *Subject:* [postgis-users] ST_Value from Polygon
>>>> Hi all,
>>>> I am working with a large raster dataset that i want to aggregate into
>>>> vector grids.
>>>> The raster dataset is a landcover dataset, and i want to find which of
>>>> the raster values are the most dominant within each of the vector grid
>>>> cells.
>>>> I have been looking at the ST_Value function, but this is not usable
>>>> together with the cell polygon.
>>>> I have written a script that gives me the raster value of the centroid
>>>> of each cell, but i want to find which raster class is the largest.
>>>> Hence i need to calculate the area of each raster class within each cell
>>>> and select the largest class.
>>>> Any idea? So far i have only come this far:
>>>> DROP TABLE IF EXISTS globshortpoly;
>>>> SELECT priogrid_land.cell, ST_Value(rast, ST_Centroid(cell))
>>>> INTO globshortpoly
>>>> FROM priogrid_land, globshort
>>>> WHERE rast && priogrid_land.cell
>>>> LIMIT 1000
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110224/d57b1cf9/attachment.html>
