[postgis-users] Find n Nearest Neighbors for given Point using PostGIS?
Scholle mstumpp at gmail.com
Thu Feb 24 20:04:32 PST 2011
I am trying to solve the problem of finding the n nearest neighbors using
PostGIS:
Starting Point:
 - Table geoname with geonames (from geonames.org) containing
latitude/longitude (WSG-84)
 - Added a GeometryColumn geom with srid=4326 and datatype=POINT
 - Filled geom with values: UPDATE geoname SET geom =
ST_SetSRID(ST_Point(longitude,latitude) 4326);
 - Created GIST index for geom (CREATE INDEX geom_index ON geoname USING
GIST (geom);) / Clustered geom_index: CLUSTER geom_index ON geoname;)
 - Created PRIMARY KEY UNIQUE BTREE index for geonameid
Problem:
Find n (e.g. 5) nearest neighbors for a given Point in table geoname
represented by id (geoname.geonameid.
Possible solution:
Inspired by
http://www.bostongis.com/PrinterFriendly.aspx?content_name=postgis_nearest_neighbor,
I tried the following query:
"SELECT start.asciiname, ende.asciiname, distance_sphere(start.geom,
ende.geom) as distance " +
"FROM geoname As start, geoname As ende WHERE start.geonameid = 2950159 AND
start.geonameid <> ende.geonameid " +
"AND ST_DWithin(start.geom, ende.geom, 300) order by distance limit 5"
Processing time: about 60s
Also tried an approach based on EXPAND:
start.geonameid <> ende.geonameid AND expand(start.geom, 300) && ende.geom "
"order by distance limit 5"
Processing time: about 120s
The intended application is some kind of autocomplete. So, any approach
taking longer than <1s is not applicable. Is it generally possible to
achieve such a response time with PostGIS?
View this message in context: http://old.nabble.com/Find-n-Nearest-Neighbors-for-given-Point-using-PostGIS--tp31010122p31010122.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
