[postgis-users] PostGIS query layer in ArcMap - error readingOID
fork
forkandwait at gmail.com
Fri Jul 8 14:01:37 PDT 2011
Paul Ramsey <pramsey <at> opengeo.org> writes:
> Well you should certainly be able to work around it by creating your
> table using the "WITH OIDS" keywords to enabled OIDs on that table.
http://www.postgresql.org/docs/9.0/static/sql-altertable.html
search for "set with oids"
> Just shame you would have to.
It's not like ESRI actually wants anybody to use PostGIS, much less discover how
much easier it is than their garbarge ....
