[postgis-users] Newbie Geocoding Error
Paragon Corporation
lr at pcorp.us
Sun Jul 10 12:05:58 PDT 2011
Mike,
> 1. the upgrade_geocoder script ran with most of the sql returning
'already exists' errors. Do I need to modify the script to drop before
recreating?
No you should be fine. The already exists and already exists skipping issue
can be ignored. I didn't want to destroy some of these structures if they
existed because they could be tied to data.
That is why I don't have the whole upgrade script in a transaction because
it would fail the whole thing when it doesn't need to. Unfortunately
PostgresQL doesn't yet support the CREATE IF NOT EXISTS for a lot of things
like new columns I needed to add to lookup etc.
> 2. My original error went away.
> So, now onto another address that does not geocode. The results don't
even include the street in the query.
> 477 Camino del Rio South, San Diego, CA 94115
> SELECT * from normalize_address returns
> address predirabbrev streetname streettypeabbrev
postdirabbrev internal location stateabbrev zip parsed
> 477 <null> Camino del Rio <null> S <null> San Diego
CA 94115 true
> I don't have enough knowledge of postGIS right now to know if it's a bug
or operator error.
As Steve mentioned in another post, it could be a data issue since the
normalization looks right. I looked at the results
for California and I see what you mean that the street appears nowhere in
results.
If I look at my underlying Tiger edges and featnames for California.
ca_edges, ca_featnames
There is a Camino del Rio Ct, but has its zip listed as 93308 which is no
where near 94115 as far as numeric distance goes.
If I look at the street ranges in ca_addr for that tlid, It gives me ranges
from 2400 - 3199 again which is no where near what that is. So your address
fails the only Camino del Rio match it could possibly match to in a big way.
In fact when I look thru all the street names in ca_edges with zip 94115,
none start with Camino anything.
So even taking off the zip doesn't help. It does seem to be a data issue.
-- Steve,
I don't think its the zip issue per se because I do have that zip listed in
my ca_zip_state and as I recall, I don't think I have
my loader generate the zips from the zcta5 file, since that would be
inaccurate since zips aren't really polygons and also aren't updated
as frequently as you stated.
It could be this street is known by another name and Tiger doesn't have this
particular name listed in its featnames alias or it somehow missed this
place entirely.
Leo says his friend works around there :) so I guess its an important place
to miss.
Hope that helps,
Regina and Leo
http://www.postgis.us
Message: 10
Date: Sat, 9 Jul 2011 14:23:09 -0400
Subject: Re: [postgis-users] Newbie Geocoding Error
To: "'PostGIS Users Discussion'"
<postgis-users at postgis.refractions.net>
Message-ID: <20AE3B391EAA4F1A8CBE0347002383E2 at J>
Content-Type: text/plain; charset="us-ascii"
Mike,
Which version are you running with? For the newer ones -- if you look at
the normalize_address function , you should see a stamp in the beginning of
the code that has
--$Id: normalize_address.sql 7616 2011-07-07 12:41:13Z robe $-
That is the latest version stamp. Really old versions don't even have a
stamp. If you are running something older than a week or 2 ago, that is
probably why you are having these issues.
The easiest way to upgrade to the latest is:
1) Download the PostGIS 2.0 tar ball from here --
http://www.postgis.org/download/ (the tiger_geocoder is in
extras/tiger_geocoder/tiger_2010)
-- (This new version requires PostGIS 1.5+ and PostgreSQL 8.4+)
2) Edit the upgrade_geocoder.sh file with your postgres settings and then
run it.
3) Run the Missing_indexes_Generate_Script() to get the commands to build
indexes you may be missing.
http://www.postgis.org/documentation/manual-svn/Missing_Indexes_Generate_Scr
ipt.html
and then execute that generated script
I think this is a bug I might have fixed. When I run normalize on this I
don't get an error, and yours seems to be breaking in the normalize step.
When I run
SELECT * FROM normalize_address('3261 South West 160 Avenue, Miramar, FL
33027')
I get the below
address | predirabbrev | streetname | streettypeabbrev | postdirabbrev |
internal | location | stateabbrev | zip | parsed
3261 | SW | 160 | Ave |
| Miramar | FL | 33027 | t
Unfortunately I don't have Florida data loaded so can't tell if it will
geocode right or not.
Regarding bad rating results, the issue is often what the address gets
normalized to and a bad normalization is often the cause of bad geocoding
results. So probably the
best check to do is do a simple
SELECT * FROM normalize_address(...);
and see what it comes with and if that normalized addess makes sense.
There are many cases where it doesn't that I have fixed recently and some
more that are known bugs I am working on. Check out the list of issues and
closed ones for details:
http://trac.osgeo.org/postgis/query?component=tiger+geocoder
The other issue I see with your code -- which perhaps it was for testing, is
that you are normalizing twice.
You should just be doing a:
geocode('3261 South West 160 Avenue, Miramar, FL 33027')
No need for those extra steps.
You might want to take a look at the manual for recent improvements made too
and examples:
http://www.postgis.org/documentation/manual-svn/Geocode.html
Hope that helps,
Regina
http://www.postgis.us <http://www.postgis.us/>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110710/d2bbee7e/attachment.html>
