[postgis-users] converting to lat long
John Callahan john.callahan at udel.edu
Tue Jul 12 06:12:30 PDT 2011
Looks like you already have lat/long coordinates and don't need to use
ST_Transform.  Make sure you know if the original values are in 'decimal
degrees' or 'degrees minutes seconds'.  If in DD, just divide your values by
100 which should be easy in SQL.  If in DMS, then you need to parse the data
first.  I'm not sure how to do that in SQL but sure it's possible.
- John
On Tue, Jul 12, 2011 at 8:58 AM, Yamini Singh <yaminijsingh at live.com> wrote:
>  *Hi All,*
> *I have a column 'geocode' in a table which has attributes like 2329/4727
> now I would like to convert these **attributes **in another column to
> 'lat' and 'long'. For example, 'Lat' column will have **attribute '**23.29'
> and 'long' column will have **attribute ** '47.27'.*
> *Is there a way through which this can be converted automatically by a
> query or so.*
> *Looking fwd..*
> *Thanks*
> *YJ*
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110712/73465966/attachment.html>
