[postgis-users] converting to lat long
MarkW mark.wimer at gmail.com
Tue Jul 12 06:18:50 PDT 2011
Just to add to the other good advice you've already received:
If the data are in the format with an actual slash, as a single string (not
sure from your email), then string functions can help you get to the point
where you can divide, or create geometry, if that's where you're at:
http://www.postgresql.org/docs/8.4/interactive/functions-string.html
Mark
On Tue, Jul 12, 2011 at 8:58 AM, Yamini Singh <yaminijsingh at live.com> wrote:
>  *Hi All,*
> *I have a column 'geocode' in a table which has attributes like 2329/4727
> now I would like to convert these **attributes **in another column to
> 'lat' and 'long'. For example, 'Lat' column will have **attribute '**23.29'
> and 'long' column will have **attribute ** '47.27'.*
> *Is there a way through which this can be converted automatically by a
> query or so.*
> *Looking fwd..Thanks*
> *YJ*
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110712/991289b1/attachment.html>
