[postgis-users] Accumulated segment length of a linestring
Ralf Suhr
Ralf.Suhr at itc-halle.de
Thu Jul 21 04:43:59 PDT 2011
Hello Stefan,
use a trigger on table romy_2010 for fast calculating. You need only to add
the new segment length to the last summary length.
And you can't use st_makeline() on a point table without ordering the points.
Gr
Ralf
Am Donnerstag 21 Juli 2011, 11:47:53 schrieb Stephan Holl:
> Dear PostGIS-users,
> I would like to calculate the accumulated lengths of each
> linestring-segments into a new column, so that every segment holds the
> real length from the beginning of the linestring. The last segment of
> the linestring shows the overall length of the linestring then.
> My data (GPS POINT-data):
> CREATE TABLE romy_2010 (
> gid integer NOT NULL,
> id double precision,
> tag_zeit date,
> the_geom public.geometry,
> veroeffentlicht smallint DEFAULT 0,
> bild text,
> link text,
> beschreibung text,
> CONSTRAINT enforce_dims_the_geom CHECK ((public.ndims(the_geom) =
> 2)), CONSTRAINT enforce_geotype_the_geom CHECK
> (((public.geometrytype(the_geom) = 'POINT'::text) OR (the_geom IS
> NULL))), CONSTRAINT enforce_srid_the_geom CHECK ((public.srid(the_geom)
> = 4326)) );
> My current linestring representing the vertexes and additional
> information:
> CREATE OR REPLACE VIEW v_romy_2010_foo AS
> SELECT
> 'Romy'::text as storkname,
> n AS gid,
> n AS id,
> to_char(s.tag_zeit::timestamp, 'DD.MM.YYYY') AS zeit,
> s.beschreibung,
> s.bild,
> s.link,
> -- segments
> st_makeline(st_PointN(m.the_geom,n), st_PointN(m.the_geom, n+1)) AS
> the_geom,
> round(st_length_spheroid(st_makeline(st_PointN(m.the_geom,n),
> st_PointN(m.the_geom, n+1)), 'SPHEROID["WGS
> 84",6378137,298.257223563]')/1000) AS length_sphero_inKM
> FROM
> (SELECT
> st_makeline(the_geom) AS the_geom
> FROM
> (SELECT
> gid,
> beschreibung,
> the_geom
> FROM romy_2010 WHERE gid >= 1 AND veroeffentlicht = 1 ORDER
> BY gid ) AS t
> ) AS m
> CROSS JOIN generate_series(1,1000) AS n
> LEFT JOIN romy_2010 s ON s.id = n
> WHERE n < st_npoints(m.the_geom);
> I appreciate any pointers how to solve this.
> TIA
> Best regards
> Stephan
