[postgis-users] Coverages and PostGIS wiki page
Bryce L Nordgren
bnordgren at fs.fed.us
Fri Jul 22 14:04:40 PDT 2011
I added geomval to the concept map on the wiki page. Also added a section
on it.
postgis-users-bounces at postgis.refractions.net wrote on 07/22/2011 05:48:24
PM:
> Some observations:
I think you mistook my intent. I want to show people that if they intend
to do the "obvious" thing, meaning to think of a table as a raster
coverage the same way that a table has been taken to be a vector coverage
for years, there are a few caveats.
How you think of the table depends on what you're doing with the table.
> This distinction disappear if you do something like this on a raster
> coverage to produce a very different kind of raster coverage being
> something very new in the GIS world and having, really, no
> distinction with a vector coverage: CREATE TABLE rastcov AS SELECT
> ST_AsRaster((gv).geom, 1), (gv).val FROM (ST_DumpAsPolygons(rast)
> gv) foo. (Note that ST_AsRaster() is still to be implemented). The
> result is a raster coverage, composed of a series of rows acting
> exactly like a vector coverage but in which the geometries are
> stored as small (or bigger) rasters. You might prefer to work with
> this kind of object if you really want your raster coverage to have
> the exact same characteristics of a vector coverage (one geometric
> area per row value).
So essentially you're proposing to create one raster for every distinct
pixel value in the raster? Each raster being a "mask" containing the
locations of it's one value. And you want to select the distinct pixel
values first by creating polygons which outline the pixels for each value,
then converting each individual geometry back into a mask containing only
"nodata" or the value in question.
I think it might be faster to use ST_Reclass(), provided there was some
"ST_DistinctValues(raster)" method.
Could I request a "ST_AsRaster(setof geomval) returns raster" which acts
as the inverse of ST_DumpAsPolygons? So if you did
ST_AsRaster(ST_DumpAsPolygons(rast)), you'd get your original raster back?
That's more along the lines of what I'd expect. That way, you can take the
raster apart into geometries, edit them, then get a new raster back. I was
kind of assuming that was what ST_AsRaster did...
> "The third observation is that a "raster coverage" does not need to
> be backed by a table at all. A single raster item could provide all
> of the data required." Totally agree, but storing a raster coverage
> in PostgreSQL as a multi row table give some major advantages: 1)
> You get fast gist indexing of the tiles for (almost) free, 2) You
> can store coverage of (theoretically) 32 TB, 3) You don't have to
> provide tiles for all the covered area, 4) tiles can overlap, 5)
> Tiles can have different dimensions, 6) implementation was relatively
easy.
The point was that any of the "aggregation" functions (or mapalgebra)
could produce something for display or analysis by returning an item with
the "raster" data type. It need not be stored in a table before being
displayed or used in the next processing step.
Note that if one is trying to consider a table to be a single raster
broken into rows, #3 #4 and #5 are disadvantages. Extra care must be taken
to constrain the flexibility those items provide. Calling attention to
this fact is the point of the wiki page.
The reason is: the "raster coverage" itself has metadata which pertains to
the coverage as a whole. If a "row raster" is to be considered to belong
to a "raster coverage", it must conform to the "raster coverage metadata".
Including:
* location of a corner pixel
* pixel size in each dimension
* number of pixels in each dimension
* number of bands
* types of bands
* srid
These are recorded in "raster_columns", along with the column extent. Each
row must conform to all of these criteria, and the extent of the "row"
must be contained within the extent of the column. Failure to comply means
the row rasters cannot be aggregated in a simple way to form a larger
"raster coverage": they must be resampled onto a common grid before
display or processing.
Clearly, if you don't consider the rows to be part of a larger coverage,
then this does not apply.
> "Clearly, a table with a raster column could be used as an index
> into many unrelated rasters. This is a legitimate use of the table
> facility. However, it is an example of a table which could not be
> used to provide information to a "raster coverage." I totally agree
> with your conclusion. It is possible to use PostGIS raster this but
> it is also very possible to use it in a clever way.
Again, the point is that it's perfectly valid to use it this way. It's not
wrong, and it's not un-clever. If you need an index, take advantage of the
flexibility offered by #3, #4, and #5. The advantage of doing so is that
you do not have to create a new table for each "type" of raster. For
anything other than the most trivial of cases, that will become
unmanageable.
In addition to the "index" case, it is perfectly acceptable to consider a
table to be a "raster type definition". The table may then contain many
raster coverage instances belonging to the same type. However, you still
cannot aggregate rows belonging to different raster coverages into some
"hybrid raster coverage".
For example, define a table to contain "Landsat Band 2" images. Columns
are "raster, path, row, date". (Path & row is a coarse global grid used by
landsat to describe the location of a scene. Two scenes over the same
path, row cover the same area.) Insert one scene over a given path/row;
divide it into 1000 rows just for kicks. 16 days later, you get another
scene with the same path/row and load it into the database using 1000
rows.
You must guard against combining rows from different scenes. All queries
have to select for path, row, date. This is also legitimate if this is
what you need to do. But it puts the onus on the user to be aware of the
subtleties to ensure they achieve the expected results.
So we have two ways of using a table, and the user needs to be aware of
the subtleties of both:
* The table stores more than one raster coverage. (e.g., "raster type
definition", "index of unrelated images") Here the user must ensure row
data from different coverages are never mixed.
* The table stores only one raster coverage. Here the user does not have
to worry about mixing coverages.
Vector coverage tables are rarely used to store multiple coverage
instances, but if they are, there is no technical obstacle to combinining
elements from different coverages. There is an obstacle with inhomogeneous
rasters. Vector coverage tables do not sport a grid definition, so the
grid definitions of individual rows do not need to be compatible. Raster
row data which are part of the same collection must ensure their grid
definitions are compatible.
Bryce
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110722/1d186db6/attachment.html>
