[postgis-users] exterior rings in multipolygons
Sandro Santilli strk at keybit.net
Mon Jul 25 13:44:04 PDT 2011
On Mon, Jul 25, 2011 at 03:40:34PM -0500, Mr. Puneet Kishor wrote:
> Please help me understand the following
> SELECT
>     ST_Nrings(the_geom) nr,
>     ST_NumInteriorRings(the_geom) nir,
>     ST_AsText(the_geom) WKT
> FROM table
> WHERE objectid = 280;
> nr  nir  WKT
>  4    3  "MULTIPOLYGON(((..),(..),(..),(..)))"
> Looking at the above, I am assuming the first (..) is the exterior ring, and the remaning three (..) are the 3 interior rings. However,
> SELECT ST_ExteriorRing(the_geom) er
> FROM table
> ERROR: ExteriorRing: geom is not a polygon
> So, what is going on? Of course, the docs say that ST_ExteriorRing doesn't work on a MULTIPOLYGON. So, is the above only an implementation anomaly, and I can treat the first ring as an exterior ring? Or, is it really something else?
All your rings are wrapper in another pair of parens, which identify
a component of the MULTIPOLYGON, that is a POLYGON. You must extract
the Polygon to use ST_ExteriorRing against it. So your query would be:
 SELECT ST_ExteriorRing(ST_GeometryN(the_geom,1)) er
 FROM table
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
