[postgis-users] Problems
Willy-Bas Loos
willybas at gmail.com
Wed Jul 27 06:06:25 PDT 2011
we would need more info to answer that.
* the error message
* the table definition
That would probably do.
possibly also:
* some data from building_poly with which the error can reproduced.
cheers,
WBL
On Fri, Jul 15, 2011 at 7:32 PM, Brian Sanjeewa Rupasinghe
<jinkabs at gmail.com> wrote:
> I have nbuff table created with two columns; autoid serial and Geometry
> column in PostGIS. After adding the_geom column, i tried to insert data
> using following query:
> INSERT INTO nbuff (the_geom) VALUES ((SELECT
> ST_AsText(ST_ConvexHull(ST_Union(the_geom) FROM building_poly))));
> However, when above query is run, it gives an error message. how can i solve
> ths?
> cheers, Sanjeewa.
> postgis-users mailing list
"Patriotism is the conviction that your country is superior to all
others because you were born in it." -- George Bernard Shaw
