[postgis-users] Mapserver with postgis, sql query error.
Nicolas ( cse )
nicolas.machado at codigosudeste.com.ar
Sat Jul 30 11:07:56 PDT 2011
Hi Sandro, my second question, is because the firs time I load data using
the GUI interface of tha utility.
But I just loaded via command line, and I guet the same error ...
In the table I got 67811 records, the error means that ALL of them have a
problem ? or at leastone of them?
In that case, how can I know wich one is?
How is it posible that if I can see the map using the shape file, but I
can't using the postgis database ?
Thanks and looking fordward to a solution ...
Best Regards
2011/7/30 Sandro Santilli <strk at keybit.net>
> On Sat, Jul 30, 2011 at 11:17:08AM -0300, Nicolas ( cse ) wrote:
> > ERROR: geometry requires more points
> > If I extract function AsBinary, there is no error:
> > Here is my question:
> > 1) How to check if the data is correct ?
> ST_IsValid, ST_IsValidReason, ST_IsValidDetail
> > 2) do I have lo load data with shp2pgsql command line utility?
> How's that related to your problem ?
> > 3) any idea ?
> Many.
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> postgis-users mailing list
_______________
.:Nicolás Machado
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110730/f21d3bd5/attachment.html>
