[postgis-users] Mapserver connection to Postgis Raster
Paragon Corporation
lr at pcorp.us
Wed Jun 1 21:53:40 PDT 2011
Virginia,
I think you are missing a mode='2' in your connection. That was a new
requirement that was added for GDAL 1.8+
Try putting that in. I think the speed on the loading still needs quite a
bit of work though last I tried. The speed issues will hopefully be
resolved before 2.0 release.
Thanks,
Regina
http://www.postgis.us
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Virginia
Maffei
Sent: Wednesday, June 01, 2011 8:00 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Mapserver connection to Postgis Raster
Hi, i'm new at this and i'm trying to connect to postgis raster in the
mapfile.
I loaded a tif file into postgis raster database with the raster2pgsql.py
script. It created a table with 2 fields: rid and rast.
In the mapfile i added the connection like it specifies in the postgis
raster FAQ but it doesn't displays anything.
This is my mapfile:
MAP
IMAGETYPE PNG24
EXTENT 366582.2901411663 6127927.100382689 857582.2901411663
6670927.100382689
SIZE 491 543
SHAPEPATH "../data"
LAYER # MODIS raster layer begins here
NAME modis
TYPE RASTER
STATUS ON
DATA "PG:host=localhost port=5432 dbname='postgis' user='postgres'
password='postgres' schema='public' table='HumedadDeExtincion'"
PROCESSING "NODATA=0"
PROCESSING "SCALE=AUTO"
PROCESSING "SCALE_BUCKETS=201"
PROCESSING "BANDS=1"
OFFSITE 71 74 65
CLASS
NAME "red"
EXPRESSION ([pixel] < 10)
COLOR 255 0 0
END
CLASS
NAME "green"
EXPRESSION ([pixel] >= 10 AND [pixel] < 15000 )
COLOR 0 255 0
END
CLASS
NAME "blue"
EXPRESSION ([pixel] >= 15000 )
COLOR 0 255 0
END
END # MODIS raster layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # All map files must come to an end just as all other things must come
to...
I have gdal 1.6 , postgis 1.5 and ms4w with mapserver 5.6.6
We cant see the tiff file on the browser, it only appears a white image.
We did try with the tif without the database connection an it works.
Could you help us?
Thank you
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110602/59323e48/attachment.html>
