[postgis-users] Mapserver connection to Postgis Raster
Virginia Maffei
vmaffei at gmail.com
Thu Jun 2 07:16:15 PDT 2011
Thank you!! I will try that installation
Virginia
2011/6/2 Jorge Arévalo <jorge.arevalo at deimos-space.com>
> On Thu, Jun 2, 2011 at 3:25 PM, Virginia Maffei <vmaffei at gmail.com> wrote:
> > Thank you for your quick response!
> > I have another question: can i install postgis 2.0 in windows? where can
> I
> > download it?
> > Virginia
> Yes, you can. Follow this post's instructions:
> http://gis4free.wordpress.com/2011/03/10/how-to-install-and-configure-postgis-raster-on-windows/
> Best regards,
> Jorge
> >> Hi,
> >> The mode=2 parameter is only valid with the last version of GDAL
> >> (1.8.0). So, as Regina said, you need that version to make it work
> >> properly. More accurately:
> >> - With a GDAL version down to 1.7.1, you can't make it work in any
> >> way. No driver.
> >> - With a GDAL version between 1.7.1 and 1.7.3, both included, you can
> >> use the old version of the driver, thought to work with the old
> >> wktraster extension, now abandoned. And it was buggy. Not recommended.
> >> Neither GDAL 1.7.x nor wktraster.
> >> - With GDAL version up to 1.8.0, you can use the last version of GDAL
> >> PostGIS Raster driver, and you'll need PostGIS 2.0, that includes
> >> PostGIS Raster extension. Additionally, as Regina said, those days
> >> we're working on the driver, and all the improvements will be included
> >> in GDAL 1.8.x
> >> So, summarizing: You need PostGIS 2.0 plus GDAL 1.8.0 to make it work.
> >> Further information on the driver:
> >> http://trac.osgeo.org/gdal/wiki/frmts_wtkraster.html
> >> Best regards,
> >> Jorge
> >> On Thu, Jun 2, 2011 at 6:53 AM, Paragon Corporation <lr at pcorp.us>
> wrote:
> >> > Virginia,
> >> > I think you are missing a mode='2' in your connection. That was a
> new
> >> > requirement that was added for GDAL 1.8+
> >> > Try putting that in. I think the speed on the loading still needs
> quite
> >> > a
> >> > bit of work though last I tried. The speed issues will hopefully be
> >> > resolved before 2.0 release.
> >> > Thanks,
> >> > Regina
> >> > http://www.postgis.us
> >> > ________________________________
> >> > From: postgis-users-bounces at postgis.refractions.net
> >> > [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> >> > Virginia
> >> > Maffei
> >> > Sent: Wednesday, June 01, 2011 8:00 PM
> >> > To: postgis-users at postgis.refractions.net
> >> > Subject: [postgis-users] Mapserver connection to Postgis Raster
> >> > Hi, i'm new at this and i'm trying to connect to postgis raster in the
> >> > mapfile.
> >> > I loaded a tif file into postgis raster database with the
> >> > raster2pgsql.py
> >> > script. It created a table with 2 fields: rid and rast.
> >> > In the mapfile i added the connection like it specifies in the postgis
> >> > raster FAQ but it doesn't displays anything.
> >> > This is my mapfile:
> >> > MAP
> >> > IMAGETYPE PNG24
> >> > EXTENT 366582.2901411663 6127927.100382689 857582.2901411663
> >> > 6670927.100382689
> >> > SIZE 491 543
> >> > SHAPEPATH "../data"
> >> > LAYER # MODIS raster layer begins here
> >> > NAME modis
> >> > TYPE RASTER
> >> > STATUS ON
> >> > DATA "PG:host=localhost port=5432 dbname='postgis' user='postgres'
> >> > password='postgres' schema='public' table='HumedadDeExtincion'"
> >> > PROCESSING "NODATA=0"
> >> > PROCESSING "SCALE=AUTO"
> >> > PROCESSING "SCALE_BUCKETS=201"
> >> > PROCESSING "BANDS=1"
> >> > OFFSITE 71 74 65
> >> > CLASS
> >> > NAME "red"
> >> > EXPRESSION ([pixel] < 10)
> >> > COLOR 255 0 0
> >> > END
> >> > CLASS
> >> > NAME "green"
> >> > EXPRESSION ([pixel] >= 10 AND [pixel] < 15000 )
> >> > COLOR 0 255 0
> >> > END
> >> > CLASS
> >> > NAME "blue"
> >> > EXPRESSION ([pixel] >= 15000 )
> >> > COLOR 0 255 0
> >> > END
> >> > END # MODIS raster layer ends here
> >> > # End of LAYER DEFINITIONS -------------------------------
> >> > END # All map files must come to an end just as all other things must
> >> > come
> >> > to...
> >> > I have gdal 1.6 , postgis 1.5 and ms4w with mapserver 5.6.6
> >> > We cant see the tiff file on the browser, it only appears a white
> image.
> >> > We did try with the tif without the database connection an it works.
> >> > Could you help us?
> >> > Thank you
> >> > _______________________________________________
> >> > postgis-users mailing list
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> Jorge Arévalo
> >> Internet & Mobilty Division, DEIMOS
> >> http://es.linkedin.com/in/jorgearevalo80
> >> http://mobility.grupodeimos.com/
> >> http://geohash.org/ezjqgrgzz0g
> Jorge Arévalo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110602/9e1cb86d/attachment.html>
