[postgis-users] multiline with with to polygon
Richard White
Richard.White at infoterra-global.com
Fri Jun 3 07:10:17 PDT 2011
Try using ST_Buffer. I have for just this purpose and it worked fine.
Regards,
R.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Martin Spott
Sent: 03 June 2011 15:04
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] multiline with with to polygon
Jaime Lop wrote:
> Is there an easy way to convert multi lines with a width to polygons?
> For example, I have a corridor defined as 100 kms around a given line.
PostGIS doesn't support this feature, as far as I can tell from my
limited insight, but if it would, I'd be one of its users ;-)
Cheers,
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
Infoterra Ltd. Is part of the Astrium GEO-Information Services Division and a wholly owned subsidiary of Astrium, Europe's leading space systems and services specialist.
Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement.
Infoterra Limited a company registered in England under number 2359955 and having its registered office at Atlas House, 41 Wembley Road, Leicester, LE3 1UT. VAT number GB 476 0468 27.
P Before printing, think about the environment
