[postgis-users] Basic postgis raster questions
Bryce L Nordgren
bnordgren at fs.fed.us
Fri Jun 3 16:59:09 PDT 2011
postgis-users-bounces at postgis.refractions.net wrote on 06/03/2011 12:00:56
PM:
> Right. But you can compute stats on the result of ST_Intersection()
> using ST_Area(geom)/areaOfOnePixel. Since the results are vector,
> the ST_histogram function is useless here.
That's basically the approach I started to take. Unfortunately, it's
taking a fair bit of time because the rasters are a bit larger than
optimum for this approach. Today I figured out how to do it in ENVI, so
there's somewhat less pressure.
> It is true that PostGIS raster do not allow yet to reassemble raster
> tiles into bigger rasters but you don't have to do that in order to
> compute histogram on a tiled coverage. Just compute the histogram
> for every tiles and aggregate the results using a GROUP BY query.
> (Bborie: shouldn't we have a ST_Histogram variant working on a whole
> table like we have for the other stat functions?)
I may be mistaken, but I did not see a way to ensure that all bins are
constant for the individual runs of ST_Histogram on each tile. You can set
the number of bins and the width of the bins, but each tile will have its
own unique min/max values, which will move the bins around. Without
constant bins, there's no way the results can be aggregated.
> If the polygon area is small comparing with the raster area you
> should retile your raster coverage into smaller tiles so the query
> has to vectorize less useless raster area. It is important to index
> the coverage and to add "WHERE ST_Intersects()" in this case. Make
> sure also that both your raster coverage and your vector coverage
> have indexes. This makes a HUGE difference. I see that you don't do
> that in your tutorial. You can do it while loading your data with
> the "-I" option or afterward with a "CREATE INDEX" query.
Good catch. Fixed.
> As I said we are very near to have a geometry parameter to the stats
> functions restricting the computation to defined area. Once we have
> this all your tutorial should be much shorter...
I may be missing the boat here, but it seems to me that a version of
ST_Intersection() which returns a raster would eliminate the need for a
separate geometry parameter, and would be more in line with the spirit of
"seamless vector/raster" processing. It also would seem that your separate
geometry parameter would behave very much like a raster-returning
ST_Intersection(), except that it is only usable "vicariously" via the
stats functions.
The two things standing in my way appear to be "Objective FV.02" and
"Objective FV.03" on this page:
http://trac.osgeo.org/postgis/wiki/WKTRaster/PlanningAndFunding I'm
curious if the page is accurate. Are these activities still unfunded and
unallocated, and are 4 weeks/4800USD (FV.02) and 2 weeks/2400USD (FV.03)
still considered a reasonable estimate of the effort required to implement
these items? Don't get excited, but if I'm even thinking of running around
with my hand out for money, I need ballpark figures.
Bryce
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110603/13952d75/attachment.html>
