[postgis-users] Selecting Unique polygons with st_intersects()
Ben Madin
lists at remoteinformation.com.au
Mon Jun 6 14:35:37 PDT 2011
G'day all,
I've just realised that in selecting a group of properties by the local government area they reside in, I end up with duplicates = some properties span shire boundaries. I've used st_intersects, because some properties cover boundaries, so I need those that are within and may be partially without the boundary.
I'm sure I'm not the first person to have this problem, but I was wondering if anyone has any insights into the most efficient way to choose a unique listing of property and shire. I was wondering about taking the area of the property still within the local government area, and choosing the row with the biggest value...
Although I have unique property identifiers, I can't be sure of not getting a ridiculous answer - an erroneously small amount of a property in a shire etc.
My current query looks a bit like :
SELECT DISTINCT ON (pic) lga_name09 as shire, propname as name, pic
FROM lga l
JOIN qldproperties q ON st_intersects(q.the_geom, l.gda_geom) AND l.gid in (245,247,252,254,258,259,275,279,289,297);
but I need to do better than using SELECT DISTINCT ON.
cheers
Ben
