[postgis-users] terminated server connection during st_isvalid()
Birgit Laggner birgit.laggner at vti.bund.de
Tue Jun 7 05:19:37 PDT 2011
Dear list,
I have a polygon (see end of e-mail) which always causes the termination
of my server connection when I am trying to test it with st_isvalid().
Maybe, anybody has an explanation or a workaround???
PostGIS:
POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.3" USE_STATS (procs from 1.5 r5385 need upgrade)
PostgreSQL:
PostgreSQL 8.4.5 on x86_64-unknown-linux-gnu, compiled by GCC gcc (SUSE
Linux) 4.4.1 [gcc-4_4-branch revision 150839], 64-bit
(translated :-) ) part of the pg_log error messages, related to this:
SELECT: IndexedNestedRingTester.cpp:71: bool
geos::operation::valid::IndexedNestedRingTester::isNonNested():
assertion »innerRingPt!=__null« not erfüllt.
2011-06-07 13:21:14 CEST   LOG:  Server process (PID 13483) was
terminated by signal 6: Aborted
2011-06-07 13:21:14 CEST   LOG:  terminating any other active server
processes
2011-06-07 13:21:14 CEST gis laggner_b WARNING:  terminating connection
because of crash of another server process
2011-06-07 13:21:14 CEST gis laggner_b DETAIL:  The postmaster has
commanded this server process to roll back the current transaction and
exit, because another server process exited abnormally and possibly
corrupted shared memory.
2011-06-07 13:21:14 CEST gis laggner_b HINT:  In a moment you should be
able to reconnect to the database and repeat your command.
I really would appreciate any help.
Thanks and regards,
Birgit.
Polygon:
POLYGON((4443628.47695753 5568392.6484742,4443627.12531426
5568394.34677421,4443627.02107313 5568394.38618749,4443625.82088725
5568396.44357745,4443625.63973148 5568396.7541194,4443625.65758256
5568396.78999158,4443625.60937614 5568396.79576678,4443625.59192468
5568396.80019632,4443625.58510664 5568396.82656923,4443625.57348413
5568396.78834027,4443625.56997522 5568396.76862257,4443625.56456072
5568396.73819666,4443624.52186656 5568398.2771376,4443621.20563297
5568402.58824126,4443618.63555194 5568407.894215,4443617.55777602
5568410.63010771,4443616.56290595 5568413.1172829,4443616.14837675
5568414.69249385,4443615.89965923 5568415.68736393,4443615.73384755
5568416.76513984,4443615.56803587 5568417.59419824,4443615.48513003
5568419.00359751,4443615.38620514 5568420.369393,4443615.75117813
5568422.19425794,4443615.87283579 5568423.53249224,4443616.48112411
5568425.84398784,4443617.69770074 5568429.49371773,4443619.40090802
5568433.50842062,4443620.00919634 5568435.33328557,4443620.49582699
5568437.40146584,4443621.10411531 5568438.8613578,4443621.59074596
5568440.68622275,4443622.19903428 5568442.99771835,4443622.68566493
5568445.55252927,4443623.53726857 5568447.74236721,4443624.14555689
5568449.68888982,4443624.7538452 5568451.27043944,4443625.60544884
5568452.60867374,4443626.45705249 5568454.43353869,4443627.30865613
5568456.01508831,4443628.6237268 5568458.51422869,4443630.41764204
5568461.90273525,4443631.81290945 5568463.99563636,4443634.35428937
5568468.67974837,4443636.6465144 5568473.11470549,4443639.2377253
5568478.24729631,4443641.33062641 5568483.13073223,4443642.77572479
5568486.71856271,4443643.92183731 5568489.90774535,4443645.26727374
5568494.34270247,4443646.0645694 5568497.38239218,4443647.7089917
5568503.91025041,4443648.50628736 5568507.6974048,4443648.65824315
5568510.51768795,4443648.2250504 5568511.55068605,4443648.4066254
5568512.92965758,4443648.5582756 5568514.01655246,4443648.85817827
5568515.61603338,4443649.02479086 5568516.48241888,4443649.40324498
5568518.21174133,4443649.55273791 5568518.95920602,4443649.55273791
5568519.55717776,4443649.50290694 5568520.30464244,4443649.50290694
5568521.40092398,4443649.55273791 5568522.14838866,4443649.50290694
5568522.69652943,4443649.55273791 5568523.54365607,4443649.52084609
5568524.39676243,4443649.55273792 5568525.25784174,4443649.42517061
5568526.72486576,4443649.39327878 5568527.64972872,4443649.48895426
5568529.53134649,4443649.36138696 5568531.44485607,4443649.32949513
5568532.81620461,4443649.07436052 5568535.11241611,4443648.97868504
5568535.9416036,4443648.81922591 5568537.12160118,4443648.6916586
5568538.7161925,4443648.5640913 5568540.8848367,4443648.75634995
5568550.36947508,4443647.77119976 5568555.59957849,4443646.63750767
5568560.26861716,4443645.85700141 5568563.191364,4443645.82378838
5568563.44046175,4443646.11361993 5568563.51731702,4443647.21055309
5568563.44326596,4443647.23964384 5568563.49280891,4443647.27905649
5568563.48513045,4443648.45908688 5568563.47248124,4443648.49846883
5568563.46398466,4443648.58891723 5568563.35115205,4443649.71364965
5568563.22529786,4443649.87345947 5568562.80365399,4443650.21099894
5568563.96507469,4443649.35236444 5568567.70308239,4443650.38388258
5568571.6481881,4443655.59066955 5568576.53763848,4443660.53868151
5568577.8595283,4443668.76935303 5568580.43929923,4443678.26070493
5568585.98212236,4443685.80289392 5568590.72578821,4443690.8908347
5568593.49097342,4443694.13668424 5568593.73550761,4443702.62848713
5568591.8894635,4443708.58802004 5568593.04854379,4443716.86968059
5568597.37040055,4443723.8787214 5568603.97892473,4443724.88001294
5568608.38460752,4443723.27794647 5568613.19080693,4443728.08414588
5568622.00217251,4443734.97843482 5568630.50605341,4443739.89938609
5568631.81482963,4443748.71075167 5568645.63265293,4443757.27139267
5568658.71626014,4443766.46694844 5568659.96420696,4443774.74433179
5568663.05512578,4443779.35027289 5568667.26055027,4443782.35414752
5568676.67269077,4443784.95750554 5568677.67398232,4443790.36447987
5568676.67269077,4443795.17067928 5568673.66881614,4443802.98075331
5568673.06804122,4443811.19134397 5568674.67010769,4443819.40193462
5568675.87165754,4443830.61639991 5568675.87165754,4443838.55721986
5568677.62132864,4443841.03056473 5568677.33285103,4443853.98948927
5568678.25697684,4443855.8489468 5568678.87553217,4443857.30699277
5568680.02157228,4443862.39660817 5568680.47236312,4443863.55889168
5568681.34407576,4443864.62431824 5568682.60321624,4443865.49603088
5568685.41206807,4443866.75517135 5568688.41463382,4443866.27088656
5568689.28634646,4443866.07717264 5568690.83605782,4443865.78660176
5568695.58204884,4443865.10860304 5568698.48775764,4443863.94631952
5568701.97460819,4443863.2683208 5568708.17345361,4443862.39660817
5568711.85401808,4443861.64345828 5568713.86241779,4443861.62175249
5568714.56601295,4443861.27064601 5568714.81689938,4443860.96225076
5568715.38963342,4443860.60979904 5568715.69802867,4443860.52168612
5568716.05048039,4443860.08112147 5568717.06377907,4443858.84754047
5568716.05048039,4443857.43773361 5568714.90501231,4443855.76358797
5568713.53926192,4443853.69293414 5568712.87841495,4443851.93067557
5568712.17351152,4443851.18171568 5568711.90917274,4443850.20265273
5568711.63220385,4443849.04488174 5568711.16909545,4443847.11526342
5568710.62880232,4443845.64875349 5568710.32006339,4443844.7225367
5568709.93413973,4443843.10165731 5568709.47103133,4443840.70893059
5568708.08170614,4443837.08124815 5568706.76956568,4443829.6715138
5568704.53120843,4443822.49333365 5568703.21906797,4443814.77486037
5568702.98751377,4443806.28453976 5568702.60159011,4443799.72383748
5568702.29285118,4443792.70002679 5568701.52100385,4443787.60583443
5568700.98071072,4443780.42765427 5568700.20886339,4443775.56501611
5568698.51079927,4443766.22566344 5568695.26904049,4443759.81933062
5568692.72194431,4443753.02707413 5568690.48358706,4443749.24502222
5568689.24863133,4443745.92607871 5568687.31901301,4443740.52314741
5568683.30540691,4443736.35517184 5568679.90927866,4443733.65370619
5568677.20781302,4443729.79446955 5568672.42235958,4443719.22016116
5568660.458726,4443709.49488483 5568650.42471073,4443697.77951427
5568637.72155976,4443694.87486592 5568633.80028449,4443692.40591483
5568630.96825235,4443690.88097444 5568629.95162542,4443688.41202334
5568628.86238229,4443684.99906153 5568626.68389603,4443682.02179697
5568623.19831801,4443679.48022967 5568620.00320483,4443679.04453242
5568618.9865779,4443678.24575412 5568616.51762681,4443677.15651099
5568614.70222159,4443675.41372198 5568613.39512983,4443674.03401401
5568611.79757324,4443665.53791759 5568601.84915264,4443658.78461018
5568595.45892627,4443655.29903216 5568591.68288342,4443652.75746485
5568586.23666776,4443647.31124919 5568575.12638782,4443648.76357337
5568568.51831283,4443643.50110829 5568570.37476199,4443642.44596321
5568574.25499332,4443642.59119563 5568576.28824716,4443648.90880579
5568588.48777023,4443655.15379974 5568599.38020154,4443660.16431814
5568602.86577956,4443663.940361 5568607.3679845,4443670.76628462
5568615.28315126,4443672.36384121 5568618.69611307,4443673.52570055
5568620.51151829,4443679.55284588 5568626.68389603,4443682.31226181
5568629.66116059,4443683.76458598 5568630.6051713,4443685.14429395
5568631.4039496,4443688.77510439 5568634.59906278,4443692.04283378
5568637.64894355,4443694.36655246 5568640.33574327,4443700.53893021
5568648.0330614,4443710.11236269 5568657.60289088,4443715.74684818
5568663.62330004,4443720.53230162 5568668.48593821,4443727.5561123
5568675.12382523,4443732.34156574 5568680.37238706,4443734.81147719
5568682.91948324,4443738.3619749 5568685.85250309,4443740.90907108
5568687.70493668,4443749.39939169 5568692.41320538,4443753.95329092
5568693.6481611,4443758.12126649 5568695.11467103,4443761.98050313
5568696.81273515,4443767.92372756 5568699.12827713,4443775.41064664
5568702.52440538,4443780.9679474 5568703.9909153,4443784.98155351
5568705.14868629,4443787.91457336 5568706.61519621,4443789.53545275
5568707.23267408,4443791.46507107 5568707.38704354,4443795.40149244
5568707.07830461,4443801.73064053 5568707.23267408,4443809.98940694
5568707.23267408,4443817.86224968 5568707.23267408,4443824.34576724
5568707.61859774,4443828.12781915 5568708.4676298,4443835.0744451
5568709.77977026,4443841.24922372 5568711.63220385,4443843.02447258
5568712.32686644,4443843.79631991 5568712.48123591,4443845.05786714
5568713.05464081,4443848.1858761 5568714.37633474,4443849.50757003
5568715.1693511,4443849.50757003 5568717.54840017,4443849.5516265
5568719.26660228,4443849.94280679 5568720.37413328,4443854.08944232
5568726.44780597,4443858.06540086 5568730.71198028,4443859.91144497
5568732.55802439,4443862.12669789 5568734.40406849,4443862.86511554
5568735.51169495,4443864.34195082 5568736.61932142,4443865.44957728
5568738.0961567,4443866.92641257 5568740.68061845,4443870.34786799
5568749.99301605,4443871.72612725 5568752.86450955,4443872.81777944
5568754.23817635,4443873.8983657 5568754.93283895,4443874.51584356
5568755.24157788,4443875.04900664 5568755.81818012,4443877.9119718
5568755.93624048,4443878.8381886 5568756.01342521,4443879.78891841
5568756.41286194,4443880.95634778 5568756.92580658,4443882.80239188
5568756.92580658,4443886.17073821 5568760.87606337,4443889.41249699
5568764.96685421,4443891.95959317 5568769.67512291,4443893.88921149
5568774.38339162,4443895.27853668 5568776.004271,4443896.97660081
5568777.93388932,4443898.05718707 5568779.40039925,4443898.75184966
5568780.55817024,4443900.29554432 5568783.41400535,4443901.29894584
5568784.10866795,4443904.38160657 5568785.9511866,4443910.49305347
5568790.52380932,4443913.07751522 5568798.27719456,4443918.1252176
5568804.33106794,4443920.47207284 5568806.44297307,4443922.84057201
5568808.08270326,4443924.11591771 5568810.45120243,4443928.48853157
5568815.91696975,4443930.67483849 5568819.19643013,4443932.67895317
5568822.29369828,4443936.32279805 5568827.57727335,4443940.14883517
5568832.49646393,4443942.51733434 5568835.95811656,4443945.61460248
5568840.14853817,4443947.30851403 5568842.00201678,4443948.34748614
5568846.34307446,4443949.46624178 5568850.99254907,4443949.98721633
5568855.63487889,4443950.7249163 5568858.45469087,4443950.7249163
5568859.17393345,4443951.26434824 5568859.80327071,4443951.44415888
5568860.70232394,4443952.52302276 5568863.12976766,4443953.33217066
5568864.02882089,4443954.50093986 5568865.28749541,4443955.31008777
5568866.45626461,4443956.209141 5568867.62503381,4443957.46781552
5568869.69285623,4443958.00724745 5568870.77172011,4443959.3558273
5568873.1092585,4443961.3337444 5568873.64869044,4443963.49147215
5568874.09821706,4443965.6491999 5568873.64869044,4443967.17759039
5568872.74963721,4443967.80692765 5568872.39001592,4443968.25645427
5568872.21020528,4443968.75301744 5568872.03218083,4443969.9646554
5568871.94048931,4443971.1334246 5568871.58086802,4443973.47096299
5568871.31115205,4443975.08925881 5568871.67077334,4443976.5024422
5568871.31524139,4443977.1041231 5568871.05737814,4443978.30748489
5568870.88546932,4443979.25298344 5568870.54165166,4443980.62825406
5568870.19783401,4443983.03497763 5568869.68210753,4444006.58648695
5568864.00911623,4444009.68084584 5568865.38438685,4444011.14207087
5568869.16638105,4444004.78144426 5568870.88546932,4443992.83378078
5568873.80791938,4443988.87987776 5568874.66746351,4443987.93437921
5568875.01128117,4443987.41865273 5568874.92532676,4443986.21529094
5568876.04273413,4443985.61361004 5568876.21464296,4443984.86146842
5568876.13387743,4443983.62850068 5568876.35805338,4443982.28344496
5568877.14266922,4443979.36915756 5568878.59981292,4443976.90322207
5568880.05695661,4443973.31640682 5568882.18662817,4443970.40211942
5568883.64377187,4443967.37574405 5568884.87673961,4443964.34936868
5568886.10970736,4443960.76255342 5568887.56685105,4443957.17573817
5568889.36025868,4443953.36474696 5568892.1624581,4443949.10540384
5568897.20641705,4443946.63946836 5568903.03499184,4443946.19111645
5568906.73389508,4443945.40650061 5568912.22620593,4443944.9581487
5568915.02840535,4443944.84606073 5568918.50313263,4443945.9669405
5568920.96906812,4443943.16474108 5568924.66797135,4443942.25964224
5568926.66625964,4443939.96060365 5568932.33257877,4443937.25533665
5568938.70927956,4443936.48240322 5568945.2792137,4443936.56460321
5568952.91296125,4443936.31699282 5568957.36994832,4443936.06938243
5568962.56976656,4443935.32655125 5568967.02675363,4443935.82177204
5568971.48374069,4443935.32655125 5568976.43594854,4443935.32655125
5568980.89293561,4443934.83133047 5568986.09275385,4443937.059824
5568991.78779288,4443938.79309675 5568998.96849427,4443941.02159028
5569006.14919565,4443945.97379813 5569013.82511782,4443948.94512284
5569017.7868841,4443950.4307852 5569021.74865038,4443953.6497203
5569027.19607902,4443959.67271679 5569038.17262972,4443960.39969075
5569046.5328303,4443960.98065467 5569053.23661382,4443967.3059434
5569056.58930345,4443978.33171517 5569059.37603698,4443981.23961102
5569062.88974446,4443985.36029284 5569069.85088576,4443988.24973144
5569075.08799322,4443993.11351909 5569081.06409354,4443995.83450776
5569084.11748884,4443999.4139601 5569089.42429412,4444005.71440111
5569094.14962487,4444011.77251747 5569099.72309192,4444012.62065376
5569102.63098778,4444013.7111147 5569110.50653904,4444016.49784823
5569117.65511635,4444018.58883671 5569120.41606122,4444019.67237619
5569122.76373008,4444020.75591566 5569127.27847789,4444020.75591566
5569129.08437702,4444020.75591566 5569129.98732658,4444020.39473584
5569131.07086605,4444020.21414593 5569132.33499544,4444019.8529661
5569133.59912482,4444019.8529661 5569135.40502395,4444019.49178628
5569137.93328272,4444019.8529661 5569139.01682219,4444019.49178628
5569140.46154149,4444019.49178628 5569141.72567088,4444018.76942663
5569154.72814457,4444018.04706698 5569155.26991431,4444017.86647706
5569156.53404369,4444018.04706698 5569157.43699325,4444017.00922906
5569159.80354124,4444015.90615885 5569160.61344085,4444012.20970392
5569163.13705151,4444010.58961281 5569164.72584753,4444003.85660609
5569166.44059579,4444002.56248399 5569177.48611518,4444001.53937172
5569180.09906842,4444001.42108901 5569181.39401199,4444005.94754285
5569196.62500423,4444007.93403189 5569204.39037047,4444015.87998803
5569224.07467091,4444018.95001654 5569235.99360513,4444018.58883671
5569238.16068408,4444018.4082468 5569240.32776303,4444019.31119636
5569243.21720162,4444018.22765689 5569250.2602082,4444019.13060645
5569264.16563146,4444021.47329239 5569276.02874963,4444022.9898534
5569280.07291232,4444029.393111 5569298.10313767,4444033.94279403
5569309.8986122,4444039.67202451 5569312.2577071,4444041.20366667
5569315.22260401,4444039.68445603 5569319.44263355,4444035.46442649
5569319.44263355,4444032.42600522 5569323.32506073,4444040.35966076
5569325.68827728,4444051.1629364 5569327.88269264,4444057.3652363
5569330.96195956,4444062.25193289 5569337.19671039,4444066.69264512
5569345.77561791,4444067.36784985 5569352.69646637,4444066.86144631
5569356.74769473,4444063.93700068 5569366.17987637,4444061.91491933
5569373.42566786,4444075.03662725 5569387.97288356,4444080.21180262
5569398.91680334,4444085.11873756 5569405.74330745,4444088.79066094
5569413.08715421,4444090.93261625 5569421.65497543,4444091.74341566
5569427.33682338,4444091.97929276 5569435.5768653,4444092.76857794
5569436.03667534,4444089.40264817 5569439.40260511,4444089.40264817
5569443.3805221,4444089.09665455 5569447.05244549,4444089.09665455
5569450.72436887,4444090.62662263 5569455.31427309,4444091.85059709
5569457.4562284,4444093.9925524 5569460.82215816,4444093.34543647
5569462.35242101,4444094.71859716 5569464.86988228,4444096.54947808
5569468.53164412,4444099.04994508 5569474.96690209,4444098.84276499
5569476.28178606,4444095.17631739 5569478.83034931,4444094.48973704
5569483.1786915,4444095.17631739 5569490.95993542,4444097.46491854
5569498.97003945,4444099.75351969 5569508.35330417,4444104.10186188
5569516.59226832,4444108.22134396 5569521.39833074,4444120
5569536.87270873,4444120.74278138 5569540,4444120.86460267
5569540.86460267,4444120 5569543.50016405,4444112.79854626
5569549.09040469,4444106.61932315 5569561.67771102,4444102.72870119
5569569.45895494,4444105.01730234 5569570.83211563,4444109.65017327
5569575.13961074,4444109.90554556 5569576.43318076,4444119.66434972
5569593.71812716,4444122.63953122 5569599.66849015,4444122.4106711
5569603.330252,4444121.26637053 5569608.13631442,4444128.13217398
5569606.76315373,4444132.02279594 5569609.96719534,4444134.76911733
5569615.68869822,4444136.59999825 5569619.80818029,4444138.76874909
5569623.11181097,4444141.40606067 5569623.46994214,4444145.06782251
5569624.61424272,4444151.70476585 5569626.90284387,4444168.34900086
5569641.35839105,4444172.63291147 5569646.86627612,4444178.25253922
5569657.34123919,4444179.16797968 5569660.08756058,4444179.85456003
5569663.29160219,4444181.0020941 5569680,4444181.36446472
5569681.36446472,4444184.20290222 5569697.16289925,4444184.88948256
5569704.71528305,4444188.78010452 5569717.76030962,4444194.66445175
5569736.52240534,4444194.97044537 5569741.41830318,4444195.5824326
5569748.76214994,4444194.66445175 5569755.49400947,4444194.05246452
5569761.91987539,4444186.70861776 5569780.58548591,4444185.17864969
5569789.76529436,4444188.23858584 5569795.27317943,4444197.70564902
5569801.98083203,4444201.59627098 5569806.32917422,4444202.73077306
5569817.26922694,4444202.96943167 5569819.6030609,4444202.96943167
5569821.20508171,4444202.51171144 5569822.5782424,4444202.28285132
5569823.03596263,4444202.28285132 5569823.26482274,4444202.51171144
5569823.49368286,4444201.82513109 5569824.40912332,4444200.3464089
5569839.88036038,4444200.16550564 5569840.01142094,4444200.09798137
5569840.12816731,4444199.99796286 5569840.23751309,4444180.33137306
5569859.90410289,4444180.2118842 5569859.97220988,4444180.14518246
5569860.01178097,4444180.06917011 5569860.06492408,4444179.87942298
5569860.21916735,4444179.08702793 5569860.39934529,4444172.30217622
5569866.97710476,4444166.12295311 5569869.03684579,4444163.37663173
5569870.6388666,4444161.31689069 5569872.01202729,4444160.63031035
5569872.92746775,4444159.71486989 5569873.15632787,4444158.57056931
5569872.92746775,4444158.11284908 5569873.6140481,4444158.16309926
5569873.74240785,4444157.88398896 5569874.30062844,4444156.05310804
5569874.30062844,4444150.75006167 5569874.04845325,4444149.85389349
5569873.99005502,4444149.60886197 5569873.98230464,4444143.90196727
5569875.5513752,4444143.67683356 5569875.56688282,4444142.70388832
5569875.57696955,4444138.65973928 5569876.81808971,4444125.61471272
5569878.64897063,4444118.06232891 5569880.70871167,4444111.73189955
5569882.84148409,4444111.48509222 5569882.9641711,4444111.36744814
5569883.22059277,4444110.74271688 5569883.58245109,4444100.48128134
5569885.8024468,4444100.19534508 5569887.48006077,4444090.78819338
5569894.84904089,4444090.94597382 5569899.43151016,4444091.70897192
5569903.8187492,4444093.2349681 5569909.92273394,4444094.76096429
5569915.45447012,4444095.39399824 5569917.56117446,4444095.47275663
5569918.97882546,4444095.63027341 5569920.7902684,4444095.7090318
5569921.89288584,4444095.47275663 5569923.31053684,4444094.57021477
5569925.37344533,4444092.07519199 5569931.88500111,4444091.23388231
5569932.52844193,4444088.28159585 5569934.18399075,4444084.6246488
5569935.21428617,4444076.74080013 5569936.86484201,4444074.80987278
5569939.10288977,4444073.58055043 5569941.56153447,4444072.35122808
5569943.09818741,4444070.81457514 5569944.94217093,4444069.58525279
5569947.09348505,4444068.35593044 5569948.63013798,4444068.35593044
5569950.47412151,4444067.12660809 5569952.31810504,4444066.20461633
5569953.54742739,4444065.58995515 5569954.77674974,4444064.3606328
5569956.00607209,4444064.05330221 5569956.92806385,4444063.43864104
5569958.1573862,4444062.51664928 5569959.07937797,4444061.59465751
5569960.30870032,4444060.05800457 5569961.53802267,4444059.13601281
5569963.0746756,4444056.67736811 5569965.53332031,4444055.17901996
5569968.29991864,4444054.51281487 5569970.39033283,4444059.28155296
5569974.20532329,4444060.80754914 5569977.82956423,4444057.94630629
5569980.30930804,4444049.93482632 5569980.88155661,4444047.83658156
5569985.26879564,4444041.73259681 5569994.99702133,4444036.77310921
5569998.43051275,4444027.04488352 5570002.05475369,4444027.17855454
5569998.56798812,4444029.90612637 5569991.18203086,4444033.14886827
5569986.98554135,4444034.92641641 5569985.53190307,4444037.31359863
5569982.37771868,4444040.23473588 5569979.62016662,4444044.19713933
5569974.4923504,4444046.52796488 5569971.92844228,4444049.90766194
5569967.26679117,4444051.77232239 5569965.518672,4444056.08434967
5569960.50739706,4444057.59938628 5569958.87581917,4444061.32870717
5569954.44725061,4444068.43772512 5569943.49237049,4444070.76855067
5569938.83071938,4444070.76855067 5569936.84951766,4444069.25351406
5569934.5186921,4444067.97156 5569934.28560955,4444065.29111061
5569935.10139849,4444062.61066122 5569938.36455427,4444061.678331
5569942.09387516,4444056.66705605 5569950.25176461,4444045.01292827
5569963.420929,4444040.58435971 5569967.73295628,4444039.30240566
5569969.48107545,4444037.20466266 5569973.79310273,4444035.9227086
5569976.12392829,4444035.10691966 5569978.33821256,4444032.65955282
5569980.66903812,4444029.74602088 5569983.58257007,4444027.53637575
5569986.02257583,4444026.65010079 5569987.30697113,4444023.7182476
5569992.46381152,4444022.83541643 5569993.75077775,4444022.63700293
5569994.65399146,4444022.28737909 5569995.23669785,4444020.18963609
5569999.78180769,4444019.02422332 5570001.41338558,4444018.44151693
5570002.92842219,4444017.5091867 5570003.86075241,4444014.24603092
5570008.75548608,4444013.43024198 5570010.38706397,4444012.4667115
5570011.55000281,4444009.66739538 5570017.46911495,4444008.88513214
5570019.59382492,4444008.45109302 5570020.48154363,4444006.11158593
5570025.47050766,4444005.2375344 5570026.66090003,4444003.11940166
5570027.25343226,4443998.70149502 5570027.24088654,4443999.80923929
5570029.42784906,4443999.20559381 5570030.62322923,4443998.33859375
5570030.70969447,4443998.05523511 5570031.29814693,4443993.69203867
5570040.62669229,4443993.41546228 5570041.19602301,4443993.39621118
5570041.85660031,4443992.84352568 5570049.48584609,4443992.82662841
5570050.14705684,4443992.96319039 5570050.89946425,4443993.37182221
5570052.88450723,4443993.67285901 5570053.58828658,4443994.20008555
5570055.38085683,4443994.41097617 5570056.85709115,4443994.62186679
5570058.86055201,4443994.43554353 5570061.02227976,4443994.05017569
5570067.20443181,4443993.99074446 5570067.85835632,4443993.93216666
5570068.22327107,4443993.84465421 5570068.88648839,4443993.88374963
5570076.15358262,4443991.93055371 5570080.8620213,4443991.11283912
5570082.66099341,4443989.15400257 5570084.13401422,4443988.96185324
5570084.51057864,4443988.62244964 5570085.14269175,4443986.42394362
5570088.43751638,4443985.77057071 5570089.37538077,4443984.98672833
5570090.55114435,4443984.61085119 5570091.15473505,4443984.45120713
5570091.39398805,4443984.18390464 5570092.05266404,4443983.46720946
5570093.38421472,4443981.11971658 5570097.73094829,4443980.32200723
5570099.39888601,4443979.52429789 5570101.50193792,4443979.27177126
5570102.19851222,4443978.86578144 5570103.31472103,4443978.50790645
5570104.26905433,4443977.97803884 5570105.76716863,4443977.29344249
5570107.65557235,4443976.98050525 5570108.49438822,4443976.76082119
5570108.86203212,4443973.56350181 5570116.34394429,4443973.36736222
5570116.7207613,4443973.21177446 5570117.14400811,4443969.63909593
5570124.38041917,4443969.53853341 5570124.8231723,4443969.18065318
5570125.4667531,4443965.36442508 5570131.94637296,4443965.00665168
5570132.59005042,4443964.65443206 5570133.13706309,4443960.77161383
5570139.78534734,4443960.426251 5570140.33350828,4443960.14036103
5570140.6451483,4443955.66102856 5570147.49438134,4443955.40511233
5570147.81688203,4443955.21069406 5570148.00235426,4443949.75078601
5570154.41225805,4443949.56391138 5570154.60088164,4443949.38125949
5570154.75285096,4443942.64136354 5570159.94433232,4443942.45998386
5570160.09717329,4443942.26487468 5570160.26220543,4443935.68684692
5570165.98853163,4443935.65703374 5570166.01378779,4443935.63217223
5570166.03071367,4443935.57308717 5570166.06828276,4443929.46027187
5570169.28351196,4443918.15906198 5570170.97869344,4443902.25022453
5570179.11327141,4443901.51397774 5570179.49420749,4443901.15189382
5570179.97226528,4443900.65570613 5570180.47814177,4443887.62538583
5570182.97037005,4443884.75742346 5570184.88234496,4443878.06551127
5570188.06896981,4443870.09894914 5570190.61826969,4443858.62709968
5570191.57425715,4443848.74856263 5570194.12355703,4443844.92461281
5570195.71686946,4443841.41932547 5570195.39820697,4443838.87002559
5570196.9915194,4443835.68340074 5570197.94750686,4443832.1781134
5570199.2221568,4443822.43418842 5570204.01629039,4443806.68511458
5570217.38591845,4443804.77313967 5570219.61655585,4443802.54250227
5570223.12184319,4443799.35587742 5570232.36305526,4443796.16925257
5570235.54968011,4443792.66396523 5570236.82433005,4443780.88458328
5570240.90347547,4443780.57307753 5570241.01443223,4443780.26133413
5570241.13554762,4443762.69387334 5570260.33876646,4443762.08127662
5570260.98248188,4443760.60755388 5570261.7337273,4443756.97376689
5570265.50395372,4443754.74312949 5570269.64656603,4443748.0512173
5570275.38249077,4443740.40331766 5570279.84376556,4443736.89803032
5570285.26102781,4443727.33815576 5570298.00752722,4443717.14095623
5570315.21530142,4443710.76770653 5570323.18186355,4443709.81171907
5570329.23645077,4443708.21840665 5570337.52167538,4443708.53706913
5570349.31218734,4443705.98776925 5570360.14671184,4443704.39445682
5570362.69601172,4443704.04332412 5570369.02350914,4443705.16548428
5570378.44965449,4443706.06321241 5570388.77352797,4443707.63423663
5570396.40421706,4443708.0831007 5570398.42410535,4443708.53196476
5570406.05479444,4443705.20235035 5570416.74586022,4443705.15359911
5570416.85112532,4443705.83878038 5570419.7451484,4443701.35013973
5570439.71959926,4443698.88138738 5570441.29062348,4443697.08593112
5570442.18835161,4443696.41263503 5570442.63721568,4443695.73933893
5570444.65710397,4443694.41254956 5570446.17532065,4443691.66655764
5570453.72679844,4443690.29356168 5570461.27827623,4443690.63681067
5570472.9487419,4443688.57731673 5570475.69473382,4443688.92056572
5570478.44072574,4443687.54756976 5570484.61920757,4443680.7937623
5570499.32451151,4443680.69405455 5570499.38501303,4443680.65541707
5570499.53886514,4443680.41508466 5570499.92132151,4443663.86338943
5570519.97385356,4443660.77414852 5570524.77933943,4443647.73068689
5570544.00128289,4443642.58195203 5570549.15001774,4443631.33183477
5570557.75936275,4443626.10721478 5570563.59864392,4443616.88729715
5570571.5892392,4443605.16781209 5570575.92343898,4443581.58854113
5570579.92700224,4443581.0542267 5570580.19334171,4443580.61702141
5570580.28671817,4443561.06834267 5570581.96958741,4443560.89117258
5570581.92931085,4443560.05279324 5570581.97760848,4443546.49784755
5570584.73162685,4443541.5032175 5570585.37571568,4443535.74250647
5570585.27097548,4443531.02919745 5570581.91928907,4443526.21114823
5570579.51026445,4443523.59264321 5570577.41546044,4443519.19355479
5570576.78701924,4443514.37550557 5570579.40552425,4443512.80440256
5570583.90935287,4443512.69966236 5570588.20370109,4443508.61479454
5570591.13642671,4443506.10102973 5570594.27863272,4443501.07350011
5570597.21135834,4443498.03603429 5570596.16395633,4443492.90376447
5570592.18382871,4443487.45727404 5570587.88948049,4443484.52454843
5570585.16623528,4443483.37240622 5570583.49039207,4443481.17286201
5570581.91928907,4443479.81123941 5570581.50032826,4443477.8211756
5570580.97662726,4443476.66903339 5570580.13870566,4443475.28849525
5570579.87282633,4443474.67584049 5570579.97694234,4443461.44968127
5570580.36409335,4443460.87808025 5570580.49667352,4443459.42593087
5570582.13095069,4443454.44409395 5570584.0293148,4443448.97224271
5570587.42563626,4443444.25512957 5570589.68985057,4443441.23617717
5570593.46354108,4443438.78327833 5570594.97301729,4443435.19827235
5570596.10512444,4443432.36800446 5570597.42591612,4443430.66984373
5570598.55802327,4443428.59854976 5570599.43562091,4443425.42103015
5570601.09977197,4443424.06588534 5570601.19960663,4443422.44960679
5570601.57438368,4443417.83929599 5570603.27513641,4443415.95245074
5570603.65250546,4443413.49955191 5570604.02987451,4443411.9900757
5570606.8601424,4443410.95375689 5570610.66412546,4443409.34968482
5570613.33757892,4443406.32953993 5570614.59620794,4443403.8766411
5570613.08673174,4443401.98979585 5570609.87909481,4443399.34821249
5570612.89804721,4443394.44241482 5570616.10568415,4443390.29135526
5570618.74726751,4443388.02714095 5570623.65306517,4443385.57424212
5570628.74754736,4443380.10239088 5570630.25702357,4443374.06448606
5570628.93623189,4443369.53605745 5570630.06833904,4443362.93209905
5570631.9551843,4443359.34709307 5570633.84202955,4443358.96972402
5570636.67229744,4443358.96972402 5570638.37045817,4443358.59235496
5570639.50256532,4443356.32814066 5570640.823357,4443353.6865573
5570641.38941058,4443350.10155131 5570642.52151773,4443347.45996796
5570644.59704751,4443341.98811671 5570647.42731539,4443336.09705988
5570651.56796347,4443327.5420088 5570658.51894248,4443323.73869454
5570659.29339492,4443319.1260836 5570663.41179755,4443318.45226702
5570666.00461218,4443318.45226702 5570674.55966327,4443315.77881355
5570681.77798762,4443313.03829928 5570687.28846296,4443311.8513133
5570689.23851137,4443308.29035534 5570692.71468461,4443307.10336936
5570695.25822601,4443306.67944579 5570697.63219798,4443311.23394266
5570701.56154326,4443309.36252524 5570705.8390688,4443308.02579851
5570709.849249,4443302.91047005 5570718.67893985,4443302.78062582
5570719.53250712,4443302.01317737 5570720.15439273,4443296.6689884
5570735.64153574,4443290.95526265 5570741.93495539,4443290.77102204
5570742.35227448,4443287.56907776 5570749.738768,4443285.68781942
5570753.67870212,4443283.10171374 5570757.07800889,4443281.66577531
5570758.35439861,4443275.60292413 5570763.93860363,4443273.3299829
5570768.76952172,4443271.61420626 5570770.79919838,4443268.37665837
5570774.79634011,4443268.10166745 5570775.89904279,4443267.15106464
5570777.0872963,4443266.36926859 5570777.03195306,4443266.34124795
5570777.04181761,4443265.60633507 5570777.68142306,4443262.63570129
5570779.22615262,4443257.05090979 5570776.96847095,4443253.53236823
5570778.10854264,4443252.77681127 5570778.13095495,4443251.87115992
5570778.69845604,4443249.50386221 5570778.48129871,4443243.69318113
5570774.46881882,4443241.61904783 5570777.50024441,4443238.90671968
5570779.73392642,4443237.63032996 5570782.12715715,4443241.60361414
5570783.38503991,4443244.90809568 5570785.67977589,4443241.41492777
5570788.17489583,4443238.42078384 5570795.16123166,4443224.05530874
5570801.67083429,4443222.98432368 5570802.02123126,4443222.88774325
5570802.30682797,4443222.22766926 5570803.73933156,4443216.88946168
5570807.53265752,4443205.59953274 5570819.98324807,4443204.05480317
5570821.17150158,4443203.10420036 5570822.12210439,4443201.06901202
5570822.98565991,4443199.2250285 5570822.98565991,4443198.30303674
5570822.98565991,4443194.92240027 5570823.2929905,4443191.69696665
5570822.83505649,4443190.00511087 5570824.52231285,4443188.77578852
5570828.51761049,4443184.78049088 5570835.27888342,4443183.26036672
5570838.40117749,4443182.19093856 5570840.06473241,4443181.02021088
5570841.7134564,4443179.18157669 5570843.57029764,4443177.74641699
5570844.45394386,4443176.0120203 5570844.93657181,4443173.87316398
5570845.29304786,4443177.67557522 5570847.90720559,4443180.78519324
5570852.48939633,4443183.55116853 5570855.56270221,4443185.08782147
5570857.71401632,4443187.23913558 5570859.25066926,4443188.63065129
5570862.25565994,4443191.48237969 5570864.50107852,4443193.36052157
5570866.80043642,4443195.22973086 5570869.08524806,4443197.28175816
5570872.50405328,4443197.87588491 5570874.99938565,4443198.10716781
5570878.8812043,4443198.03451855 5570879.21113948,4443197.07371438
5570883.52978568,4443196.69230733 5570886.5530768,4443198.4461536
5570889.47384623,4443198.91769791 5570893.0570339,4443201.87807059
5570897.9500081,4443201.76249354 5570898.66629898,4443204.8765559
5570901.17364421,4443210.43299313 5570911.39930815,4443216.20853583
5570919.58132698,4443218.13371673 5570924.39427923,4443219.99717876
5570926.22472778,4443220.1221805 5570927.03723908,4443219.74717528
5570928.03725298,4443218.43465703 5570929.16226863,4443210.24704317
5570936.97487728,4443207.62200666 5570936.91237641,4443200.80708862
5570935.46406941,4443202.68443799 5570942.03744768,4443206.58524977
5570953.02723478,4443210.16570036 5570959.47204584,4443215.41702789
5570965.08141843,4443219.59422025 5570968.06512726,4443226.63577308
5570973.07775809,4443231.4097072 5570980.35800762,4443232.96123579
5570986.92216704,4443233.4386292 5570990.14457257,4443234.15471932
5570992.29284292,4443235.22885449 5570992.05414622,4443236.42233802
5570993.96371986,4443238.80930508 5570995.15720339,4443240.83822708
5570997.90221551,4443244.89607109 5571001.2439694,4443249.07326344
5571003.98898152,4443250.38609533 5571008.04682552,4443250.14739862
5571011.03053435,4443253.84719756 5571014.13359152,4443253.36980415
5571018.90752564,4443255.99546792 5571025.71038177,4443259.57591851
5571030.36496753,4443265.30463945 5571028.81343894,4443270.19792193
5571025.47168506,4443273.3009791 5571022.48797624,4443275.0912044
5571021.41384106,4443279.1490484 5571020.93644765,4443289.89040017
5571018.43013223,4443315.07290266 5571017.47534541,4443320.32423019
5571017.2366487,4443332.61711055 5571017.71404211,4443350.51936351
5571019.62361576,4443365.79595269 5571022.01058282,4443376.29860776
5571023.44276306,4443384.18056946 5571024.98498132,4443396.2129501
5571025.94757177,4443401.50719757 5571026.428867,4443408.24533073
5571028.3540479,4443420.19572104 5571032.27779012,4443437.40623395
5571035.96575717,4443442.01619276 5571038.42440187,4443456.37485326
5571041.34901898,4443458.30003416 5571041.83031421,4443460.70651029
5571043.27419988,4443467.83196213 5571049.48830303,4443470.29060683
5571053.48360067,4443473.05658212 5571055.94224537,4443475.62666227
5571059.63823754,4443477.07054795 5571063.96989457,4443479.0931667
5571068.5333963,4443480.42688109 5571072.0010537,4443481.76059547
5571074.66848247,4443482.5608241 5571076.5356826,4443484.16128136
5571078.40288274,4443483.62779561 5571080.53682575,4443486.29522437
5571086.93865479,4443488.16242451 5571091.74002657,4443488.96265314
5571095.74116972,4443488.96265314 5571102.14299876,4443487.62893876
5571105.34391328,4443486.29522437 5571111.74574231,4443485.76173862
5571117.08059985,4443482.82756698 5571122.94894313,4443480.42688109
5571129.35077217,4443473.70148137 5571141.45842585,4443471.77630047
5571153.00951126,4443471.77630047 5571164.07930144,4443471.29500525
5571177.07427252,4443467.92593867 5571186.2188818,4443464.07557687
5571196.80737676,4443462.63169119 5571201.62032901,4443460.88180197
5571219.11819803,4443460.5668088 5571220,4443457.81873894
5571231.94192821,4443456.95350795 5571238.98209446,4443456.15327932
5571244.58369486,4443450.81842178 5571262.98895335,4443448.19283443
5571278.14626984,4443449.63672011 5571283.92181254,4443447.71153921
5571294.02901227,4443448.19283443 5571298.3606693,4443449.59070051
5571306.500031,4443455.39781705 5571317.33998187,4443461.20493359
5571331.27706155,4443466.23776792 5571338.6327425,4443478.23914209
5571351.40839888,4443481.33627091 5571354.8926688,4443487.91766965
5571359.15122093,4443497.59619721 5571369.60403069,4443502.62903154
5571376.18542943,4443506.50044257 5571379.28255825,4443518.94323255
5571400.39525707,4443520.1715697 5571401.96199206,4443521.77202696
5571404.62942083,4443526.16266093 5571414.83411383,4443529.72890871
5571419.1580918,4443532.05175533 5571430.77232487,4443530.79167212
5571448.10637651,4443531.94095608 5571461.32314216,4443535.81978948
5571472.60049111,4443540.34848273 5571480.09495518,4443546.81904384
5571484.68696629,4443553.28960495 5571490.32261628,4443553.7070605
5571494.49717184,4443550.36741606 5571495.7495385,4443520.72807163
5571507.22956628,4443552.87214939 5571497.83681628,4443559.3427105
5571506.60338294,4443570.82273827 5571511.19539405,4443579.17184938
5571513.28267183,4443593.36533826 5571513.28267183,4443602.13190493
5571512.03030516,4443614.39759695 5571508.88550637,4443624.54626866
5571507.99749759,4443630.43008191 5571510.71891224,4443639.33471775
5571519.35188656,4443639.49034776 5571519.54392151,4443639.97321475
5571519.78694909,4443655.98965262 5571533.55571954,4443664.27272117
5571540.09498418,4443675.17149557 5571547.94210175,4443684.32646607
5571555.35326835,4443700.45665218 5571565.81609177,4443710.04757366
5571570.17560153,4443716.5868383 5571574.09916032,4443726.61371075
5571580.20247398,4443741.00009296 5571590.22934643,4443745.35960272
5571595.02480717,4443747.5393576 5571599.38431693,4443751.57348208
5571602.50303457,4443754.46643375 5571604.51512667,4443759.40485251
5571607.70120329,4443763.38744828 5571612.79892588,4443767.68865171
5571615.66639483,4443772.46776664 5571618.53386379,4443780.59226201
5571623.95019404,4443787.12371908 5571631.11886643,4443798.43429107
5571637.80962732,4443801.62036769 5571640.67709628,4443815.6391048
5571652.62488359,4443821.69265038 5571657.24469469,4443832.6846147
5571665.0505824,4443838.26024878 5571672.37855862,4443842.56145222
5571677.47628121,4443846.06742731 5571682.57964586,4443860
5571696.36603815,4443861.6047313 5571700,4443880
5571718.3952687,4443881.15007122 5571720,4443891.45196595
5571731.45196595,4443895.88962113 5571739.23026219,4443901.28491793
5571747.32320738,4443906.12368073 5571751.87117022,4443913.92956845
5571758.24332346,4443929.06343238 5571761.74800774,4443937.02862392
5571765.25269201,4443939.38920153 5571766.88115826,4443946.26824611
5571770.50971843,4443951.52527253 5571778.31560615,4443957.59832821
5571796.21808457,4443957.93553426 5571800.26455717,4443958.27274031
5571804.64823581,4443955.17534486 5571819.18695983,4443958.12795785
5571838.87104639,4443964.36125193 5571853.3060432,4443969.61034168
5571860.52354161,4443980 5571876.43084708,4443982.01989867
5571880.08177098,4443981.70869932 5571880.72256255,4443981.84089412
5571883.76705094,4443979.99424664 5571892.64842762,4443976.14466094
5571895.69386921,4443974.79583674 5571901.7635781,4443982.55157588
5571911.20534749,4443993.34216947 5571916.60064428,4444000
5571918.61776101,4444015.96535725 5571920.63562648,4444018.27357766
5571922.64487691,4444022.0968696 5571927.90190333,4444022.83898177
5571930.28482563,4444026.3661246 5571938.93181974,4444030.63101002
5571946.80545437,4444035.79699906 5571961.03710015,4444036.91212587
5571964.70108826,4444040.57611398 5571968.84298786,4444054.90805011
5571980.26840152,4444063.99377712 5571986.84432075,4444079.74290555
5571997.20668337,4444087.92800278 5572001.75395961,4444091.86897551
5572005.9980841,4444100.05407274 5572016.00209182,4444104.29819723
5572016.91154706,4444105.6702438 5572017.82290416,4444105.83094424
5572017.74715514,4444106.91917056 5572020.1578473,4444109.14862521
5572025.09664429,4444111.27068745 5572028.43131353,4444113.9990532
5572031.46283102,4444117.94002593 5572033.28174151,4444123.73271369
5572039.73319259,4444126.44087882 5572045.62743433,4444128.42204254
5572050.33600878,4444130.29989921 5572053.98125996,4444131.18359646
5572055.63819231,4444132.28821803 5572058.73113271,4444132.95099097
5572060.94037585,4444134.27653686 5572062.92869467,4444135.38115843
5572066.35302154,4444135.27069627 5572072.0970537,4444139.73805294
5572077.72395725,4444143.10162111 5572081.17971787,4444144.9205316
5572084.51438711,4444146.43629035 5572087.24275285,4444149.7550466
5572090.24736686,4444154.24257172 5572096.28826607,4444156.6589314
5572100.08540271,4444158.90269397 5572103.53734512,4444160.11087381
5572107.679676,4444161.66424789 5572111.30421552,4444163.21762197
5572116.48212913,4444164.59839893 5572119.76147441,4444165.9791759
5572123.55861106,4444167.7051471 5572131.67067571,4444172.71046358
5572137.71157492,4444177.19798871 5572139.95533748,4444178.57876567
5572140.9909202,4444179.78694551 5572142.54429428,4444180.47733399
5572145.65104245,4444181.85811095 5572154.6260927,4444183.58408216
5572159.28621494,4444185.48265048 5572164.63672567,4444186.92006087
5572173.58750445,4444189.61689087 5572178.98116446,4444194.67344713
5572184.71192821,4444199.05579588 5572192.12821072,4444201.41552214
5572197.52187073,4444201.75262589 5572200.89290823,4444203.43814464
5572205.27525699,4444205.12366339 5572210.33181324,4444204.78655964
5572216.39968075,4444204.78655964 5572223.47885951,4444204.78655964
5572228.19831201,4444206.47207839 5572240.67115078,4444204.78655964
5572255.16661205,4444206.47207839 5572271.68469582,4444211.1915309
5572283.14622333,4444216.58519091 5572299.6643071,4444217.052394
5572301.61430584,4444225.20999984 5572299.38000035,4444238.71000002
5572295.68000169,4444246.1900013 5572293.62999934,4444244.01999988
5572288.78000048,4444241.62000026 5572281.27999936,4444239.12000141
5572270.28999795,4444239.34999962 5572262.16000174,4444239.66000178
5572253.69999894,4444242.6100017 5572249.81000176,4444243.77000183
5572248.28999986,4444242.65000139 5572248.33999947,4444241.74999924
5572248.37999916,4444234.11999914 5572247.78999918,4444226.84000089
5572245.30000025,4444219.73000131 5572239.14999778,4444214.47000106
5572229.54999928,4444212.95999909 5572224.06000083,4444211.6799999
5572215.21000106,4444211.60000052 5572207.43000213,4444213.25000141
5572199.35000095,4444217.45000075 5572190.72999939,4444222.03000171
5572183.0599996,4444225.3699986 5572174.94999865,4444229.47999864
5572171.37999898,4444225.60000139 5572170.12999956,4444219.65000193
5572168.77000099,4444208.62000083 5572166.2399978,4444203.61999856
5572155.36000011,4444202.06000155 5572140.00000068,4444201.25999863
5572134.57000176,4444199.85000045 5572123.86999809,4444199.20000093
5572116.23999798,4444199.36999961 5572109.78999785,4444198.92999846
5572107.22999947,4444197.23999788 5572105.39999998,4444193.38000047
5572103.52000089,4444187.11999885 5572100.67000019,4444182.28999983
5572093.29999806,4444181.03000049 5572087.68000061,4444180.05999889
5572081.09000157,4444179.97999951 5572074.43999841,4444180.57999941
5572069.57999963,4444182.32999952 5572061.08000172,4444187.09999901
5572055.06999815,4444190.18999784 5572051.37999942,4444193.11999791
5572047.88999912,4444195.20000003 5572045.27000121,4444192.43999863
5572041.65000193,4444190.61999907 5572039.58999966,4444187.80999806
5572038.22000117,4444184.53000071 5572037.53000196,4444177.20999819
5572036.18999866,4444172.86000001 5572034.5600022,4444164.59000031
5572030.99999787,4444160.37000112 5572021.64000208,4444160.29000175
5572012.10999846,4444164.09999955 5572004.73000098,4444168.14000014
5571999.78999824,4444169.17000127 5571999.08999912,4444167.79999821
5571997.86999946,4444163.72999785 5571995.44999999,4444161.90999829
5571994.88999977,4444157.67999918 5571995.35000077,4444152.61000203
5571997.77000024,4444144.87999812 5571996.44000144,4444136.99000004
5571991.4999987,4444133.84000168 5571983.64000039,4444132.36999939
5571978.89000075,4444128.66000081 5571971.17000134,4444126.63999823
5571963.93999812,4444123.99000055 5571955.70999811,4444123.31000127
5571947.40999864,4444122.91999972 5571941.45999919,4444128.54000175
5571936.42000181,4444132.10000149 5571933.22999918,4444135.66000124
5571925.31000133,4444155.34999901 5571940.16000016,4444185.15000046
5571980.34999853,4444233.99000015 5572048.88000057,4444235.78962146
5572047.70845302,4444231.7205238 5572041.49013081,4444224.96823484
5572031.14151403,4444222.98658482 5572028.27913067,4444221.46146171
5572025.93454849,4444219.24346811 5572022.55436394,4444215.69225431
5572016.86865114,4444209.51096067 5572007.39066755,4444207.65923818
5572004.94338312,4444206.05337633 5572002.19047709,4444203.30047029
5571998.06111804,4444199.85933775 5571992.55530597,4444193.2064815
5571982.69072601,4444183.1124927 5571967.09092514,4444165.17587045
5571939.73054775,4444142.41491532 5571924.47036193,4444129.49616134
5571913.88512728,4444117.55383302 5571904.33126463,4444111.82151543
5571899.5543333,4444109.06619393 5571881.77977772,4444106.06265933
5571860.91738875,4444104.92618678 5571853.61149378,4444082.35908899
5571815.94554638,4444065.23082411 5571787.29020278,4444043.32770937
5571757.75658419,4444026.74169515 5571735.4487572,4444006.2445684
5571717.05204274,4443999.21905147 5571712.2717941,4443980.09805691
5571699.08989634,4443963.43961468 5571687.79112683,4443923.39757214
5571653.39956965,4443900.81844596 5571634.03810996,4443881.97633326
5571617.89565061,4443860.45880658 5571599.29835969,4443840.40139777
5571579.77888905,4443820 5571560,4443799.36440044
5571540.12516129,4443760.6328524 5571502.5463379,4443755.94510552
5571498.08913594,4443727.74177589 5571474.72724982,4443704.6104347
5571460.2029193,4443664.95670695 5571442.29726317,4443634.75532127
5571404.56474315,4443587.92938682 5571346.12366246,4443589.9372906
5571339.14380646,4443587.73815789 5571337.32713161,4443585.25218177
5571335.22361336,4443582.57497673 5571332.92886618,4443578.36794023
5571329.48674541,4443574.73459053 5571326.1402391,4443571.86615655
5571322.98496173,4443569.85825277 5571320.78582901,4443567.75473452
5571317.91739504,4443565.74683074 5571315.04896106,4443562.4959389
5571290.09358547,4443561.82663764 5571278.04616277,4443564.40822821
5571262.8434627,4443565.97850745 5571258.17271422,4443566.96322872
5571253.74146852,4443567.46789112 5571251.0828834,4443568.13719238
5571248.50129282,4443571.00562636 5571243.14688274,4443574.55378849
5571239.18867194,4443576.40657695 5571235.75904224,4443577.58920788
5571230.83141335,4443577.11615551 5571226.92873127,4443575.53931426
5571219.91178773,4443578.33820747 5571214.31400131,4443578.57473366
5571204.4193225,4443578.73241778 5571194.918854,4443578.89010191
5571189.67585686,4443579.008365 5571181.04265104,4443579.32373325
5571170.00476233,4443579.44199634 5571161.0956093,4443579.52083841
5571154.35461297,4443579.70029604 5571148.44875226,4443580.31495721
5571143.53146286,4443581.23694898 5571139.22883463,4443582.15894074
5571134.61887581,4443583.0809325 5571129.70158641,4443584.92491603
5571124.47696642,4443586.76889955 5571116.17904055,4443588.61288308
5571108.80310645,4443589.84220543 5571100.19784999,4443589.22754426
5571090.67060178,4443591.37885837 5571081.75801473,4443590.45686661
5571078.37737827,4443588.61288308 5571071.00144416,4443586.46156897
5571063.62551006,4443584.31025485 5571058.09355948,4443583.0809325
5571053.79093126,4443581.23694898 5571049.79563362,4443580.31495721
5571045.49300539,4443579.08563486 5571042.41969951,4443577.24165134
5571039.03906305,4443576.40337966 5571037.14800368,4443575.58150545
5571035.75081753,4443573.60900735 5571034.10706911,4443569.99276083
5571030.73738486,4443567.19838852 5571028.60051191,4443565.63682752
5571027.20332576,4443565.30807784 5571023.91582892,4443565.70263338
5571019.90349718,4443566.12995205 5571016.60114847,4443567.19838852
5571013.5602139,4443568.43119983 5571010.68365416,4443569.25307404
5571008.87553091,4443570.73244762 5571007.14959507,4443573.60900735
5571004.1086605,4443576.32119223 5571002.30053724,4443578.78681486
5571001.56085045,4443583.14274817 5571000.90335108,4443588.97805505
5571000.08147687,4443593.08742609 5570995.56116873,4443594.81336193
5570993.17773352,4443596.21054808 5570989.72586185,4443597.19679713
5570988.08211343,4443598.01867134 5570982.16461913,4443596.45711034
5570979.20587198,4443593.41617577 5570974.68556383,4443590.7861783
5570969.42556889,4443590.86836573 5570966.13807206,4443592.01898962
5570962.02870101,4443594.97773677 5570956.19339413,4443596.95023487
5570952.33058535,4443598.59398329 5570949.70058789,4443599.49804492
5570947.56371494,4443605.90866374 5570943.12559422,4443601.96366754
5570934.57810245,4443597.27898455 5570924.5512371,4443593.74492546
5570914.93530886,4443586.01930789 5570895.53907754,4443579.85525133
5570901.94969637,4443578.86900228 5570902.27844605,4443576.40337965
5570901.86750895,4443574.34869413 5570900.47032279,4443572.95150798
5570898.90876179,4443570.89682246 5570895.95001464,4443568.75994951
5570891.75845618,4443565.06151558 5570884.03283862,4443563.66432942
5570885.43002477,4443560.95214453 5570886.82721093,4443558.48652191
5570887.15596061,4443555.28121249 5570886.41627382,4443551.82934082
5570883.9506512,4443549.69246788 5570881.07409147,4443546.81590815
5570875.15659717,4443544.59684778 5570871.70472549,4443542.7065371
5570868.49941608,4443539.91216479 5570867.18441734,4443537.85747927
5570865.37629408,4443535.39185665 5570861.92442241,4443534.32342018
5570860.36286141,4443533.99467049 5570858.39036331,4443534.4056076
5570855.92474069,4443538.26841638 5570853.87005516,4443542.13122516
5570854.60974195,4443545.8296591 5570856.58224005,4443548.95278109
5570858.55473815,4443550.92527919 5570856.99317716,4443545.50090941
5570848.1169357,4443539.82997737 5570837.67913326,4443534.48779502
5570826.74820628,4443531.52904787 5570824.69352076,4443529.72092461
5570823.13195976,4443529.06342524 5570820.83071198,4443529.63873719
5570818.36508935,4443529.47436234 5570817.13227804,4443527.91280135
5570811.8722831,4443525.85811583 5570808.50259885,4443524.04999257
5570807.43416238,4443522.32405673 5570808.66697369,4443517.72156116
5570814.83103026,4443511.47531718 5570821.89914845,4443505.55782287
5570828.72070438,4443502.84563798 5570832.91226284,4443509.50281907
5570835.54226031,4443511.31094233 5570835.87101,4443514.84500143
5570834.06288674,4443519.20093474 5570832.50132574,4443522.81718125
5570834.7203861,4443524.87186677 5570838.6653823,4443525.94030325
5570841.87069172,4443527.83061393 5570843.02131561,4443530.29623655
5570843.84318982,4443531.44686044 5570845.65131308,4443532.18654723
5570847.78818602,4443527.50186424 5570850.00724638,4443525.20061646
5570852.14411933,4443520.43374605 5570849.43193444,4443516.16000016
5570845.89787534,4443513.61219012 5570843.92537724,4443510.32469328
5570842.52819108,4443504.90032351 5570841.13100493,4443501.94157636
5570841.13100493,4443500.21564052 5570841.7885043,4443497.25689337
5570843.67881498,4443492.90096006 5570848.36349797,4443490.27096259
5570852.14411933,4443488.38065191 5570856.08911553,4443487.31221544
5570860.11629915,4443487.31221544 5570862.00660983,4443490.27096259
5570868.9925406,4443490.76408712 5570871.45816323,4443492.57221038
5570884.44377572,4443492.81877264 5570885.5122122,4443493.96939653
5570886.41627382,4443496.02408205 5570888.14220966,4443494.21595879
5570888.71752161,4443492.07908585 5570889.53939582,4443490.35315001
5570890.93658197,4443488.46283933 5570892.66251781,4443487.06565318
5570894.55282849,4443486.49034123 5570896.52532659,4443486.57252865
5570899.23751148,4443486.7369035 5570901.45657184,4443485.66846702
5570899.56626116,4443485.14868919 5570898.14651338,4443484.68221797
5570896.85407627,4443482.79190729 5570894.22407881,4443482.38097019
5570893.07345491,4443481.55909598 5570891.59408134,4443480.49065951
5570890.93658197,4443478.76472367 5570892.25158071,4443475.64160168
5570890.85439455,4443472.84722937 5570888.71752161,4443470.95691869
5570886.41627382,4443468.65567091 5570884.52596315,4443473.42254132
5570874.74566006,4443473.50472874 5570873.34847391,4443470.79254385
5570874.99222232,4443467.01192249 5570878.11534432,4443463.56005081
5570881.89596568,4443456.90286972 5570889.12845871,4443451.13194871
5570898.13299798,4443445.50118843 5570904.63002908,4443442.25267288
5570909.17795085,4443437.70475111 5570917.19095587,4443433.15682934
5570926.0702317,4443425.94427553 5570937.73940912,4443421.46005015
5570945.960489,4443419.49820154 5570950.81839983,4443418.42385588
5570954.08814751,4443418.33043452 5570957.12434178,4443419.12451609
5570959.27303311,4443421.22649674 5570959.97369333,4443433.09100974
5570962.30922738,4443439.95747986 5570964.13094395,4443446.12328977
5570965.15857893,4443462.75229224 5570967.91450911,4443473.00528674
5570969.60034006,4443479.6615588 5570970.06320044,4443487.18197846
5570971.74478497,4443494.9826622 5570974.31387242,4443496.89780013
5570974.36058311,4443500.40110121 5570972.77241995,4443502.08268573
5570972.25860246,4443509.18270925 5570975.57506081,4443514.27417349
5570978.42441236,4443514.64785894 5570979.17178326,4443514.69456962
5570981.60073868,4443515.4886512 5570984.12311546,4443516.51628619
5570986.03825338,4443518.43142411 5570988.14023403,4443520.39327272
5570989.40142242,4443524.59723402 5570991.73695648,4443529.45514485
5570995.19354688,4443534.87358386 5570998.74355864,4443539.82491606
5571001.49948883,4443548.32626002 5571004.95607923,4443550.5123867
5571007.57756776,4443556.31378648 5571010.23438619,4443557.32497253
5571011.42584475,4443558.5091885 5571012.71005229,4443560.42432642
5571016.30677474,4443562.75986048 5571018.3620447,4443563.60065274
5571019.24954764,4443563.6940741 5571019.99691854,4443562.80657116
5571020.8377108,4443561.68551481 5571021.5850817,4443560.51774778
5571022.37916328,4443559.95721961 5571022.61271668,4443559.53682348
5571022.37916328,4443557.85523896 5571024.01403712,4443551.63298448
5571019.74553616,4443549.12860052 5571017.50022641,4443544.72433907
5571014.99584244,4443532.89328381 5571005.66917114,4443517.43518971
5570993.75175781,4443513.63543473 5570991.76552226,4443510.09475396
5570990.64286738,4443504.59137744 5570988.34379977,4443501.4589472
5570987.27490274,4443498.2636987 5570985.89317366,4443495.24116633
5570984.16601231,4443493.85943725 5570982.69792516,4443491.35505329
5570981.40255414,4443489.36881773 5570980.88440574,4443486.34628537
5570980.7116896,4443484.87819822 5570980.79804767,4443483.49646914
5570980.53897347,4443482.89196266 5570980.36625733,4443482.11474005
5570980.1935412,4443480.99208518 5570979.84810893,4443479.26492382
5570979.32996052,4443475.98331725 5570978.03458951,4443471.0609074
5570975.35748941,4443468.21109117 5570973.88940226,4443466.57028788
5570973.54396999,4443462.68417484 5570973.19853772,4443459.83435861
5570972.68038931,4443457.93448112 5570972.42131511,4443455.77552943
5570972.16224091,4443454.30744228 5570971.98952477,4443447.83058721
5570971.29866023,4443444.98077098 5570971.1259441,4443443.47053844
5570971.05374483,4443438.24484171 5570970.52143762,4443435.22230934
5570970.26236342,4443431.94070277 5570970.17600535,4443430.12718335
5570969.83057308,4443428.9181704 5570969.65785695,4443427.96823166
5570969.48514081,4443425.63656384 5570969.31242468,4443422.09588306
5570969.05335047,4443419.5914991 5570968.7079182,4443418.12341195
5570968.62156014,4443416.56896674 5570968.36248593,4443413.97822471
5570968.10341173,4443411.81927302 5570967.93069559,4443410.09211167
5570967.67162139,4443403.8743308 5570967.58526332,4443401.62902104
5570967.41254719,4443399.81550162 5570967.49890526,4443397.742908
5570967.41254719,4443395.0658079 5570967.41254719,4443391.35241099
5570967.23983105,4443386.34364307 5570966.98075685,4443384.01197525
5570966.72168265,4443379.17592346 5570966.54896651,4443374.08079747
5570966.20353424,4443371.83548771 5570965.94446004,4443370.45375863
5570965.94446004,4443368.64023921 5570965.94446004,4443366.56764559
5570965.68538584,4443364.84048424 5570965.85810197,4443363.54511322
5570965.85810197,4443361.29980346 5570965.68538584,4443358.19091303
5570965.68538584,4443355.68652907 5570965.68538584,4443349.12331593
5570965.59902777,4443346.18714163 5570965.33995357,4443343.27047531
5570965.30437338,4443339.67510707 5570964.97239142,4443337.37861873
5570964.9945213,4443335.37247884 5570964.97239142,4443332.62892502
5570964.73544709,4443330.72904753 5570964.56273096,4443328.31102164
5570964.21729869,4443323.47496985 5570963.35371801,4443322.09324077
5570963.00828574,4443321.14330202 5570962.74921154,4443320.71151169
5570962.66285347,4443317.68897932 5570962.14470506,4443313.02564367
5570961.79927279,4443311.12576618 5570961.88563086,4443308.18959188
5570960.84933405,4443306.20335633 5570960.24482758,4443304.90798531
5570959.72667917,4443303.69897237 5570959.3812469,4443301.97181101
5570958.86309849,4443300.50372386 5570958.43130816,4443296.44489469
5570957.04957907,4443294.285943 5570956.01328226,4443292.21334937
5570954.63155318,4443289.10445894 5570953.16346603,4443286.85914918
5570951.60902082,4443283.92297488 5570949.01827879,4443279.69142957
5570945.65031415,4443275.45988426 5570941.67784304,4443272.78278416
5570938.39623647,4443272.35099382 5570936.15092671,4443272.52370996
5570931.05580072,4443274.33722938 5570922.33363589,4443274.50994551
5570916.89307763,4443274.42358745 5570914.30233561,4443274.07815517
5570911.62523551,4443273.81908097 5570907.22097406,4443273.81908097
5570903.24850295,4443273.81908097 5570900.74411899,4443274.25087131
5570898.8442415,4443274.42358745 5570896.08078334,4443274.68266165
5570893.83547358,4443274.94173585 5570891.84923803,4443275.37352619
5570888.22219919,4443277.27340368 5570879.24096015,4443279.0869231
5570874.5776245,4443281.50494899 5570869.91428885,4443282.80032
5570867.40990489,4443288.32723633 5570862.14206277,4443289.44989121
5570861.01940789,4443291.26341063 5570855.83792383,4443292.29970744
5570852.90174953,4443295.41950244 5570847.26477634,4443299.29471092
5570841.58884267,4443299.64014319 5570840.9843362,4443300.24464966
5570839.94803939,4443301.88545294 5570837.01186509,4443310.38454401
5570817.7065206,4443314.85190803 5570809.09088999,4443318.52152848
5570803.82578239,4443328.41354881 5570795.05060306,4443334.1742115
5570789.05113607,4443334.88106038 5570788.28987786,4443336.48523223
5570788.48702912,4443354.04572578 5570794.00554742,4443356.63646781
5570794.52369582,4443360.52258085 5570794.43733776,4443362.50881641
5570794.09190549,4443367.55253634 5570792.97959281,4443376.9306137
5570790.63758278,4443393.78383364 5570779.92539849,4443398.60648867
5570775.35220481,4443414.69659175 5570755.83264859,4443416.36006113
5570744.47895641,4443419.52084655 5570740.41040143,4443420.58528699
5570739.36747791,4443422.51918571 5570738.37504089,4443434.48281611
5570733.47339164,4443447.49121539 5570733.16979632,4443455.8618875
5570732.43224521,4443460.17979088 5570731.22323226,4443474.16140386
5570719.94360041,4443485.30203196 5570706.63820571,4443496.32461548
5570699.81384615,4443498.35005677 5570698.49352464,4443499.55906971
5570700.22068599,4443500.42265039 5570701.86148927,4443500.59536652
5570704.10679903,4443502.06345367 5570706.09303459,4443503.87697309
5570705.92031845,4443504.82691184 5570705.48852811,4443507.41765386
5570701.17062473,4443509.76089254 5570697.02261533,4443512.41659156
5570693.86436941,4443516.31267035 5570689.54326384,4443520.35042474
5570684.6554559,4443521.1296405 5570683.73456455,4443521.69634287
5570683.23869997,4443522.26304524 5570682.6719976,4443523.18393659
5570681.53859287,4443524.38817912 5570680.05099915,4443525.94661064
5570678.35089204,4443528.21342012 5570676.01324476,4443533.38457924
5570670.06286988,4443535.58055092 5570665.45841313,4443537.06814464
5570661.13730756,4443538.05987379 5570660.287254,4443548.47302983
5570658.79966028,4443553.71502675 5570658.02044452,4443556.65697072
5570657.98425178,4443560.58629299 5570657.52457995,4443564.76572296
5570654.6910681,4443568.73263955 5570654.05352794,4443571.35363801
5570653.98269014,4443579.35830898 5570655.54112166,4443586.01706183
5570657.17039097,4443591.68618896 5570659.79311786,4443597.21813954
5570662.25176256,4443605.82339599 5570665.63239902,4443613.1993301
5570669.93502725,4443614.84804489 5570671.12543682,4443616.76066538
5570671.69213919,4443621.29428434 5570670.84208564,4443624.12779619
5570670.34622106,4443626.11125448 5570670.06286988,4443627.17382143
5570669.85035649,4443628.30722617 5570675.58821798,4443628.73225294
5570677.35916289,4443628.87392854 5570678.56340543,4443629.15727972
5570678.9884322,4443629.5823065 5570671.90465258,4443629.29895531
5570669.49616751,4443630.36152226 5570668.78778955,4443630.99906242
5570668.22108718,4443634.11592546 5570664.25417059,4443638.40043828
5570660.10044845,4443642.70306651 5570658.56379551,4443653.56591972
5570654.18420877,4443659.40115255 5570654.52745776,4443664.8931364
5570655.55720473,4443676.81676174 5570659.48578727,4443680.5047288
5570661.02244021,4443682.65604291 5570661.94443197,4443685.4220182
5570662.55909315,4443687.89081875 5570664.48167848,4443692.35305562
5570665.16817646,4443698.18828846 5570666.88442141,4443702.99377432
5570663.45193151,4443712.52394042 5570653.21649211,4443714.10216538
5570651.2166037,4443715.44140756 5570650.94101475,4443717.06698292
5570650.06522089,4443721.87246879 5570645.946233,4443733.13983674
5570637.6845439,4443736.63217537 5570631.18652642,4443740.75116325
5570622.26205267,4443742.8106572 5570617.11331782,4443744.18365316
5570610.93483599,4443747.27289407 5570603.38335821,4443756.19736782
5570586.90740667,4443756.33109453 5570583.48680848,4443757.30799701
5570580.4746925,4443757.87785679 5570579.49779003,4443758.28489949
5570578.68370463,4443758.44771657 5570577.38116799,4443759.01757635
5570573.47355808,4443760.3163557 5570564.5962223,4443767.5245845
5570551.89600966,4443771.98682137 5570545.71752784,4443777.13555622
5570539.53904601,4443784.34378502 5570529.58482529,4443787.77627492
5570523.40634347,4443789.83576886 5570517.91435962,4443794.64125473
5570509.33313487,4443796.70074867 5570502.81140405,4443797.73049564
5570492.85718333,4443797.73049564 5570488.39494646,4443798.10499809
5570486.43039611,4443797.97675201 5570483.09599809,4443797.91262897
5570480.01809223,4443797.97675201 5570478.73563145,4443797.84850593
5570476.81194028,4443797.84850593 5570474.43938785,4443797.84850593
5570471.8744663,4443797.14315251 5570468.21945308,4443796.6301682
5570464.43619379,4443795.28358438 5570459.88345804,4443792.24511274
5570455.20540948,4443789.83576886 5570448.57806359,4443787.77627492
5570441.71308378,4443785.96101584 5570435.90425471,4443784.23288701
5570427.68820276,4443783.17015941 5570421.84320101,4443781.87970448
5570414.55592609,4443780.892886 5570407.26865118,4443780.36152221
5570403.16955904,4443780.892886 5570399.6018307,4443780.99333779
5570396.97434925,4443780.88052751 5570394.37971282,4443780.42928639
5570391.10821471,4443780.74428863 5570389.11763069,4443781.27243157
5570387.68409985,4443781.9556136 5570386.69728137,4443782.14810322
5570385.63971065,4443782.46676571 5570384.04639823,4443784.6974031
5570381.17843586,4443786.29071553 5570377.35448604,4443789.47734038
5570371.6185613,4443796.48791505 5570368.43193645,4443802.08886009
5570367.8692971,4443808.91575198 5570368.75059894,4443816.56365162
5570367.15728651,4443820.70626393 5570364.28932414,4443824.21155127
5570360.78403681,4443827.24555245 5570357.15232054,4443830.90346346
5570350.90549976,4443836.72161594 5570340.90764027,4443838.97782153
5570338.08738328,4443841.00840656 5570335.94398796,4443845.06957663
5570331.20595622,4443850.66053754 5570326.68715089,4443854.54564012
5570323.42204692,4443858.83243075 5570319.58649741,4443860.29896438
5570318.11996378,4443869.0981662 5570309.65919281,4443874.51305962
5570304.24429938,4443877.44612689 5570301.87528351,4443880.1535736
5570299.1678368,4443884.21474367 5570292.39922002,4443886.01970815
5570289.91739387,4443891.32179129 5570285.17936212,4443893.57799688
5570283.03596681,4443902.37719869 5570279.99008926,4443918.05782757
5570282.35910513,4443929.33885553 5570284.38969016,4443932.61035364
5570285.2921724,4443939.71740126 5570284.38969016,4443946.1475872
5570278.41074534,4443946.93725916 5570277.05702199,4443948.96784419
5570275.02643695,4443951.56248062 5570273.1086622,4443952.01372174
5570269.72435381,4443954.04430677 5570267.46814822,4443956.07489181
5570265.77599402,4443958.10547684 5570264.98632206,4443960.36168243
5570264.87351178,4443963.63318054 5570264.30946039,4443968.48402257
5570264.53508095,4443972.7708132 5570265.77599402,4443975.92950103
5570266.79128654,4443976.94479354 5570266.90409682,4443978.74975802
5570265.66318374,4443989.01549346 5570266.4528557,4443991.0460785
5570266.56566598,4443993.75352521 5570266.90409682,4443996.91221304
5570267.0169071,4444002.32710646 5570267.35533794,4444009.99820548
5570267.12971738,4444015.07466806 5570266.79128654,4444024.09949043
5570265.77599402,4444028.95033246 5570265.21194262,4444035.04208756
5570264.30946039,4444042.0363249 5570263.74540899,4444044.40534077
5570263.97102955,4444053.6557837 5570265.8888043,4444056.25042014
5570266.56566598,4444060.19877992 5570264.98632206,4444064.71119111
5570262.84292675,4444069.33641257 5570261.15077256,4444073.17196208
5570260.02266976,4444077.23313215 5570258.55613612,4444079.48933774
5570257.42803333,4444080.61744054 5570256.52555109,4444082.19678445
5570255.62306885,4444084.90423117 5570254.15653522,4444087.95010872
5570252.35157074,4444090.54474515 5570250.43379599,4444093.25219186
5570248.96726235,4444095.73401801 5570247.27510816,4444097.08774137
5570246.03419508,4444098.10303389 5570244.90609229,4444099.1183264
5570243.89079977,4444099.6823778 5570243.21393809,4444100.58486004
5570242.31145586,4444101.93858339 5570239.94243998,4444105.2100815
5570235.76845964,4444107.69190766 5570233.28663348,4444113.10680108
5570229.22546342,4444119.42417674 5570224.26181111,4444122.35724401
5570221.77998496,4444123.82377764 5570220.20064104,4444124.95188044
5570219.29815881,4444126.3056038 5570217.94443545,4444129.23867107
5570214.78574762,4444132.51016918 5570212.19111119,4444136.68414952
5570209.59647476,4444140.74531959 5570208.46837196,4444142.55028407
5570209.25804392,4444147.17550553 5570205.76092525,4444153.60569147
5570201.36132434,4444157.70547128 5570198.22716617,4444159.14951477
5570197.14413355,4444160.26149797 5570196.0592412,4444166.46606335
5570191.88526085,4444171.09128482 5570187.82409079,4444175.82931656
5570183.76292072,4444179.48142029 5570180.55506065,4444179.82617544
5570180.25224168,4444180.56734831 5570179.92737121,4444181.80826138
5570178.68645814,4444183.27479502 5570177.55835534,4444185.19256977
5570176.20463198,4444189.93060152 5570171.01535912,4444192.18680711
5570168.75915353,4444196.47359774 5570164.81079374,4444199.40666501
5570162.89301898,4444200.87319864 5570161.31367507,4444203.80626592
5570158.15498724,4444205.83685095 5570155.10910969,4444208.54429766
5570151.27356018,4444209.33396962 5570150.25826766,4444210.23645185
5570148.79173403,4444213.16951913 5570142.69997893,4444214.74886304
5570139.20286026,4444215.98977612 5570134.01358739,4444217.00506863
5570131.08052012,4444218.24598171 5570127.24497062,4444219.03565367
5570124.5375239,4444220.27656674 5570120.81478467,4444221.51747982
5570118.4457688,4444222.1943415 5570116.86642489,4444223.99930597
5570113.14368566,4444225.57864989 5570109.08251559,4444227.04518352
5570105.24696608,4444228.850148 5570101.41141658,4444230.54230219
5570098.13991847,4444232.91131807 5570093.74031756,4444233.70099002
5570092.3865942,4444234.82909282 5570089.00228581,4444236.74686757
5570084.26425407,4444239.08412066 5570076.0565572,4444239.22869373
5570074.22413918,4444239.9055554 5570073.5472775,4444241.93614044
5570073.09603638,4444244.19234603 5570073.09603638,4444244.41796659
5570069.82453827,4444243.17705351 5570067.11709156,4444242.95143295
5570060.68690562,4444242.61300211 5570058.31788975,4444241.71051988
5570053.24142716,4444241.5977096 5570051.21084213,4444241.0336582
5570049.06744682,4444240.58241708 5570047.60091318,4444239.9055554
5570046.02156927,4444239.34150401 5570044.55503563,4444238.32621149
5570041.62196836,4444237.08529841 5570037.33517773,4444236.0700059
5570034.51492074,4444235.39314422 5570032.59714599,4444235.52683081
5570030.8223277,4444234.9419031 5570030.00250956,4444233.36255919
5570024.58761613,4444232.4821201 5570022.27420316,4444231.71912201
5570019.60370983,4444230.20387135 5570015.22436292,4444229.43012773
5570012.54597747,4444228.39890688 5570009.47103866,4444227.7220452
5570006.53797139,4444227.49642464 5570003.60490412,4444227.38361436
5570001.01026769,4444227.38361436 5569999.09249293,4444227.74746756
5569997.18364184,4444227.64958886 5569996.4284778,4444227.60456171
5569996.30285764,4444227.83485548 5569995.59537426,4444228.39890688
5569991.42139392,4444228.2860966 5569989.61642944,4444228.39890688
5569988.82675749,4444229.18857884 5569988.03708553,4444229.07576856
5569986.79617245,4444226.70675268 5569986.57055189,4444225.12740877
5569986.23212105,4444224.45054709 5569985.89369021,4444223.43525457
5569981.94533043,4444222.64558262 5569980.81722763,4444222.64558262
5569977.6585398,4444223.20963402 5569973.93580057,4444223.54806485
5569973.14612861,4444225.12740877 5569973.71018001,4444230.54230219
5569974.95109309,4444233.2497489 5569974.61266225,4444234.72261578
5569971.6025619,4444235.28033394 5569970.10025106,4444236.29562645
5569967.95685575,4444237.42372925 5569965.13659876,4444240.13117596
5569958.93203338,4444240.24398624 5569955.99896611,4444235.05471338
5569951.82498576,4444234.03942086 5569947.65100541,4444234.9419031
5569941.44644003,4444236.0700059 5569938.2877522,4444238.10059093
5569937.27245969,4444239.45431429 5569935.58030549,4444240.69522736
5569932.7600485,4444242.27457128 5569929.82698123,4444243.96672547
5569927.57077564,4444245.32044883 5569925.42738032,4444245.99731051
5569923.62241585,4444247.02227924 5569921.70820932,4444248.08084311
5569919.06179964,4444248.91887284 5569916.79764914,4444249.94803216
5569915.62146706,4444250.97719148 5569913.2691029,4444254.35871496
5569914.15123946,4444255.38787428 5569912.5339891,4444254.2116922
5569911.21078426,4444249.35994112 5569909.15246562,4444248.3307818
5569904.59476007,4444249.21291836 5569899.30194071,4444254.2116922
5569894.89125791,4444255.24085152 5569892.68591651,4444253.91764668
5569890.03950684,4444248.62482732 5569886.06989232,4444245.68437212
5569884.89371024,4444242.89093968 5569881.65920952,4444241.42071208
5569878.4247088,4444241.12666656 5569876.07234464,4444242.15582588
5569871.66166185,4444245.24330384 5569865.48670593,4444249.0658956
5569861.66411417,4444254.2116922 5569857.10640861,4444260.82771639
5569851.51954374,4444263.62114883 5569849.31420234,4444266.56160403
5569844.90351954,4444267.88480887 5569843.13924642,4444271.41335511
5569844.46245126,4444275.08892411 5569846.07970162,4444274.50083307
5569844.60947402,4444283.32219866 5569844.3154285,4444287.14479042
5569843.72733746,4444297.28936085 5569835.64108566,4444305.22858989
5569826.08460627,4444308.31606785 5569813.73469444,4444310.08034097
5569802.1198964,4444312.28568237 5569791.97532597,4444315.66720584
5569783.59502865,4444316.5493424 5569778.89030034,4444314.78506928
5569769.33382094,4444315.0791148 5569760.21840983,4444315.8142286
5569754.77856771,4444316.69636516 5569743.31079243,4444316.84338792
5569738.90010964,4444314.93209204 5569734.04835856,4444313.6088872
5569730.81385784,4444310.81545477 5569728.46149368,4444308.46309061
5569725.37401573,4444307.28690853 5569721.40440121,4444306.84584025
5569716.99371841,4444306.69881749 5569713.90624045,4444308.46309061
5569706.99617074,4444309.49224993 5569698.02778238,4444307.58095405
5569689.20641679,4444305.37561265 5569685.82489331,4444303.61133953
5569677.73864151,4444302.72920297 5569672.44582215,4444296.34435869
5569665.80906346,4444292.68259684 5569660.54528081,4444281.98169703
5569642.03901698,4444278.7644931 5569643.33531569,4444276.55386657
5569638.3975611,4444278.82118816 5569637.22954695,4444276.26510619
5569632.45563146,4444272.98111741 5569625.82423233,4444272.58953719
5569629.51517626,4444271.56037787 5569636.27822321,4444271.05732941
5569639.49686854,4444270.16414212 5569642.03901698,4444265.67946747
5569647.89302125,4444264.44353524 5569643.28954898,4444263.91183109
5569640.87100283,4444261.71321622 5569632.55749036,4444261.37978857
5569631.23996915,4444260.53367087 5569628.33899418,4444259.94557983
5569625.54556174,4444259.85813493 5569623.3507906,4444259.65201478
5569622.80113689,4444259.51460135 5569621.9079496,4444259.51460135
5569620.87734888,4444259.92684164 5569618.88485416,4444262.05674979
5569617.23589301,4444263.70571094 5569616.48011915,4444267.07233996
5569617.02977286,4444268.79000782 5569617.37330643,4444270.0954354
5569617.64813329,4444270.5763824 5569617.99166687,4444271.12603612
5569617.78554672,4444272.01922341 5569617.16718629,4444272.9124107
5569615.65563857,4444272.70629056 5569615.10598485,4444269.87899202
5569612.19831638,4444268.18394237 5569609.30432918,4444265.90596336
5569604.47455257,4444262.93342274 5569598.5138912,4444260.64218071
5569593.71812716,4444259.26902002 5569591.20066589,4444258.12471944
5569589.36978497,4444257.10410567 5569587.43405449,4444256.44262288
5569586.27645962,4444255.73979742 5569585.11886474,4444255.16099998
5569583.96126986,4444253.50729301 5569580.98459731,4444252.22567011
5569578.38000883,4444249.88575529 5569573.3495769,4444247.63663326
5569569.49133387,4444244.85083276 5569561.44885091,4444242.30342828
5569553.90514567,4444241.18717608 5569550.55638905,4444238.90046976
5569546.11522319,4444236.61186861 5569543.36890181,4444232.91864123
5569539.93132177,4444231.57694607 5569538.10511915,4444230.4326455
5569536.96081858,4444229.97492527 5569535.35879777,4444229.0594848
5569534.67221743,4444228.37290446 5569533.75677697,4444226.99974377
5569532.15475616,4444226.77088365 5569531.01045558,4444226.99974377
5569529.86615501,4444226.77088365 5569528.49299431,4444226.99974377
5569527.57755385,4444225.39772296 5569523.6869319,4444223.10912181
5569516.36340821,4444219.67622008 5569507.66672383,4444215.32787789
5569498.2834591,4444212.58155651 5569491.87537588,4444210.9795357
5569486.38273311,4444209.43600224 5569482.2169485,4444207.7409526
5569476.92508619,4444205.75650423 5569470.88905575,4444203.48265715
5569464.93571066,4444198.56287891 5569455.13749686,4444196.12366113
5569449.18415176,4444194.09787009 5569444.96719899,4444192.56819115
5569442.15589714,4444191.78268033 5569440.99830226,4444190.83984556
5569438.32210891,4444190.17707639 5569437.06830291,4444190.08775397
5569436.77317861,4444189.46749058 5569434.17676101,4444188.39258104
5569428.51281463,4444188.32179993 5569427.92889925,4444188.42962849
5569427.49758504,4444188.32179993 5569426.904528,4444188.26788566
5569426.47321378,4444188.21397138 5569425.2870997,4444188.10614283
5569424.31664272,4444187.9444 5569423.02270009,4444187.83657144
5569421.94441456,4444187.2435144 5569421.29744324,4444186.43480026
5569420.97395758,4444185.43919558 5569419.78443957,4444184.43997203
5569418.81738652,4444183.03820084 5569417.90084382,4444181.90600103
5569417.14604395,4444181.15120116 5569415.95992987,4444180.6919314
5569408.30510102,4444180.6440076 5569407.57625987,4444180.63202664
5569407.41252022,4444180.63202664 5569407.35261546,4444180.56795984
5569406.26078521,4444180.48481493 5569405.20068762,4444180.42245625
5569403.99508645,4444180.30796369 5569402.51880148,4444180.12618939
5569401.46451058,4444180.01712482 5569400.88283284,4444179.90806024
5569400.44657454,4444179.65357623 5569399.8648968,4444179.3263825
5569399.0650899,4444178.8901242 5569398.26528301,4444178.41751104
5569397.32005669,4444178.23573674 5569396.84744352,4444177.87218815
5569396.08399149,4444177.54499443 5569395.32053946,4444177.25415556
5569394.77521658,4444176.96331669 5569394.2298937,4444176.09080008
5569392.48486048,4444175.58183206 5569390.55805297,4444175.14557375
5569388.70395518,4444174.27305714 5569385.28659846,4444173.67533692
5569382.48024079,4444172.07331611 5569376.98759802,4444169.21937344
5569366.80447527,4444168.50027549 5569363.20898552,4444167.24185408
5569357.99552539,4444164.90478575 5569352.06296731,4444164.90478575
5569346.6697327,4444164.54523677 5569342.71469398,4444159.48034435
5569334.50060192,4444155.7362869 5569328.15296051,4444153.41410031
5569323.88467485,4444150.54948506 5569317.98693758,4444150.16327779
5569316.46761884,4444149.62395433 5569314.84964845,4444148.69591049
5569312.2577071,4444145.83129525 5569300.96775291,4444145.49428169
5569299.78820546,4444145.66278847 5569298.94567156,4444143.64070713
5569291.36286651,4444143.8092139 5569290.85734617,4444143.64070713
5569289.50929194,4444142.12414612 5569282.600514,4444141.95563934
5569281.75798011,4444141.61862578 5569281.25245977,4444140.27057155
5569272.15309371,4444140.10206477 5569271.14205304,4444140.12584773
5569268.31919944,4444139.04230826 5569262.72091216,4444138.50053852
5569260.01206347,4444138.50053852 5569258.02557444,4444138.13935869
5569253.51082663,4444137.23640913 5569250.44079812,4444137.23640913
5569249.35725864,4444136.87522931 5569246.64840996,4444136.51404948
5569244.12015118,4444135.97227975 5569241.23071259,4444135.2499201
5569237.98009416,4444135.2499201 5569235.81301522,4444135.06933018
5569233.64593627,4444134.34697053 5569230.21472793,4444134.52756045
5569227.86705907,4444133.98579071 5569226.06115995,4444132.90225124
5569221.72700205,4444132.54107141 5569218.29579372,4444131.27694202
5569213.96163582,4444131.09635211 5569210.53042749,4444130.55458238
5569208.54393845,4444129.10986308 5569201.68152178,4444127.66514378
5569198.79208318,4444127.66514378 5569197.16677397,4444127.48455387
5569196.26382441,4444127.30396395 5569195.72205467,4444127.12337404
5569194.45792529,4444126.76219422 5569192.11025643,4444126.40101439
5569190.48494722,4444125.31747492 5569186.87314897,4444124.59511527
5569183.80312046,4444124.05334553 5569180.55250204,4444122.96980606
5569176.57952396,4444121.88626658 5569171.70359633,4444120.6221372
5569168.09179808,4444119.89977755 5569162.31292089,4444117.7326986
5569159.42348229,4444118.09387842 5569154.90873448,4444117.01033895
5569150.7551665,4444115.38502974 5569142.98980027,4444113.94031044
5569137.21092307,4444112.13441131 5569132.69617526,4444109.42556263
5569128.72319719,4444105.81376438 5569125.65316868,4444104.36904508
5569119.69370157,4444102.92432578 5569114.63718403,4444100.75724684
5569109.58066648,4444102.20196614 5569106.51063797,4444104.549635
5569104.88532876,4444102.92432578 5569099.46763139,4444101.11842666
5569092.96639454,4444100.39606701 5569088.45164673,4444098.95134771
5569082.85335945,4444099.13193762 5569079.78333094,4444100.75724684
5569077.25507217,4444101.29901657 5569075.99094278,4444100.03488719
5569071.65678489,4444097.68721833 5569066.96144716,4444096.24249903
5569064.43318839,4444094.07542008 5569062.08551953,4444092.81129069
5569059.01549102,4444092.08893104 5569054.86192304,4444090.29837353
5569048.60363282,4444089.57927558 5569044.6485941,4444088.50062866
5569039.79468295,4444085.80401135 5569032.78347795,4444083.94017292
5569029.02407617,4444083.10739404 5569027.21046884,4444082.56807058
5569026.3115964,4444082.01464716 5569024.97033773,4444081.10255601
5569022.94346851,4444079.27837371 5569019.5991343,4444077.7582218
5569014.43061779,4444074.00851374 5569012.40374857,4444073.09642259
5569012.20106165,4444071.47492722 5569010.27553589,4444070.46149261
5569006.52582784,4444070.36014915 5568998.62103788,4444070.25880569
5568994.36461252,4444069.75208838 5568991.12162177,4444069.54940146
5568990.10818716,4444069.14402762 5568987.37191372,4444068.13059301
5568980.78458875,4444067.31984532 5568975.51472878,4444067.42118878
5568972.8797988,4444067.42118878 5568966.79919114,4444067.6238757
5568964.26560462,4444067.6238757 5568962.64410924,4444067.79811127
5568958.36038989,4444067.55050088 5568955.88428596,4444067.55050088
5568953.40818204,4444069.53138402 5568943.50376633,4444071.01704638
5568938.30394809,4444071.26465677 5568933.35174024,4444071.26465677
5568926.41864925,4444072.25509834 5568917.50467511,4444073.4931503
5568913.79051922,4444075.22642305 5568910.32397373,4444075.72164384
5568905.61937627,4444077.20730619 5568901.1623892,4444080.42624129
5568898.93389567,4444085.13083875 5568896.45779174,4444094.78764406
5568892.24841507,4444101.47312466 5568891.75319429,4444111.49523023
5568888.37298987,4444118.51520087 5568885.84580044,4444125.81597033
5568881.63381805,4444140.13671042 5568879.10662863,4444145.19108928
5568879.10662863,4444150.52626696 5568879.9490251,4444155.58064582
5568877.14103685,4444160.07342703 5568871.80585917,4444162.88141528
5568865.62828501,4444164.28540941 5568860.57390615,4444165.97020236
5568856.64272259,4444162.0390188 5568851.58834374,4444156.73085389
5568846.13514751,4444154.98371891 5568841.77185539,4444146.39595483
5568837.05700452,4444141.00755384 5568829.64795316,4444138.81851594
5568819.37631377,4444137.63980322 5568813.98791278,4444136.79786556
5568810.11499957,4444135.78754038 5568804.22143599,4444134.94560273
5568800.85368537,4444134.44044013 5568798.49625994,4444134.10366507
5568796.98077216,4444134.05083761 5568796.30171918,4444134.10806736
5568795.50050269,4444134.17960455 5568794.77082339,4444134.09375992
5568793.86945484,4444133.45700154 5568787.08482174,4444133.58898231
5568786.1958597,4444133.44866994 5568785.2136731,4444133.37119283
5568778.77102797,4444133.14639624 5568777.6625274,4444133.30835757
5568775.39180709,4444132.90525638 5568771.10467448,4444133.30835757
5568768.37618851,4444133.86960706 5568763.18463076,4444134.57116891
5568759.67682147,4444134.29054417 5568756.30932455,4444134.57116891
5568752.0999534,4444135.41304314 5568746.76808328,4444133.44866994
5568744.2424606,4444129.37961117 5568745.92620905,4444126.85398848
5568747.32933277,4444123.06555444 5568751.25807917,4444120.25930701
5568754.34495135,4444117.45305958 5568759.11557199,4444115.06774926
5568763.04431839,4444113.80493792 5568765.28931634,4444111.13900286
5568770.62118646,4444110.02545632 5568772.4601735,4444108.05213068
5568775.11118235,4444105.52650799 5568776.09336895,4444103.70244716
5568775.95305658,4444095.43502691 5568773.28175304,4444094.68166539
5568773.1496299,4444086.45528297 5568770.80814002,4444078.13901001
5568768.83343827,4444069.6517234 5568767.75321013,4444069.02629152
5568767.54215421,4444060.06529959 5568766.97306479,4444051.78686967
5568766.13119057,4444042.94719026 5568765.14900396,4444041.40375417
5568764.72806685,4444034.10751085 5568763.88619262,4444032.14313765
5568763.60556788,4444026.67095515 5568763.04431839,4444025.22197772
5568762.8464596,4444024.00502009 5568762.76369365,4444022.92906264
5568762.56377144,4444021.01306511 5568762.21826369,4444019.6310341
5568761.27596982,4444018.37464228 5568759.86252902,4444017.80926596
5568758.19780985,4444017.36808342 5568749.35223583,4444017.27090727
5568748.62341469,4444017.07655497 5568740.4606179,4444016.93079074
5568739.78038484,4444016.9957064 5568737.86065391,4444016.8414836
5568731.57607473,4444016.8029279 5568730.80496072,4444017.12514304
5568728.79947964,4444017.85396419 5568727.53618966,4444018.43207199
5568725.9848225,4444019.22130588 5568723.95536392,4444020.68702595
5568722.71513924,4444021.25076445 5568720.91117607,4444021.58900754
5568716.96500662,4444021.81450294 5568713.13158488,4444022.03355035
5568709.51886859,4444022.61755395 5568707.76685779,4444023.37675863
5568705.95644662,4444023.49355935 5568704.3796369,4444023.37675863
5568702.68602646,4444023.14315719 5568701.28441781,4444022.73435467
5568699.88280917,4444022.38395251 5568698.18919873,4444021.91674963
5568695.7363836,4444021.68314818 5568694.74357748,4444021.56634746
5568693.86757208,4444021.33274602 5568693.10836739,4444020.57354134
5568689.13714291,4444020.28153954 5568687.50193282,4444019.8326098
5568686.31524948,4444019.65820321 5568685.2688099,4444019.9198131
5568684.48398022,4444019.57099991 5568682.65271096,4444022.74200435
5568677.96901151,4444024.4507263 5568673.12763263,4444027.29859623
5568668.28625376,4444032.13997511 5568666.00795782,4444032.99433608
5568663.72966188,4444034.41827105 5568661.16657894,4444035.55741902
5568657.74913503,4444035.84220601 5568653.47733014,4444036.98135398
5568646.35765532,4444037.52251611 5568638.71549455,4444036.40411707
5568637.31210974,4444033.07038212 5568630.65638973,4444029.00731819
5568625.56820486,4444026.15944826 5568621.01161298,4444022.45721736
5568616.4550211,4444019.03977344 5568612.18321621,4444014.19839457
5568607.91141132,4444006.48734699 5568600.38126639,4444002.79525878
5568598.53522228,4444001.68763231 5568595.95076054,4443999.10317056
5568594.47392525,4443991.98500914 5568589.96983078,4443984.58054733
5568587.69153484,4443977.74565951 5568583.41972995,4443972.61949364
5568580.85664701,4443967.77811476 5568578.86313806,4443961.51280093
5568574.87612017,4443951.54525618 5568569.7499543,4443948.37909491
5568567.24829601,4443945.4083757 5568563.18310129,4443944.36601808
5568560.62932512,4443943.63636774 5568559.74332115,4443937.95551871
5568556.82471981,4443929.92936504 5568551.76928535,4443926.38534913
5568549.26762706,4443923.57098355 5568546.66173301,4443921.7989756
5568545.46302175,4443920.23543917 5568542.75289194,4443918.41131333
5568540.98088398,4443917.42107359 5568540.25123365,4443913.46011464
5568536.49874622,4443911.94869609 5568534.93520979,4443911.42751728
5568533.63226276,4443911.01057423 5568529.6713038,4443909.90208961
5568527.00894608,4443908.00415853 5568523.68756668,4443905.98760675
5568522.02687698,4443900.0565721 5568520.48480797,4443893.41381331
5568517.40066996,4443888.31312351 5568513.3675664,4443885.94070965
5568507.67377314,4443884.04277857 5568504.47101443,4443877.21100105
5568500.51012591,4443873.24829552 5568498.77722118,4443869.80829543
5568500.20066949,4443860.2000193 5568493.32066931,4443857.11588129
5568492.96480723,4443849.88001902 5568489.99928991,4443843.29704801
5568490.35703767,4443836.9503635 5568486.6779105,4443834.10346687
5568481.93308279,4443832.91725995 5568482.17032418,4443833.15450133
5568483.59377249,4443832.244797 5568484.88480404,4443829.71450124
5568487.62687605,4443827.22346669 5568487.03377258,4443822.83450105
5568483.59377249,4443818.8013975 5568480.27239309,4443816.90346641
5568478.4930827,4443815.00553532 5568475.52756538,4443813.58208701
5568472.79928944,4443811.44691454 5568470.1896342,4443810.02346622
5568467.57997895,4443809.31174207 5568464.61446163,4443807.88829375
5568463.30963401,4443805.51587989 5568461.05584085,4443799.82208664
5568454.05721997,4443796.38208655 5568448.6006681,4443799.70346595
5568443.85584038,4443796.97519001 5568441.12756445,4443791.28139675
5568437.09446089,4443783.33381033 5568433.6544608,4443777.57787783
5568433.12967038,4443765.65932709 5568433.17997802,4443760.5586373
5568431.51928832,4443754.39036127 5568425.70687437,4443749.17105079
5568416.33583964,4443747.74760247 5568408.26963252,4443744.54484376
5568399.37308056,4443739.18016043 5568390.30144712,4443733.64202811
5568385.13252362,4443730.42898131 5568379.56342485,4443723.07009256
5568370.24267628,4443715.21546768 5568363.77416167,4443712.21222876
5568361.69499626,4443708.95863591 5568358.68618291,4443694.8712598
5568346.31328149,4443694.4845348 5568346.00337305,4443693.07647872
5568345.1333235,4443692.34919188 5568344.40603666,4443691.72740652
5568344.08055335,4443690.90976999 5568343.57942128,4443690.46138867
5568343.42116905,4443689.44004449 5568342.70903402,4443687.25315952
5568341.76444039,4443684.65552705 5568340.70177257,4443681.70367198
5568339.75717894,4443678.0215087 5568337.90010325,4443669.70484706
5568330.96955189,4443663.69836921 5568326.81122107,4443662.08124056
5568323.57696376,4443659.97609087 5568319.39106569,4443657.89412942
5568314.81075049,4443656.22856025 5568310.64682757,4443652.27283348
5568304.19274705,4443652.37846865 5568294.93068479,4443647.69251827
5568288.36983997,4443643.52859536 5568288.36983997,4443641.4466339
5568289.61901685,4443636.65812255 5568288.78623227,4443632.91059193
5568286.49607466,4443629.99584589 5568281.91575946,4443623.54176537
5568272.33873675,4443619.79894224 5568270.01380847,4443616.85039913
5568268.13001704,4443611.0352169 5568265.75480176,4443606.53049827
5568264.77195406,4443603.99147504 5568264.19862623,4443601.86197168
5568264.03481828,4443599.79899736 5568263.8105774,4443598.09438882
5568262.47864275,4443597.11154112 5568261.659603,4443596.22396586
5568261.3632842,4443595.71917355 5568261.0043712,4443595.2277497
5568260.43104338,4443594.81146848 5568259.75950212,4443593.9952438
5568259.04641031,4443593.50776622 5568258.7110599,4443593.01551162
5568258.69082264,4443591.43121804 5568258.49855749,4443590.45605943
5568259.04936238,4443589.7867578 5568259.139631,4443589.92901545
5568259.63483309,4443589.62377262 5568260.55381542,4443589.23036074
5568260.60936267,4443589.14775725 5568260.62418881,4443587.53642063
5568260.58378922,4443587.4810493 5568260.52604445,4443587.47605574
5568260.52221744,4443587.4709611 5568260.51376993,4443586.75046193
5568259.31839407,4443586.74536702 5568259.30994591,4443586.49895985
5568258.70649166,4443585.95787711 5568257.62422686,4443585.94796708
5568257.61483102,4443585.94211366 5568257.60222934,4443585.92622069
5568257.54791388,4443586.0729647 5568255.43095424,4443586.07965436
5568255.38340305,4443586.24005372 5568253.15580536,4443586.24492976
5568253.11020137,4443586.23550475 5568253.07090266,4443586.25495777
5568253.01182713,4443586.34427952 5568252.96577378,4443586.95544821
5568251.91302996,4443587.6583538 5568250.93497955,4443587.70720134
5568250.76750358,4443587.69073353 5568250.63627081,4443590.69656152
5568247.57191714,4443593.46878206 5568244.56867822,4443596.00998423
5568241.79645767,4443596.70303936 5568239.94831064,4443597.16507612
5568237.63812685,4443596.70303936 5568235.32794307,4443596.24100261
5568232.09368576,4443594.62387396 5568229.09044684,4443593.0067453
5568225.85618954,4443591.15859827 5568222.62193223,4443588.15535935
5568216.15341763,4443585.61415718 5568210.83999491,4443583.76601015
5568207.37471923,4443582.37989988 5568204.14046193,4443579.83869771
5568197.9029657,4443577.99055068 5568195.59278191,4443571.2910177
5568193.74463488,4443562.5123193 5568193.51361651,4443557.89195173
5568190.74139596,4443551.88547388 5568185.89001001,4443546.57205117
5568180.80760567,4443540.04881255 5568172.31067108,4443535.57444993
5568167.46344492,4443534.33157143 5568163.48623371,4443532.59154153
5568159.75759819,4443531.34866302 5568156.52611408,4443525.50713405
5568143.60017765,4443523.6428163 5568142.10872344,4443521.77849854
5568142.97873839,4443516.55840883 5568141.98443559,4443513.07834902
5568138.13151223,4443510.09544061 5568136.76434588,4443504.62677519
5568134.27858887,4443500.11631134 5568127.13633107,4443499.98840842
5568126.8687197,4443499.84662832 5568126.73254226,4443499.70392061
5568126.08672993,4443499.63980413 5568120.50138902,4443497.01276792
5568119.20332017,4443496.73731515 5568118.77956482,4443491.30417632
5568112.11014692,4443491.13545808 5568111.57955803,4443491.09798799
5568111.49883611,4443491.04864005 5568111.4293152,4443485.28724005
5568104.75705484,4443485.23719653 5568104.68762456,4443485.18848028
5568104.61993756,4443479.8170823 5568097.61998682,4443479.76821172
5568097.55235958,4443479.72557149 5568097.49107683,4443474.57490432
5568090.305361,4443474.53202743 5568090.24391966,4443474.49589376
5568090.19939928,4443474.45211103 5568090.14089115,4443469.30323412
5568082.94699839,4443469.25941395 5568082.88870665,4443469.21788341
5568082.82548336,4443464.29204635 5568075.48854922,4443464.25057128
5568075.42537946,4443464.20635146 5568075.35847414,4443460.24442874
5568069.26276704,4443374.94353806 5567927.0946159,4443371.82140703
5567921.29355833,4443371.76417129 5567921.18731335,4443371.70848906
5567921.08201121,4443367.63376194 5567913.32658067,4443367.57809637
5567913.2212989,4443367.52309228 5567913.1174798,4443363.45497956
5567905.35477601,4443363.39998999 5567905.25097095,4443363.34590772
5567905.14876527,4443359.27750053 5567897.38239973,4443359.22343671
5567897.28021168,4443359.17059219 5567897.18140188,4443355.09979715
5567889.40953831,4443355.04699624 5567889.31073874,4443354.99350266
5567889.20540229,4443350.92128323 5567881.4308193,4443350.86776969
5567881.32542015,4443346.84076666 5567873.40495939,4443346.78867451
5567873.29639215,4443342.97597481 5567865.3917577,4443342.92393501
5567865.28330554,4443342.87395549 5567865.17428828,4443339.16210938
5567857.22049958,4443339.11209662 5567857.11139408,4443339.06283324
5567857.00092016,4443335.38449349 5567849.03376913,4443335.33520879
5567848.92322298,4443331.69855723 5567840.81619337,4443331.65148536
5567840.70467562,4443328.21982519 5567832.62751233,4443328.17284284
5567832.51622034,4443328.12805432 5567832.40692835,4443324.79367443
5567824.28204992,4443324.74900697 5567824.17305733,4443324.71990521
5567824.09081881,4443323.97666755 5567820.004672,4443323.94764447
5567819.92256349,4443323.92202075 5567819.86278917,4443321.53613537
5567815.73475582,4443321.51038587 5567815.67588411,4443321.47802339
5567815.59311517,4443318.52799438 5567807.30449601,4443318.4956628
5567807.22212022,4443318.47304946 5567807.14206315,4443315.52063509
5567798.84683976,4443315.49706566 5567798.76578055,4443315.47957223
5567798.70671575,4443315.46562854 5567798.65585258,4443312.55465897
5567790.30620415,4443312.53970323 5567790.25341388,4443312.53192049
5567790.23529688,4443312.5119758 5567790.19768828,4443312.47993173
5567790.07976379,4443309.63678346 5567781.7224407,4443306.6807846
5567773.40486064,4443306.63004934 5567773.31430212,4443306.60034295
5567773.25526306,4443306.56695547 5567773.15864194,4443303.58178824
5567764.96668401,4443303.54773015 5567764.86846153,4443303.54344519
5567764.82028997,4443303.52968914 5567764.7824091,4443300.55595211
5567756.40715871,4443300.54554231 5567756.36700843,4443300.53588712
5567756.33251881,4443300.52703742 5567756.30254376,4443297.61110292
5567747.88537855,4443297.61267572 5567747.85072751,4443297.58218289
5567747.80890102,4443297.55565439 5567747.73788703,4443294.03483077
5567739.69127237,4443292.77479099 5567739.79332096,4443291.47605328
5567740.090136,4443290.77575835 5567740.23795422,4443290.74009939
5567740.22369289,4443290.73391818 5567740.20477219,4443290.72948015
5567740.19326824,4443290.10270882 5567738.59377005,4443289.53521862
5567737.14580118,4443289.53146216 5567737.13572559,4443289.52409604
5567737.12195081,4443290.15724783 5567734.47056556,4443289.08695293
5567731.46026176,4443289.08098769 5567731.44116481,4443289.06981563
5567731.39471104,4443291.1698565 5567731.19098239,4443288.33906922
5567722.75562492,4443288.30698244 5567722.7232057,4443285.04007227
5567714.43586334,4443285.01361854 5567714.36508434,4443281.71282367
5567706.17981161,4443281.68604621 5567706.1085433,4443281.65670053
5567706.05203419,4443281.63739635 5567706.00267309,4443280.26164043
5567700.19170006,4443280.24197903 5567700.14255026,4443280.22105084
5567700.10703215,4443278.25095899 5567697.74325573,4443278.23010279
5567697.7081095,4443278.20746795 5567697.64984861,4443274.73190651
5567689.51706828,4443274.70841403 5567689.45743711,4443274.68747466
5567689.41384893,4443274.64921779 5567689.34790774,4443270.91494245
5567681.35534631,4443270.87612482 5567681.29381105,4443270.84657704
5567681.22042466,4443266.96173655 5567673.31900109,4443266.93070892
5567673.24416778,4443266.90459763 5567673.18600645,4443266.86349014
5567673.11056992,4443262.85467565 5567665.29563709,4443262.81353117
5567665.22010489,4443262.78428952 5567665.15924735,4443260.97404842
5567659.82729819,4443260.94455933 5567659.7666036,4443260.92467628
5567659.72390359,4443258.56137615 5567657.32027043,4443258.54016049
5567657.28164457,4443258.51744353 5567657.23811081,4443258.47082702
5567657.16591193,4443254.10746987 5567649.51282539,4443254.06064727
5567649.44388082,4443254.02405246 5567649.37354389,4443249.47842015
5567641.85067876,4443249.43965037 5567641.77802377,4443249.38915554
5567641.70960192,4443244.68599662 5567634.28583414,4443244.6363903
5567634.22078978,4443244.60210708 5567634.14171809,4443240.96049213
5567626.23380094,4443240.92484274 5567626.15252285,4443240.88629709
5567626.10801081,4443240.84652011 5567626.04171338,4443236.61631171
5567618.32455766,4443236.57547707 5567618.25534409,4443236.53845696
5567618.21107823,4443236.46822265 5567618.12490757,4443231.81604784
5567610.74877476,4443231.74603018 5567610.67099257,4443231.72564366
5567610.5878126,4443231.67446838 5567610.51460491,4443226.38840452
5567603.51798841,4443226.33572655 5567603.44327007,4443226.22367488
5567603.27126595,4443220.91168561 5567596.24036638,4443215.5997943
5567589.20956475,4443215.51855335 5567589.08407901,4443215.46594849
5567589.02778945,4443212.53775297 5567585.53733175,4443212.46634045
5567585.45859515,4443209.73898592 5567582.20745183,4443209.73300993
5567582.12939946,4443207.6142247 5567577.63683492,4443206.70107288
5567573.87789767,4443206.68485255 5567573.81916297,4443204.01577019
5567569.98714809,4443204.01430558 5567569.96115252,4443204.02480256
5567569.94223942,4443203.4754 5567569.0268,4443202.5457
5567567.8502,4443201.3949 5567566.3939,4443200.2215
5567564.9091,4443199.2771 5567563.8022,4443198.1112
5567562.4456,4443197.4643 5567561.7399,4443196.6092
5567560.8356,4443195.9262 5567560.2209,4443195.0383
5567559.6061,4443194.0821 5567558.7182,4443192.5864
5567557.635,4443191.2347 5567556.5,4443189.6952
5567555.2072,4443188.2321 5567553.9786,4443187.80060126
5567553.53349056,4443187.79772616 5567553.5566514,4443186.53306203
5567554.90559629,4443187.04019718 5567553.37063433,4443185.90563024
5567552.48171014,4443176.5242124 5567544.5307646,4443175.45279177
5567543.72742026,4443175.05239881 5567543.10774795,4443168.20128184
5567538.19779903,4443167.66419468 5567537.66919809,4443167.36007911
5567537.34829166,4443162.64567046 5567532.26167873,4443162.34526499
5567531.94381942,4443162.06416679 5567531.66536598,4443155.34164706
5567525.57706349,4443155.05337221 5567525.29773888,4443154.8605031
5567525.1159098,4443149.11080947 5567519.93221512,4443148.91911119
5567519.75381739,4443148.73061191 5567519.6002229,4443141.53125965
5567513.60077849,4443141.34250771 5567513.44684337,4443141.18458968
5567513.30601451,4443133.52193542 5567506.85318255,4443133.36002202
5567506.71088791,4443133.28571593 5567506.62249509,4443133.22561921
5567506.55292671,4443115.5628 5567495.5768,4443114.2579
5567494.5451,4443112.2863 5567492.9861,4443110.6217
5567491.8565,4443108.182 5567490.2011,4443105.8858
5567488.6429,4443104.0671 5567487.4173,4443101.6375
5567485.78,4443098.521 5567484.3493,4443096.9138
5567483.371,4443094.6444 5567482.2776,4443092.5513
5567480.6422,4443090.7886 5567479.8261,4443088.4367
5567478.7373,4443081.2121 5567473.3927,4443074.3375
5567468.537,4443066.9453358 5567464.82233181,4443066.84742918
5567464.85069124,4443066.6966369 5567464.83908248,4443066.46020764
5567464.66623784,4443060.67199887 5567458.69006379,4443060.41849869
5567458.53363784,4443056.42464488 5567456.80402366,4443056.10530749
5567456.65818932,4443051.84653091 5567455.20481076,4443051.25795622
5567455.10462267,4443043.21066587 5567451.69117444,4443042.50124777
5567451.38323097,4443036.06074451 5567449.15222078,4443034.79397048
5567449.00350144,4443030.03709183 5567447.39794486,4443028.92374524
5567449.36143539,4443028.09128819 5567449.63815427,4443027.82199146
5567449.77214723,4443027.54576231 5567449.68117625,4443027.1940502
5567449.52728528,4443026.43398189 5567449.09255752,4443021.19752826
5567444.66138485,4443020.28987031 5567444.36495513,4443018.85888144
5567444.00213043,4443013.23711232 5567442.47802824,4443011.80473249
5567442.11695452,4443010.29997683 5567441.73971417,4443004.84360142
5567440.26051597,4443003.33861043 5567439.8841757,4443001.37997851
5567439.57682455,4442996.53784485 5567438.43735193,4442994.52007447
5567438.1928189,4442989.62753706 5567438.02294329,4442989.40781531
5567437.97561872,4442989.22490461 5567438.07400923,4442985.08495238
5567439.13070771,4442982.45319404 5567439.15293929,4442981.99439183
5567438.52077658,4442981.03753035 5567436.42693279,4442981.07870378
5567436.30509492,4442980.86625263 5567436.26407108,4442977.4014804
5567434.72962293,4442974.06071246 5567434.02502369,4442964.05694084
5567432.36185011,4442960.60975548 5567431.69359409,4442959.39368908
5567431.35844102,4442952.67138715 5567430.12532549,4442951.42242945
5567429.8183423,4442950.68333129 5567429.57568785,4442944.21130139
5567428.97355733,4442943.46906396 5567428.79238514,4442942.92073763
5567428.66166214,4442935.39623754 5567427.5976072,4442934.84178446
5567427.47944138,4442934.44308342 5567427.38337742,4442926.86911936
5567426.25076389,4442926.46690229 5567426.16365346,4442926.1505631
5567426.09043484,4442917.87330823 5567425.04219404,4442917.55270292
5567424.97554923,4442917.37450473 5567424.89607677,4442909.10894105
5567423.82123364,4442908.91730096 5567423.76489084,4442899.42693208
5567421.87768966,4442899.29167631 5567421.82555145,4442899.28357158
5567421.76418291,4442896.50373513 5567421.21144315,4442896.50093207
5567421.19100774,4442896.50188445 5567421.18247791,4442896.78345276
5567418.83561202,4442896.78410335 5567418.82738058,4442896.78503868
5567418.81445908,4442897.09578998 5567416.22516195,4442897.09673948
5567416.21262746,4442896.6466 5567416.2063,4442895.5504
5567415.9203,4442894.4543 5567415.6344,4442893.3104
5567415.3961,4442891.7377 5567415.2054,4442890.6513
5567415.084,4442890.21748092 5567414.92133021,4442890.21508134
5567414.93682915,4442889.86922814 5567417.67859728,4442889.86726097
5567417.68932725,4442889.86622255 5567417.69831683,4442889.53992075
5567420.28502002,4442889.53886808 5567420.29595876,4442889.34159173
5567422.58422564,4442889.34377166 5567422.6032564,4442889.32175064
5567422.64374807,4442882.49712318 5567419.96265847,4442882.34279566
5567420.05012339,4442874.95389347 5567419.24888225,4442881.00200794
5567425.79890486,4442881.08522625 5567426.01632884,4442881.09095181
5567426.13275564,4442880.92224614 5567426.29298321,4442875.2903667
5567428.4117692,4442875.16684157 5567428.65181316,4442874.37884411
5567429.26174197,4442867.44384339 5567430.99744295,4442869.58373467
5567436.60542574,4442869.40536421 5567437.4754841,4442869.30756811
5567437.98276083,4442868.3425196 5567439.16638067,4442862.45908138
5567440.69399195,4442866.73585185 5567446.82529004,4442867.07987617
5567448.60206317,4442866.91976237 5567449.09711136,4442866.8196363
5567449.4195324,4442866.91361167 5567449.77520425,4442860.73110996
5567459.80937374,4442860.53733049 5567460.05527012,4442860.36291499
5567460.58941802,4442860.05237702 5567461.17170182,4442860.01967315
5567466.00353279,4442853.00112121 5567472.24452976,4442857.20376425
5567477.48961974,4442855.69327107 5567478.83748736,4442857.7143404
5567481.0409753,4442857.58255488 5567481.66670448,4442856.00582158
5567483.25270589,4442855.79735348 5567488.99745014,4442855.98245467
5567490.74661171,4442856.88804254 5567497.22547541,4442856.74218685
5567498.99343851,4442859.69615468 5567506.09399108,4442859.87952213
5567508.42351835,4442864.36010679 5567515.71561697,4442864.02641523
5567516.22137842,4442863.73385789 5567524.53497837,4442863.5787026
5567525.04638614,4442859.12667998 5567531.76353216,4442859.05995912
5567532.3408386,4442858.52986823 5567532.84523578,4442854.48413086
5567539.96654261,4442850.88004383 5567547.31955559,4442851.13447743
5567548.39874547,4442851.98938604 5567550.6206781,4442849.42898986
5567557.31879801,4442847.73322222 5567564.29346287,4442848.66394163
5567569.73839163,4442847.48029996 5567574.89540833,4442845.46454981
5567577.43868236,4442844.05627146 5567583.21978698,4442843.69281766
5567586.94520713,4442844.67285264 5567592.8735647,4442848.81421767
5567596.84826464,4442850.50795705 5567599.20139784,4442850.62376851
5567600.7810893,4442855.0707635 5567605.26080102,4442855.72070977
5567605.55637217,4442857.75456664 5567606.35362447,4442858.3697203
5567606.62463602,4442858.30764227 5567607.69229141,4442858.26063484
5567607.77787714,4442858.47230349 5567610.54020222,4442858.45678028
5567610.57288651,4442858.45325818 5567610.58684982,4442857.9293234
5567612.15875227,4442857.92331599 5567612.17236121,4442857.91536221
5567612.19641595,4442857.31898194 5567613.65012952,4442857.31307516
5567613.66640208,4442857.30820391 5567613.69605002,4442857.23796737
5567613.94546938,4442856.43764072 5567614.33808456,4442853.7761625
5567613.86163579,4442852.16390457 5567614.08293483,4442849.45236505
5567614.96254565,4442847.90963853 5567615.29900737,4442846.42708539
5567617.31027204,4442845.39024799 5567617.74623296,4442845.98433535
5567618.88155244,4442846.13597602 5567621.59357747,4442846.99359777
5567622.29712616,4442848.95099603 5567624.68523448,4442849.81937244
5567625.28713324,4442848.9989915 5567626.89401297,4442848.93239411
5567627.08102699,4442848.84455801 5567627.31770896,4442844.25975296
5567635.46647802,4442844.17408697 5567635.70318729,4442847.43858
5567643.7654266,4442847.43664991 5567643.80857711,4442847.43778892
5567643.86773802,4442847.46945577 5567644.01223885,4442850.39166265
5567651.97756596,4442850.47399003 5567652.12658347,4442850.57448933
5567652.25580624,4442850.67418621 5567652.37143199,4442850.79641588
5567652.57846318,4442840.94994871 5567659.9262902,4442859.73735459
5567678.84001381,4442860.07070926 5567679.42997023,4442860.95105203
5567680.09066065,4442862.02987319 5567682.23298078,4442862.10922926
5567697.89126977,4442877.77223247 5567697.99341125,4442879.91364185
5567699.07501827,4442880.2499195 5567699.86369184,4442880.32544476
5567700.12365313,4442880.3051729 5567719.40508768,4442880.61031478
5567719.49148182,4442880.86140096 5567719.85515748,4442883.11556236
5567720.16908304,4442899.17198089 5567735.94994745,4442900.28708797
5567738.87129965,4442900.73132311 5567739.22315861,4442903.81316898
5567739.97579978,4442911.70202998 5567753.88855813,4442918.99262942
5567754.05489929,4442926.27999107 5567753.75937054,4442928.72408309
5567754.50188321,4442935.15575421 5567754.56670321,4442937.13891057
5567755.01812383,4442937.68811019 5567755.93390093,4442945.49524379
5567756.59301986,4442946.06328731 5567756.98332203,4442946.07373161
5567757.49428778,4442954.82456705 5567758.04043659,4442954.89839104
5567758.27033916,4442960.12507204 5567759.42149064,4442963.0524784
5567759.99911782,4442963.08793646 5567760.03267103,4442963.10662848
5567760.05742433,4442963.1299389 5567760.09908021,4442963.15981067
5567760.14459583,4442968.40772612 5567766.50541835,4442968.44070064
5567766.54908367,4442972.38265505 5567774.35908268,4442972.42463862
5567774.37810691,4442972.51081001 5567774.42698733,4442972.6628659
5567774.58099589,4442972.7526548 5567778.74285627,4442972.84408481
5567778.93534958,4442971.70294482 5567780.7246295,4442976.26750478
5567781.95109642,4442976.5875098 5567782.12104298,4442976.65506786
5567782.22823021,4442976.60187981 5567782.91036611,4442975.4615862
5567783.69545338,4442962.4619688 5567787.24155067,4442961.33677802
5567798.82440701,4442960.69567776 5567799.94735452,4442960.69664177
5567819.25266374,4442960.9922263 5567819.97093643,4442961.12608123
5567821.12084244,4442959.98993297 5567838.72885417,4442959.16897729
5567839.12476415,4442958.70114979 5567839.58055995,4442958.80701651
5567839.91912125,4442959.12313866 5567840.54948442,4442959.99248198
5567841.09599123,4442965.41700057 5567859.90208069,4442979.97853669
5567874.55776467,4442987.74982073 5567879.99172387,4442999.99883076
5567892.30489364,4443012.3278877 5567892.2474554,4443020.17542773
5567898.45347396,4443021.18459227 5567900.03694723,4443040.20021053
5567919.07410811,4443040.90287841 5567919.98289711,4443040.70412272
5567939.1965324,4443039.92899786 5567940.89536225,4443021.00712289
5567960.03468618,4443020.08899795 5567962.60876389,4443018.26171521
5567961.88398072,4443000.12920132 5567961.77404815,4442996.45508809
5567963.60236973,4442983.69820518 5567963.58080915,4442983.73942392
5567976.299644,4442981.91128528 5567979.96561672,4442980.08270673
5567981.86744468,4442976.22233468 5567983.82916843,4442964.01621319
5567983.98671819,4442963.96594439 5567996.10272367,4442962.02385916
5567999.95158349,4442962.11057198 5568018.12333838,4442979.88850615
5568018.04927118,4442981.99563933 5568017.90601447,4443000.2255726
5568017.67864383,4443005.96000937 5568013.84561952,4443001.56102217
5568019.75201693,4443001.32110929 5568038.97396485,4443000.61412513
5568040.2270468,4443000.07167633 5568040.97553614,4442998.51110822
5568041.80702745,4442998.75511166 5568040.20243211,4442997.37152584
5568037.44288234,4442997.24316473 5568022.72502776,4442982.83150381
5568022.90477546,4442979.86378537 5568021.45524221,4442978.17292132
5568021.71290562,4442961.87106449 5568021.78082312,4442960.17988415
5568022.1385169,4442955.99004285 5568024.17225243,4442943.95058434
5568024.01878991,4442944.11286655 5568035.93477282,4442942.06059007
5568040.08289699,4442941.53615898 5568041.62084717,4442941.46682251
5568058.53302599,4442941.14987099 5568060.07356333,4442941.16133641
5568061.32656135,4442941.29771255 5568078.65857017,4442941.30924026
5568079.91179428,4442941.84212525 5568081.71584843,4442941.77084202
5568098.03561019,4442943.05388208 5568099.84651053,4442940.52674811
5568100.39386744,4442939.9666422 5568100.71196863,4442934.39873439
5568103.34859301,4442933.63579801 5568103.55297887,4442925.76718611
5568101.60508708,4442924.73195613 5568102.1993952,4442916.54831544
5568100.76017072,4442914.55361052 5568101.99537785,4442908.17396001
5568101.77033702,4442904.15264323 5568107.42484422,4442899.83560172
5568110.01273291,4442893.97665536 5568111.60286121,4442888.681906
5568117.63756915,4442881.53577987 5568117.44730649,4442880.5044273
5568117.73116563,4442879.13715738 5568117.89902786,4442862.49897778
5568116.90856783,4442861.12614162 5568117.1496635,4442859.46590675
5568117.40335945,4442842.7418586 5568116.87465261,4442841.12550718
5568117.21204555,4442836.93311698 5568120.41183258,4442824.62382888
5568123.81441934,4442824.72596586 5568135.7210977,4442822.6559694
5568140.37511183,4442821.27414573 5568150.80617344,4442819.84910845
5568155.2186326,4442801.85970478 5568184.29773179,4442825.91403709
5568221.76437743,4442825.54652997 5568222.45355426,4442820.77164192
5568239.44861877,4442820.50335956 5568240.1079113,4442820.49894937
5568240.60999615,4442820.4211288 5568259.28408432,4442820.41673434
5568259.78616491,4442820.35837536 5568260.23626491,4442820.71848233
5568279.41172247,4442820.67421054 5568279.86175314,4442820.45274011
5568299.60986003,4442820.42804693 5568300.01592659,4442820.44317692
5568300.40377335,4442820.37492596 5568319.71975461,4442820.39164971
5568320.1074891,4442820.37287001 5568320.49522898,4442820.39498048
5568339.79670723,4442820.37793151 5568340.18449401,4442820.4702443
5568340.60610997,4442820.4664292 5568359.49177359,4442820.62087018
5568359.88915002,4442821.09331951 5568359.96788913,4442824.43438948
5568361.30807851,4442822.34591488 5568362.65422053,4442823.80888754
5568376.90532949,4442823.18854795 5568379.09077565,4442827.18186549
5568380.15653874,4442827.13829902 5568382.21490834,4442831.07415173
5568393.10518754,4442840.37808668 5568397.28999479,4442840.09126753
5568399.86225696,4442840.15047119 5568401.44737988,4442833.89922419
5568405.30870028,4442829.77045705 5568406.01802589,4442831.44097933
5568408.66809308,4442830.69340998 5568414.37122808,4442831.74158989
5568416.15398654,4442834.13456048 5568420.13282573,4442839.91870956
5568422.55663115,4442840.6481565 5568423.14866572,4442842.88203529
5568422.67630444,4442843.65976611 5568422.9286484,4442844.97764484
5568424.06669285,4442855.50424816 5568440.46097389,4442856.64241499
5568440.83013391,4442855.33209577 5568442.11114137,4442854.29239901
5568451.91870557,4442861.5756 5568452.44848096,4442862.13992221
5568452.08684306,4442861.86746491 5568452.79305303,4442861.91632074
5568453.20529899,4442861.16067629 5568457.27709849,4442861.4552633
5568457.73611421,4442862.51212776 5568459.9495284,4442862.773622
5568462.34639999,4442864.56037569 5568462.39000003,4442866.31515028
5568463.52663212,4442866.50983411 5568464.37546628,4442866.5175318
5568464.44523048,4442866.56068 5568464.54814109,4442867.23683575
5568467.86029425,4442868.79153144 5568468.16934547,4442868.84771966
5568468.22768157,4442868.84876196 5568468.27329317,4442868.84414093
5568468.29223935,4442868.83964525 5568468.30909958,4442867.82245466
5568470.80628309,4442867.82230209 5568470.81922002,4442868.54935271
5568473.69515314,4442868.54984999 5568473.70839117,4442868.5469548
5568473.71291229,4442867.44938294 5568475.85943443,4442867.44758727
5568475.86353514,4442867.44454923 5568475.86856701,4442866.05530339
5568477.91585046,4442866.05159223 5568477.92201609,4442866.03917999
5568477.9370351,4442866.00397872 5568477.93661654,4442865.96187619
5568477.92637888,4442861.64539374 5568476.99380551,4442857.22536821
5568476.99380551,4442857.3122283 5568477.37948705,4442856.88656951
5568477.17605159,4442852.52445857 5568478.01263638,4442852.18790521
5568478.01999929,4442851.96244024 5568478.21147566,4442846.96797722
5568480.70866262,4442846.87015157 5568480.96156197,4442846.46117633
5568480.99983017,4442838.68881499 5568485.56054883,4442838.51640541
5568485.70032186,4442838.3880131 5568485.78614632,4442838.21381787
5568485.87658896,4442832.47887228 5568489.648023,4442832.3043084
5568489.74173984,4442832.09560428 5568489.85283427,4442829.76418107
5568491.08315404,4442827.45132977 5568488.82834339,4442823.86941532
5568488.79733669,4442826.345 5568493.2077,4442828.4152
5568496.6007,4442830.8544 5568500.5984,4442831.9577
5568503.7243,4442833.0052 5568506.0927,4442833.9803
5568508.3211,4442853.034 5568508.956,4442859.2207
5568509.0243,4442860.7545 5568513.738,4442863.2028
5568512.9767,4442866.1594 5568512.5459,4442868.9074
5568512.0197,4442870.9784 5568516.7914,4442873.4786
5568516.1973,4442875.8488 5568520.7578,4442878.1845
5568520.2182,4442880.3433 5568520.0088,4442882.1049
5568519.3237,4442885.1867 5568516.7858,4442900.062
5568519.94,4442919.886 5568539.861,4442919.949 5568560.081,4442940.066
5568579.963,4442959.941 5568600.018,4442969.49156949
5568604.54907138,4442972.46321773 5568605.14039099,4442972.83186989
5568602.54091766,4442974.48793835 5568599.66449445,4442972.54579281
5568595.75713418,4442971.94619846 5568592.88024512,4442971.51813394
5568591.84189479,4442968.54216013 5568585.60117921,4442968.10873541
5568584.57389992,4442967.68198179 5568583.67854745,4442964.63135749
5568577.2790128,4442964.20461855 5568576.38369176,4442963.73421985
5568575.47423792,4442960.71359893 5568569.18335736,4442960.24069982
5568568.277515,4442960.44931085 5568567.51755851,4442960.5547171
5568567.35477056,4442960.63579198 5568567.24102491,4442961.54607104
5568567.2464146,4442961.69614675 5568567.90255185,4442965.24165207
5568575.28658022,4442965.38634204 5568575.98023327,4442969.08473987
5568583.73865343,4442972.78418122 5568591.4965044,4442979.99741356
5568598.99935888,4442981.13282677 5568598.89395586,4442982.66550914
5568600.02163266,4442983.1080337 5568607.21285184,4442986.27811279
5568609.82124346,4442988.302462 5568613.55377648,4442995.4418472
5568615.29444399,4443000.0612423 5568617.33845198,4443002.2078094
5568617.85795341,4443007.66052005 5568620.03169229,4443011.68981814
5568628.24116168,4443020.048983 5568632.82306232,4443028.29762735
5568628.40162201,4443032.40707296 5568619.98210373,4443037.79724744
5568617.74750998,4443039.98121372 5568617.13144701,4443042.61892721
5568617.28846237,4443044.51089924 5568619.93255262,4443048.99207265
5568628.9924783,4443048.99670427 5568630.92550411,4443050.90174739
5568630.92974977,4443059.83156792 5568635.47462049,4443068.99833342
5568630.96317956,4443070.95538576 5568630.95700406,4443070.95721911
5568629.04211876,4443075.54703935 5568620.06260529,4443078.26500912
5568618.26787774,4443080.06562435 5568618.67331322,4443082.8772597
5568617.24741697,4443097.17528325 5568617.09095833,4443097.17169475
5568602.90346061,4443098.57698312 5568600.09782413,4443098.31157709
5568598.41309487,4443099.9806113 5568598.0326076,4443101.17543724
5568598.90810467,4443101.44700006 5568600.09932117,4443102.91035778
5568602.9931169,4443102.91389793 5568616.98943784,4443117.10138674
5568617.06661302,4443120.0270073 5568618.5254452,4443122.94240888
5568617.07135755,4443122.65825471 5568608.76432826,4443119.65449565
5568597.50023178,4443130.16765236 5568604.25868967,4443138.42798978
5568602.00587037,4443146.68832719 5568605.00962943,4443153.44678508
5568605.00962943,4443159.4543032 5568603.5077499,4443165.46182132
5568605.7605692,4443171.46933944 5568605.7605692,4443178.22779732
5568605.7605692,4443184.23531544 5568605.7605692,4443191.74471309
5568608.76432826,4443197.75223121 5568607.26244873,4443205.26162886
5568603.5077499,4443209.76726745 5568599.00211131,4443216.79034118
5568596.82341911,4443219.98972479 5568588.53132401,4443225.70917967
5568585.67916388,4443228.5552003 5568579.96413516,4443237.60065741
5568577.62673339,4443239.96115931 5568576.84038695,4443244.03458821
5568575.93628538,4443248.75606005 5568576.89444463,4443253.56207455
5568577.85564753,4443255.48448035 5568578.81685043,4443260.83607958
5568576.0947674,4443263.54167138 5568577.29725264,4443265.09650934
5568578.81685043,4443267.01891514 5568584.58406782,4443268.46071949
5568592.75429246,4443267.01891514 5568605.24993015,4443265.57711079
5568615.3425606,4443263.17410354 5568624.95458959,4443258.36808904
5568634.56661858,4443256.44568325 5568640.81443743,4443269.42192238
5568634.08601713,4443277.11154558 5568625.43519104,4443282.39816152
5568615.82316205,4443290.56838617 5568608.6141403,4443295.37440066
5568600.92451711,4443304.02522676 5568589.39008232,4443313.63725575
5568581.21985767,4443317.9626688 5568578.33624898,4443326.13289344
5568570.16602433,4443337.18672678 5568567.28241563,4443346.79875577
5568565.36000984,4443354.48837897 5568559.11219099,4443359.77499491
5568557.18978519,4443362.65860361 5568554.3061765,4443369.3870239
5568555.26737939,4443374.67363985 5568551.4225678,4443383.80506739
5568549.98076345,4443387.64987899 5568549.500162,4443395.33950218
5568549.98076345,4443401.10671958 5568549.98076345,4443407.35453842
5568549.01956055,4443413.60235727 5568551.90316925,4443424.65619061
5568551.90316925,4443429.4922681 5568549.99696056,4443431.84316565
5568546.07879797,4443434.97769572 5568543.33608416,4443437.72040953
5568542.55245165,4443439.28767456 5568541.76881913,4443440.46312334
5568540.98518661,4443444.77310219 5568536.28339151,4443447.90763225
5568538.2424728,4443449.86671355 5568537.85065654,4443453.78487614
5568535.89157525,4443459.66212002 5568536.28339151,4443463.5802826
5568535.89157525,4443467.10662893 5568536.67520777,4443470.63297526
5568537.85065654,4443474.9429541 5568537.45884028,4443478.46930043
5568537.45884028,4443482.38746302 5568538.2424728,4443487.61498051
5568539.40753156,4443491.00742071 5568540.98518661,4443494.14195078
5568544.11971668,4443499.23556214 5568544.11971668,4443503.54554099
5568543.33608416,4443507.07188731 5568542.55245165,4443514.90821249
5568542.55245165,4443522.74453766 5568544.9033492,4443525.87906773
5568549.99696056,4443528.62178154 5568559.40055077,4443534.49902542
5568562.14326458,4443544.29443189 5568561.35963206,4443553.30620584
5568563.31871336,4443559.18344972 5568561.75144832,4443562.31797979
5568558.22510199,4443569.37067244 5568556.65783696,4443574.07246755
5568557.04965322,4443577.20699761 5568560.18418329,4443581.06601812
5568562.32808357,4443584.65150653 5568562.53508084,4443589.74511789
5568561.75144832,4443594.446913 5568560.9678158,4443598.36507558
5568557.04965322,4443603.06687069 5568555.87420444,4443609.33593083
5568559.79236703,4443614.03772593 5568562.9268971,4443620.30678607
5568566.06142717,4443624.22494865 5568568.80414098,4443627.75129498
5568568.80414098,4443629.53737329 5568565.89134324,4443633.97065522
5568553.79395318,4443634.18243198 5568552.94684612,4443634.29537959
5568552.74918781,4443634.53539326 5568552.59388484,4443634.63422242
5568552.42446343,4443634.74717002 5568552.15621286,4443635.32602652
5568551.93031764,4443635.43897413 5568551.50676411,4443635.80200418
5568550.60371207,4443636.47811414 5568545.81664678,4443636.47811414
5568543.02966615,4443636.54778866 5568541.42715229,4443636.61746317
5568539.05821876,4443636.75681221 5568535.85319103,4443636.82648672
5568532.92686137,4443636.68713769 5568530.13988074,4443636.89616124
5568528.04964527,4443637.10518478 5568526.02908432,4443638.01095349
5568523.86917433,4443637.29175433 5568517.02841577,4443636.15136068
5568513.2271036,4443635.77122947 5568507.52513535,4443633.49044216
5568502.96356074,4443631.20965486 5568499.16224857,4443630.06926121
5568494.22054275,4443628.68346805 5568488.31331608,4443622.01307469
5568488.96727622,4443618.35089794 5568489.75202838,4443613.38080092
5568491.58311675,4443606.31803147 5568494.59133337,4443604.09456702
5568495.63766958,4443603.80224276 5568495.4671471,4443602.40308482
5568493.99025817,4443602.13268662 5568492.36786891,4443602.00189459
5568489.75202838,4443601.74031053 5568488.57490014,4443601.47872648
5568487.52856392,4443600.95555837 5568486.35143568,4443600.56318229
5568484.91272339,4443600.04001419 5568483.9971792,4443600.17080621
5568482.29688285,4443602.39427067 5568480.85817056,4443606.57961553
5568480.0734184,4443612.72684078 5568480.5965865,4443615.99664146
5568477.45757786,4443618.48168996 5568474.18777719,4443617.43535375
5568469.21768017,4443614.29634511 5568463.72441505,4443608.93387201
5568455.48451736,4443605.79486337 5568448.68333197,4443603.96377499
5568443.71323495,4443602.91743878 5568439.39709807,4443601.0863504
5568433.77304091,4443599.12447 5568425.14076715,4443597.94734176
5568420.30146215,4443597.29338162 5568417.29324554,4443595.7238773
5568414.02344487,4443594.41595704 5568410.23047609,4443593.10803677
5568407.22225948,4443590.75378029 5568403.16770665,4443589.57665204
5568400.94424219,4443588.3995238 5568398.19760963,4443586.17605935
5568395.18939301,4443583.29863476 5568392.1811764,4443581.44662711
5568390.36744874,4443581.14873921 5568389.90374897,4443581.24804104
5568389.59551589,4443581.29795875 5568389.48824085,4443581.32529779
5568389.3824725,4443583.57792908 5568383.45892232,4443583.60113264
5568383.35168011,4443583.66510022 5568383.26831536,4443590.01171001
5568379.96011743,4443589.97830184 5568379.3722195,4443593.63339177
5568372.11470289,4443594.08801389 5568371.30585234,4443594.27519023
5568371.96100714,4443595.33150122 5568371.38524414,4443596.91389792
5568371.60981884,4443598.89154953 5568371.60981884,4443600.00935261
5568371.69580369,4443601.12715569 5568371.8677734,4443602.84685274
5568372.46966736,4443603.96465582 5568372.89959162,4443605.42639832
5568373.15754618,4443606.37223169 5568374.10337956,4443607.57601963
5568375.13519779,4443608.26389845 5568376.33898572,4443608.76604999
5568377.96581913,4443609.15126213 5568380.11200105,4443609.20629243
5568381.98303144,4443609.31635304 5568382.91854664,4443609.37138335
5568386.66060742,4443611.06639663 5568388.75717248,4443611.76144336
5568388.35590208,4443611.76448469 5568388.38657188,4443611.82879567
5568388.95051136,4443621.78597385 5568382.6079339,4443622.56591789
5568382.06636262,4443622.5596001 5568382.04055086,4443625.50790598
5568380.01712827,4443625.49387493 5568379.98792757,4443625.48499711
5568379.9694515,4443625.64719764 5568379.88649869,4443626.04556594
5568379.68276467,4443626.52983263 5568379.55069193,4443627.45434177
5568379.37459496,4443627.47329003 5568379.36918117,4443627.76251148
5568379.28654647,4443628.99519032 5568379.022401,4443630.13982068
5568378.6261828,4443631.06432981 5568378.14191611,4443631.9448147
5568377.70167367,4443633.57371175 5568376.86521302,4443636.96357857
5568374.70802504,4443643.78733647 5568370.48169757,4443645.19233262
5568371.21969707,4443645.67896327 5568374.99108463,4443639.47442245
5568380.95231013,4443632.20896017 5568387.95932263,4443628.75006438
5568392.39082298,4443628.50134686 5568392.97116386,4443628.47695753
5568392.6484742),(4444255.0549816 5569636.29591284,4444255.06626691
5569636.27051908,4444255.07108533 5569636.2927718,4444255.07298959
5569636.30106326,4444255.07396402 5569636.31135465,4444255.0549816
5569636.29591284),(4444184.83165179 5569901.59549577,4444182.71452405
5569900.00764996,4444186.94877953 5569883.86455092,4444190.12447115
5569883.33526898,4444227.17420665 5569902.65405964,4444214.47144019
5569930.17672029,4444188.53662534 5569919.32644061,4444188.00734341
5569915.09218513,4444188.27198437 5569909.00544287,4444187.2134205
5569904.77118738,4444184.83165179 5569901.59549577),(4443916.66095589
5568787.77329425,4443916.83137135 5568787.87493499,4443923.16327457
5568795.30102851,4443923.54379378 5568795.49450526,4443923.60098851
5568795.86459701,4443926.98156927 5568801.67265846,4443923.29011303
5568795.96565934,4443923.21646397 5568795.85576355,4443923.18738646
5568795.80742174,4443923.15946859 5568795.76519005,4443923.12350859
5568795.72069123,4443923.04055843 5568795.61890168,4443916.81526654
5568787.98864567,4443916.79212848 5568787.96024977,4443916.78419758
5568787.94669107,4443916.77208651 5568787.93348435,4443916.66095589
5568787.77329425),(4443904.65018025 5568771.1012293,4443905.29499108
5568771.21746511,4443907.99007631 5568775.10930294,4443908.05137377
5568775.23803903,4443908.07738939 5568775.43490557,4443908.1563699
5568775.83310102,4443907.89160806 5568775.48027604,4443907.84755963
5568775.42052581,4443907.82380466 5568775.38472835,4443907.79778726
5568775.351978,4443904.97485789 5568771.63119758,4443904.93695162
5568771.57068326,4443904.873538 5568771.50295211,4443904.65018025
5568771.1012293),(4443885.00853365 5568746.41565815,4443885.50922689
5568746.44171846,4443885.68632021 5568746.66694249,4443891.91441755
5568753.16592347,4443892.13512589 5568753.42461176,4443892.81903982
5568754.44883348,4443897.16340735 5568760.06365111,4443897.20633183
5568760.81765088,4443896.82152312 5568760.34960277,4443896.72646326
5568760.22009976,4443896.6804572 5568760.14643548,4443896.63413376
5568760.09545514,4443896.55069094 5568759.99038954,4443891.70913788
5568753.73299134,4443891.62436453 5568753.62611546,4443891.58438866
5568753.57277209,4443891.53294765 5568753.52800399,4443891.43847853
5568753.42511132,4443885.30800291 5568747.027998,4443885.20996846
5568746.92165557,4443885.17175156 5568746.86878505,4443885.13347195
5568746.8223968,4443885.09521595 5568746.7717444,4443885.0817925
5568746.73000414,4443885.09183086 5568746.70300302,4443885.00853365
5568746.41565815),(4443504.81813609 5570884.85471283,4443504.40719898
5570881.07409147,4443503.74969961 5570877.78659463,4443504.4893864
5570873.34847391,4443506.62625934 5570869.81441481,4443509.91375618
5570867.34879219,4443512.70812849 5570866.93785508,4443514.13230156
5570867.56836753,4443516.40656243 5570869.07472802,4443519.20093474
5570872.19785002,4443523.22811836 5570882.71783989,4443526.02249067
5570891.51189392,4443528.32373845 5570897.7581379,4443528.8990504
5570901.21000958,4443527.74842651 5570903.75781963,4443525.20061646
5570906.30562967,4443523.63905546 5570906.30562967,4443520.76249573
5570904.99063094,4443515.00937627 5570899.97719827,4443513.69437754
5570898.25126243,4443510.65344297 5570895.7856398,4443500.29782794
5570889.04627129,4443500.1334531 5570888.38877193,4443504.73594867
5570885.67658704,4443504.81813609 5570884.85471283),(4443488.87846012
5570908.63141102,4443488.9721337 5570906.38324493,4443490.00254316
5570903.94773167,4443492.15703566 5570903.85405809,4443501.05602641
5570906.47691852,4443504.80296989 5570908.0693695,4443506.95746238
5570909.00610536,4443509.20562847 5570909.19345254,4443513.2335927
5570908.25671667,4443520.16543813 5570910.22386199,4443524.00605519
5570913.0340696,4443525.76856834 5570916.36561532,4443526.53524204
5570918.56081123,4443524.09972878 5570922.58877546,4443520.82115324
5570926.14837176,4443516.51216824 5570929.33327372,4443512.20318325
5570930.55103035,4443509.86134358 5570930.55103035,4443507.00039611
5570929.50333588,4443504.05358119 5570927.83449633,4443501.1497
5570925.39898307,4443498.80786033 5570922.77612264,4443488.87846012
5570908.63141102),(4443188.8277281 5567566.83297961,4443188.82836829
5567566.75958525,4443188.89331232 5567566.76621724,4443188.89944478
5567566.78750821,4443188.9019006 5567566.80904921,4443188.90011086
5567566.83509379,4443188.8825199 5567566.882733,4443188.8277281
5567566.83297961),(4442891.63729948 5568511.88541539,4442891.90532748
5568512.13440766,4442892.03139508 5568512.04066517,4442892.5073897
5568512.22817821,4442891.83788084 5568512.72601764,4442891.64096972
5568512.66219208,4442891.59797853 5568512.54712367,4442891.56882667
5568511.85844126,4442891.63729948 5568511.88541539),(4444166.75478477
5569909.08039931,4444166.74170445 5569909.08785205,4444166.76269758
5569909.08423582,4444166.88545988 5569909.14375694,4444166.96409049
5569909.17358234,4444167.41508125 5569909.37465487,4444167.71604679
5569909.51911833,4444168.02751688 5569909.67884658,4444169.21749236
5569910.21393623,4444169.33728855 5569910.28581394,4444180.60611671
5569915.54885984,4444180.31860586 5569918.37604989,4444179.79150263
5569925.4200658,4444167.42853594 5569919.76568568,4444167.54286591
5569918.50469221,4444167.54186135 5569918.5147644,4444167.53801589
5569918.52747964,4444167.52996986 5569918.52382874,4444166.94935118
5569919.33441941,4444166.37432947 5569919.23858245,4444161.48664497
5569916.9864141,4444161.34288954 5569916.45931087,4444161.39080802
5569915.69261526,4444152.78322844 5569911.59495203,4444152.68562539
5569911.65194274,4444152.5896098 5569912.06102617,4444151.50070894
5569912.13941907,4444143.18194214 5569908.31030231,4444142.29786636
5569906.59591251,4444141.85433452 5569904.5290284,4444143.07337853
5569900.21285087,4444143.97971763 5569898.87768182,4444145.43535291
5569899.26749299,4444146.07174586 5569899.50752268,4444153.93327082
5569903.17277625,4444154.39457706 5569903.44784962,4444162.50623375
5569907.22967745,4444162.70868012 5569907.35180693,4444163.01800947
5569907.43964973,4444164.3631744 5569907.85893305,4444166.34238382
5569908.88819174,4444166.35161803 5569908.88256763,4444166.55801696
5569909.00000151,4444166.35364431 5569908.88133352,4444166.47815284
5569908.95208304,4444166.50405813 5569908.92849411,4444166.63740622
5569908.95386857,4444166.60593544 5569909.00798792,4444166.62685766
5569908.98526859,4444166.62190826 5569909.00000151,4444166.65303517
5569908.95684256,4444166.62190826 5569909.01597434,4444166.75478477
5569909.08039931),(4444166.7634155 5569909.08411215,4444167.02584539
5569909.19700661,4444166.96409049 5569909.17358234,4444166.7634155
5569909.08411215),(4444167.07182615 5569909.21444759,4444167.11706584
5569909.23160748,4444167.36910252 5569909.35258508,4444167.07182615
5569909.21444759),(4444166.50405813 5569908.92849411,4444166.50211207
5569908.9281238,4444166.81884419 5569908.64185517,4444166.50405813
5569908.92849411),(4444166.65303517 5569908.95684256,4444166.62685766
5569908.98526859,4444166.63740622 5569908.95386857,4444166.65303517
5569908.95684256),(4444167.07182615 5569909.21444759,4444167.06914737
5569909.21563465,4444167.02584539 5569909.19700661,4444167.07182615
5569909.21444759))
SRID: 38168
