[postgis-users] How do you use PostGIS Raster?
Bryce L Nordgren
bnordgren at fs.fed.us
Tue Jun 7 12:11:32 PDT 2011
I'm not using PostGIS raster yet. We've been using PostGIS for years to
keep track of active fire and burn scar detections from the MODIS
instruments on board the Aqua and Terra satellites. Part of our process is
to resample the point detections onto a grid which aggregates burned area
over the course of a fire season. Aggregating onto a grid has been
performed using an external program, but we'd like to be able to use
PostGIS raster.
More recently, we're comparing a vector fire perimeter from the MODIS
instrument to a higher resolution Landsat image of the area. We select
the areas of the Landsat raster which are inside the perimeter vs. outside
the perimeter and calculate histograms on the separate image regions.
Currently, we're using ENVI and IDL to do this more or less manually. We'd
like to be able to perform this inside PostGIS, as PostGIS is the source
of the vector data anyway.
Bryce
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110607/bd4337f9/attachment.html>
