[postgis-users] Viewer plugins of PostGIS --HELP
David Fawcett
david.fawcett at gmail.com
Wed Jun 15 07:51:17 PDT 2011
I have used RT SQL for the exact case that you have outlined. I have
a vector 'grid' that I connect to a very large data set. It allows me
to store the geometry in one place and then connect the features with
the values for one analytical parameter for a particular date for
visualization.
I have also done a similar thing with MapServer. I have a simple Web
app that passes parameters for the date and the analyte to MapServer,
which writes the query, hits PostGIS, and then renders the image.
David.
On Wed, Jun 15, 2011 at 4:04 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il giorno mer, 15/06/2011 alle 16.29 +0800, Ben Madin ha scritto:
>> This may not help, but I guess I find QGIS quite simple for actually
>> visualising data. Maybe not so good for complex queries. There are now
>> a number of PostGIS plug-ins though.
> Confirmed. You can also run complex queries via the RT SQL layer plugin,
> and others.
> All the best.
> Paolo Cavallini: http://www.faunalia.it/pc
> postgis-users mailing list
