[postgis-users] QGIS - PostGIS - ArcGIS Interaction
Paragon Corporation
lr at pcorp.us
Wed Jun 15 11:40:50 PDT 2011
James,
You can use shp2pgsql command line packaged with PostGIS. It automatically
renames columns for you by adding digits to the end of duplicated 10char
names
So something like
pgsql2shp -f myshapefile -h myserver -u apguser -P apgpassword mygisdb
"SELECT * FROM incidents WHERE urgency = 'Immediate' AND
date_time_of_arrival - date_time_unit_assigned > '00:12:00' "
http://www.bostongis.com/pgsql2shp_shp2pgsql_quickguide_20.bqg
Leo
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of James
David Smith
Sent: Wednesday, June 15, 2011 1:58 PM
To: PostGIS Users Discussion
Subject: [postgis-users] QGIS - PostGIS - ArcGIS Interaction
Dear all,
I appreciate that this is more of a QGIS query, but I think that the route
of the problem might be in PostGIS, so... I have opened QGIS and ran the
query on my PostGIS table as below:
AND date_time_of_arrival - date_time_unit_assigned > '00:12:00'
This gives me 33 points in QGIS. Great. I would now however like to save
this as a ShapeFile for use in ArcGIS with which I am more familiar, but
when I try to SAVE AS from QGIS I am given the following error....
Export to vector file failed.
Error: trimming attribute name 'date_time_of_arrival' to ten significant
characters produces duplicate column name.
I am guessing that the problem here is that ESRI shapefiles can only deal
with column names that are ten characters long...? And that as I also have a
column called 'date_time_of_departure', when QGIS trims this column it ends
up with two columns called the same thing? Is there a way around this? I
realise I could rename the column in QGIS, but I actually have around 45
columns in the table and this problem will occur with about 15 pairs of them
I think. I guess there is no simple answer... but thought I'd ask.
Cheers
James
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
