[postgis-users] QGIS - PostGIS - ArcGIS Interaction
Bborie Park
bkpark at ucdavis.edu
Wed Jun 15 12:58:29 PDT 2011
Regina,
I'm doing this against my production PostGIS 1.5 server.
-bborie
On 06/15/2011 12:18 PM, Paragon Corporation wrote:
> Bborie,
> Does this work for any version of PostGIS or only ESRI sanctioned PostGIS
> 1.4?
> Thanks,
> Regina
> http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bborie
> Park
> Sent: Wednesday, June 15, 2011 3:10 PM
> To: Doug_Newcomb at fws.gov
> Cc: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] QGIS - PostGIS - ArcGIS Interaction
> Hey Doug,
> ArcMap 10 brought "read-only" access to PostGIS without the need for ArcSDE
> or any other extensions. To do so...
> 1. Click on File> Add Data> Add Query Layer...
> 2. In the "New Query Layer" window that appears, click on the
> "Connections..." button to add a new connection. Unless you have existing
> connnections, click on "New..." in the "Manage Connection(s)"
> window.
> 3. In the "Database Connection" window, select "postgresql" for the DBMS
> client, provide your database server IP (or domain name) in "Data Source"
> and fill out "Database" with the name of the database you're connecting to.
> If need be, add the appropriate authentication information. For PostgreSQL,
> you'll select "Database Authentication"
> for Authentication. Feel free to test your settings with "Test Connection".
> 4. Once satisfied, click "OK" to close the "Database Connection" window.
> 5. By now, you should have an entry in the "Manage Connection(s)" window so
> click "OK" if you're satisfied.
> 6. You should be back in "New Query Layer" and the connection you just
> created may have already been selected for "Connection". If not, select the
> appropriate connection. It takes a few seconds for the connection to be
> established and the program to retrieve the schema of the database.
> 7. I usually skip clicking on the "List of Tables" and "Columns" tools as
> ArcGIS still doesn't work with 64-bit datatypes (double, bigint,
> text???) and go directly to the "Name" and "Query" elements on the window.
> Just provide a value for "Name" as that value will be the layer name and use
> any valid SQL SELECT statement in the "Query" field.
> 8. You can click on "Validate" to make sure your query is valid. Once,
> satisfied, click on "Finish"
> That's it.
> -bborie
> On 06/15/2011 11:53 AM, Doug_Newcomb at fws.gov wrote:
>> bborie,
>> I would like details on this procedure. Does it require the
>> interoperability extension? Ziggis?
>> Doug
>> Doug Newcomb
>> USFWS
>> Raleigh, NC
>> 919-856-4520 ext. 14 doug_newcomb at fws.gov
>> The opinions I express are my own and are not representative of the
>> official policy of the U.S.Fish and Wildlife Service or Dept. of the
>> Interior. Life is too short for undocumented, proprietary data formats.
>> -----postgis-users-bounces at postgis.refractions.net wrote: -----
>> To: postgis-users at postgis.refractions.net
>> From: Bborie Park<bkpark at ucdavis.edu>
>> Sent by: postgis-users-bounces at postgis.refractions.net
>> Date: 06/15/2011 06:47PM
>> James,
>> If you have ArcGIS 10, you can directly write SELECT queries from
>> ArcMap to PostGIS. That's how I visualize my data when I'm running
> Windows.
>> -bborie
>> On 06/15/2011 10:58 AM, James David Smith wrote:
>>> Dear all,
>>> I appreciate that this is more of a QGIS query, but I think that the
>>> route of the problem might be in PostGIS, so... I have opened QGIS
>>> and ran the query on my PostGIS table as below:
>>> SELECT * FROM incidents
>>> WHERE urgency = 'Immediate'
>>> AND date_time_of_arrival - date_time_unit_assigned> '00:12:00'
>>> This gives me 33 points in QGIS. Great. I would now however like to
>>> save this as a ShapeFile for use in ArcGIS with which I am more
>>> familiar, but when I try to SAVE AS from QGIS I am given the
>>> following error....
>>> Export to vector file failed.
>>> Error: trimming attribute name 'date_time_of_arrival' to ten
>>> significant characters produces duplicate column name.
>>> I am guessing that the problem here is that ESRI shapefiles can only
>>> deal with column names that are ten characters long...? And that as I
>>> also have a column called 'date_time_of_departure', when QGIS trims
>>> this column it ends up with two columns called the same thing? Is
>>> there a way around this? I realise I could rename the column in QGIS,
>>> but I actually have around 45 columns in the table and this problem
>>> will occur with about 15 pairs of them I think. I guess there is no
>>> simple answer... but thought I'd ask.
>>> Cheers
>>> James
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Bborie Park
>> Programmer
>> Center for Vectorborne Diseases
>> UC Davis
>> 530-752-8380
> Bborie Park
> Programmer
> UC Davis
> 530-752-8380
Bborie Park
Programmer
UC Davis
530-752-8380
