[postgis-users] QGIS - PostGIS - ArcGIS Interaction
James David Smith
james.david.smith at gmail.com
Thu Jun 16 04:23:13 PDT 2011
Dear all,
Thank you so much for your help.
shp2pgsql - I didn't realise it automaticaly renamed columns. Awesome.
I'll use that.
ArcGIS 10 - I'm on 9 unfortunately. No access to 10 at the moment.
RT SQL - I glanced at that the other day and they seem to have
stopped supporting ArcGIS 9, and also you had to pay for anything more
than 100 rows of data I think? I may have read that incorrectly, but
the shp2pgsql solution seems good so I'll just go with that anyway.
Cheers all, this list is awesome!
James :-)
On 15 June 2011 21:44, David Fawcett <david.fawcett at gmail.com> wrote:
> James,
> There a couple of SQL plugins for QGIS. They allow you to visualize
> spatial features via 'ad hoc' queries (not whole tables).
> I am pretty sure that I used the RT_SQL plugin. Here is a link to
> some info: http://underdark.wordpress.com/2010/10/16/visualizing-postgis-queries-in-qgis-using-rt-sql-layer-plugin/
> No need to buy a $10,000 proprietary desktop GIS...
> David.
> On Wed, Jun 15, 2011 at 1:33 PM, James David Smith
> <james.david.smith at gmail.com> wrote:
>> Dear Cristian & David,
>> Thanks alot for your responses.
>> Cristian - I don't have money to buy additional software
>> unfortunately. With regard to 'view' I actually don't know what this
>> is. I'm a bit of a beginner. I wonder if I made a 'view' whether I
>> could then query that view with QGIS. Something for me to look into...
>> David - That looks like a good idea... but when adding data to QGIS
>> you can only select the whole table (I think) and then you manually
>> enter the 'WHERE' clause in a dialog box. I guess I could run the
>> query you suggest in PostgreSQL and save it into another table... and
>> then link QGIS to the new table. Though it all starts to get a bit
>> convoluted if I have to do that every time I want to look at some data
>> in QGIS...
>> Cheers
>> James
>> On 15 June 2011 19:16, David Fawcett <david.fawcett at gmail.com> wrote:
>>> This is what is really cool about using a database to store your data...
>>> Change your query to:
>>> SELECT mycol1,
>>> mycol2,
>>> date_time_of_arrival as dt_arrive,
>>> date_time_of_departure as dt_depart,
>>> the_geom
>>> FROM incidents
>>> WHERE urgency = 'Immediate'
>>> AND date_time_of_arrival - date_time_unit_assigned > '00:12:00'
>>> Note: you will need to specify the names of the columns that you are
>>> interested in.
>>> On Wed, Jun 15, 2011 at 12:58 PM, James David Smith
>>>> Dear all,
>>>> I appreciate that this is more of a QGIS query, but I think that the
>>>> route of the problem might be in PostGIS, so... I have opened QGIS and
>>>> ran the query on my PostGIS table as below:
>>>> SELECT * FROM incidents
>>>> This gives me 33 points in QGIS. Great. I would now however like to
>>>> save this as a ShapeFile for use in ArcGIS with which I am more
>>>> familiar, but when I try to SAVE AS from QGIS I am given the following
>>>> error....
>>>> Export to vector file failed.
>>>> Error: trimming attribute name 'date_time_of_arrival' to ten
>>>> significant characters produces duplicate column name.
>>>> I am guessing that the problem here is that ESRI shapefiles can only
>>>> deal with column names that are ten characters long...? And that as I
>>>> also have a column called 'date_time_of_departure', when QGIS trims
>>>> this column it ends up with two columns called the same thing? Is
>>>> there a way around this? I realise I could rename the column in QGIS,
>>>> but I actually have around 45 columns in the table and this problem
>>>> will occur with about 15 pairs of them I think. I guess there is no
>>>> simple answer... but thought I'd ask.
>>>> Cheers
>>>> James
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
