[postgis-users] Postgres service refuses to start on windows
Paragon Corporation
lr at pcorp.us
Sun Jun 19 08:59:16 PDT 2011
Roman,
Try checking your pg_log folder in your PostgreSQL data folder. That
usually gives reason for this error.
If the problem is even before it can write, then that's a more serious
issue. You might want to just reinstall PostgreSQL. Reinstalling will keep
your data as is so you should be okay.
Last time I had issues on windows was with a client. It turned out his
Anti-Virus decided certain dlls in hist PostgreSQL folder were suspicious
and just deleted them. Well that was my guess anyway
since half the files I recognized were missing and he had recently updated
his virus signature.
Hope that helps,
Regina
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ben
Madin
Sent: Sunday, June 19, 2011 9:37 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Postgres service refuses to start on windows
Roman,
I'm afraid I have no ideas, but as it sounds like a PostgreSQL problem (and
you may well get a reply from someone here) you might wish to try to
PostgreSQL mailing list as well, if you are awaiting a reply.
You might find a description of which version of XP, which version of
PostgreSQL, what happened before you got this problem etc improves your
chances of a useful response.
cheers
Ben
On 19/06/2011, at 5:18 AM, Smith Roman wrote:
> hello !
> I having an issue with my postgres database installed on a windows xp. For
some reason, I can no longer start the postgres service through pgadmin or
the services window. I get the following error:
> Error 1053: The service did not respond to the start or control request in
a timely fashion.
> Any ideas ?
> Roman.
> postgis-users mailing list
