[postgis-users] Interpolation problem
Saka Royban
sakaroyban at yahoo.com
Tue Jun 21 21:54:40 PDT 2011
yes, of course.there is a unique x,y for each triple measurements.
This measurements are, in fact, Received Signal Strength so it means more
distance less RSS value.
From: Chris Hermansen <chris.hermansen at tecogroup.ca>
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Wed, June 22, 2011 8:35:05 AM
Subject: Re: [postgis-users] Interpolation problem
What are the three measurements? Is it reasonable to assume that knowing three
measurement values tells you the location ie is there a unique x,y for each
triple of measurements?
On 2011-06-21 8:54 PM, "Saka Royban" <sakaroyban at yahoo.com> wrote:
> Hi all
> I'm not sure whether this can be done completely via PostGIS or it needs some
> programming. Anyway, at this step no problem with programming if Knowing the
>way
> and algorithm.
> I have point shapefile (arranged like a grid) and for each point there is 3
> similar measurements (obtained via 3 transmitters) and, of course, x and y
> coordinates. The problem is that when i have a new point with these 3 measures,
> How can i interpolate its coordinates and specify its location?
> Maybe helpful to say, this type of measurement is distance dependent but
> unfortunately i don't know the exact formula.
> Any help would be appreciated.
> Best Regards
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110621/aeb1d49c/attachment.html>
