[postgis-users] Nearest neighbor spatial join (more questions)
Sheara Cohen
Sheara at calthorpe.com
Thu Jun 23 11:21:55 PDT 2011
Hey all and Mark -
Mark, thanks again for your suggestions. I am having trouble making it
work, and I'm wondering if you or anyone else has any suggested fixes to
any of the following scripts. These were my various failed attempts:
Take One:
[WARNING ] CREATE TABLE
public.census_bg_near_ids_for_du_equal_zero_test_062111
as
SELECT DISTINCT ON(o.ogc_id)
o.ogc_id As orig_ogc_id,
o.sf3_totalhu_h030001 As sf3_totalhu_h030001,
o.st_pointfromtext As st_pointfromtext,
n.ogc_id As near_ogc_id,
n.sf3_totalhu_h030001 As near_sf3_totalhu_h030001,
FROM census_bg_du_equal_zero_test_062111 As o,
census_bg_du_more_than_zero_test_062111 As n
WHERE o.ogc_id <> n.ogc_id AND ST_DWithin(o.the_geom,
n.the_geom, 25000);
Take Two:
as
SELECT
n.the_geom, 25000)
LIMIT 1;
Maybe the "nn" in the field names of the following model script
something important?
Model One:
SELECT DISTINCT ON(g1.gid) g1.gid As gref_gid, g1.description As
gref_description, g2.gid As gnn_gid,
g2.description As gnn_description
FROM sometable As g1, sometable As g2
WHERE g1.gid <> g2.gid AND ST_DWithin(g1.the_geom, g2.the_geom, 300)
ORDER BY g1.gid, ST_Distance(g1.the_geom,g2.the_geom)
Model Two:
SELECT g1.gid As gref_gid, g1.description As gref_description, g2.gid As
gnn_gid,
WHERE g1.gid = 1 and g1.gid <> g2.gid AND ST_DWithin(g1.the_geom,
g2.the_geom, 300)
ORDER BY ST_Distance(g1.the_geom,g2.the_geom)
LIMIT 5
Thank you again!
~ Sheara
Sheara Cohen
Planner
C A L T H O R P E A S S O C I A T E S
2095 ROSE STREET, SUITE 201, BERKELEY, CALIFORNIA, 94709 USA
510 809-1165 (direct) | 510-548-6800 x35 (main) | 510 548-6848 (fax)
sheara at calthorpe.com <mailto:sheara at calthorpe.com> | www.calthorpe.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110623/d5411648/attachment.html>
