[postgis-users] Failed POST GIS on Re-boot.
Paul Ramsey
pramsey at opengeo.org
Thu Jun 23 16:34:54 PDT 2011
Figure out where your libproj.so file is installed (probably /usr/local/lib)
and add that directory to /etc/ld.so.conf and run ldconfig. Best guess.
P.
On Thu, Jun 23, 2011 at 12:25 PM, Chris Seker <Chris at dqsi.com> wrote:
> Hi all. I am running PostgreSQL 9.1 and PostGIS2.0 under CENTOS. After
> install, the server worked fine and we spent about 2 weeks building
> databases, etc. Then after some routine hardware maintenance and re-boot,
> we get the following error.****
> Top of Form****
> *SQL **select * from "oxbuildings2" limit 25 offset 0** failed : **ERROR:
> could not load library "/usr/pgsql-9.1/lib/postgis-1.5.so":
> /usr/pgsql-9.1/lib/postgis-1.5.so: undefined symbol: pj_set_searchpath ***
> Bottom of Form****
> Anyone have an idea? I am thinking that it’s a simple ENV setting.****
> *Chris Seker*
> *Vice President*
> *DQSI LLC*
> *Chris at DQSI.com*
> *19218 North 5th Street*
> *Covington, LA 70433*
> *Office - 985.871.7472 x213*
> *Cell - 301.613.6401*
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110623/2eb2eb53/attachment.html>
