[postgis-users] st_collect, st_union
Bob Pawley
rjpawley at shaw.ca
Wed Jun 29 11:15:23 PDT 2011
Hi
The table is attached.
Following is the query I used.
select st_collect(import_process.wkb_geometry)
from import_process;
Bob
-----Original Message-----
Sent: Wednesday, June 29, 2011 10:11 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] st_collect, st_union
On Wed, Jun 29, 2011 at 09:54:49AM -0700, Bob Pawley wrote:
> Hi
> I have a table with five rows each holding a linestring geometry.
> Each of theses geometries indicate true on an st_isvalid query.
> All rows are displayed as expected in QGis.
> However, when I run an st_union or st_collect query on all five rows the
> return is empty.
> If I select only four of the five rows (any four) it returns a value.
> Can anyone suggest what type of problem I should look for? Is there some
> restriction on these functions?
That's a really odd behavior. Can you provide a dump of your table ?
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110629/68c53cef/attachment.obj>
