[postgis-users] st_collect, st_union
Bob Pawley rjpawley at shaw.ca
Wed Jun 29 13:46:24 PDT 2011
What do you mean with your reference about an empty database??
I'm running   PostgreSQL v 8.4.1 and  PGAdmin v 1.10.0.
Bob
-----Original Message-----
Sent: Wednesday, June 29, 2011 12:33 PM
To: Bob Pawley
Cc: PostGIS Users Discussion
Subject: Re: [postgis-users] st_collect, st_union
On Wed, Jun 29, 2011 at 12:17:07PM -0700, Bob Pawley wrote:
> I just retried it using the script of imp_process.
> Same empty value returned.
Against an empty database ?
Really weird.
What version of postgis are you running ?
--strk;
> Bob
> -----Original Message----- From: Sandro Santilli
> Sent: Wednesday, June 29, 2011 12:09 PM
> To: PostGIS Users Discussion
> On Wed, Jun 29, 2011 at 11:15:23AM -0700, Bob Pawley wrote:
> >Hi
> >The table is attached.
> psql:E5R.backup:108: ERROR:  function imp_process() does not exist
> >Following is the query I used.
> >select st_collect(import_process.wkb_geometry)
> >from import_process;
> strk=# select st_summary(st_collect(import_process.wkb_geometry))
>             st_summary
> MultiLineString[B] with 5 elements
>   LineString[B] with 46 points
>   LineString[B] with 2 points
> (1 row)
> Did you retry after import ?
> Maybe the missing function makes a difference...
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> postgis-users mailing list
