[postgis-users] st_collect, st_union
Bob Pawley
rjpawley at shaw.ca
Wed Jun 29 13:49:43 PDT 2011
The table I sent you was imported using ogr2ogr. A second table, imported
the same way, although with fewer rows has had no similar problems.
Bob
-----Original Message-----
Sent: Wednesday, June 29, 2011 12:33 PM
To: Bob Pawley
Cc: PostGIS Users Discussion
Subject: Re: [postgis-users] st_collect, st_union
On Wed, Jun 29, 2011 at 12:17:07PM -0700, Bob Pawley wrote:
> I just retried it using the script of imp_process.
> Same empty value returned.
Against an empty database ?
Really weird.
What version of postgis are you running ?
--strk;
> Bob
> -----Original Message----- From: Sandro Santilli
> Sent: Wednesday, June 29, 2011 12:09 PM
> To: PostGIS Users Discussion
> On Wed, Jun 29, 2011 at 11:15:23AM -0700, Bob Pawley wrote:
> >Hi
> >The table is attached.
> psql:E5R.backup:108: ERROR: function imp_process() does not exist
> >Following is the query I used.
> >select st_collect(import_process.wkb_geometry)
> >from import_process;
> strk=# select st_summary(st_collect(import_process.wkb_geometry))
> st_summary
> MultiLineString[B] with 5 elements
> LineString[B] with 46 points
> LineString[B] with 2 points
> (1 row)
> Did you retry after import ?
> Maybe the missing function makes a difference...
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> postgis-users mailing list
