[postgis-users] OT: Export/copy postgres geometry to sql server with bcp
Paragon Corporation lr at pcorp.us
Thu Jun 30 22:48:26 PDT 2011
Charles,
We haven't tried ourself, but someone posted on our OGR2OGR tip page his
experience and some gotchas and how to work around them.
http://www.bostongis.com/PrinterFriendly.aspx?content_name=ogr_cheatsheet
If you are not against shelling out some money.  One of our clients uses
Safe FME for ETL. http://www.safe.com/   It does both PostGIS and SQL
Server.  I'm not much of a GUI liker for loading so I personally haven't
used it myself, but it does seem to have a SQL Server SSIS feel to it
If you are into that kind of stuff.
 Regina and Leo,
http://www.postgis.us
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Richard
Greenwood
Sent: Thursday, June 30, 2011 7:29 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] OT: Export/copy postgres geometry to sql server
with bcp
I'd suggest that you try ogr2ogr.
Rich
On Tue, Jun 28, 2011 at 6:48 AM, Charles Galpin <cgalpin at lhsw.com> wrote:
> Sorry for the somewhat off topic question, but I figured someone here has
probably dealt with this.  I am using postgis and am very happy with it, but
for various reasons I need to export some of our data to sql server
periodically and want to automate it, preferably to fit into our existing
framework which uses bcp to import from flat files.  However looking at the
binary output of a straight "copy" to CSV the binary formats do not look the
same. Is there any way to export to a format that bcp can understand?
> I can export the wkt, strip quotes, import into a temp table and then use
an insert select to fill the destination table converting the wkt back to a
geometry but this is less than ideal.
> tia,
> charles
> postgis-users mailing list
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
