[postgis-users] a couple of procedural questions for populating	tables programmatically
    Mr. Puneet Kishor
    punk.kish at gmail.com
    Tue Mar  8 06:07:54 PST 2011
I have a couple of procedural questions. I am populating my table with point and cell geometries programmatically. First question: When I INSERT values other than the geometry in rows and then UPDATE the geometry in a second process, everything works --
   $sth = $dbh->prepare(qq{INSERT INTO base.cells (x, y) VALUES (?, ?)});
   for (@a) {
       $sth->execute($a[0], $a[b]);
       UPDATE base.new_cells
       SET
           the_point = GeomFromText('POINT(' || x || ' ' || y || ')', 2163),
           the_cell  = GeomFromText(
               'POLYGON((' ||
               (x - $csmid) || ' ' || (y - $csmid) || ',' ||
               (x + $csmid) || ' ' || (y - $csmid) || ',' ||
               (x + $csmid) || ' ' || (y + $csmid) || ',' ||
               (x - $csmid) || ' ' || (y + $csmid) || ',' ||
               (x - $csmid) || ' ' || (y - $csmid) ||  '))',
               2163
   $sth->execute;
However, if I try to do the above in one attempt like so --
   $sth = $dbh->prepare(qq{INSERT INTO base.cells (x, y, the_point, the_cell) VALUES (?, ?, ?, ?)});
   for (@a) {
       $sth->execute(
           $a[0],
           $a[b],
           GeomFromText('POINT(' || $a[0] || ' ' || $a[y] || ')', 2163),
           GeomFromText(
               'POLYGON((' ||
               2163
I get an error saying the method GeomFromText doesn't exist. Would like to understand the reason behind this.
Second question: I am doing the following to set the SRID (besides specifying it in the UPDATE step above).
   INSERT INTO geometry_columns (f_table_catalog, f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, type)
   VALUES ('', 'base', 'cells', 'the_point', 2, 2163, 'POINT');
   VALUES ('', 'base', 'cells', 'the_cell', 2, 2163, 'POLYGON');
Is the above correct and sufficient?
Puneet.
