[postgis-users] Problem with WKTRaster: cannot get raster type in database
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Mar 11 06:54:20 PST 2011
Do you have the "rtpostgis" shared library in "usr/local/pgsql-9.0/lib"?
There should be "libgdal" as well.
Pierre
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
>bounces at postgis.refractions.net] On Behalf Of AJ7
>Sent: 11 mars 2011 07:02
>To: postgis-users at postgis.refractions.net
>Subject: [postgis-users] Problem with WKTRaster: cannot get raster type in database
>Hi,
>I installed postgis1.5 and the corresponding wkt package for the Mac OS
>Leopard 1.6...using the packages from kyngchaos. While I believe that
>wktraster has been installed properly (i.e. i could run the
>gdal2wktraster.py script on a tiff file), when I try to enable my database
>for the raster type support, this is not working. I get the error:
>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:32: ERROR: could not
>access file "$libdir/rtpostgis": No such file or directory
>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:37: ERROR: type raster
>does not exist
>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:45: ERROR: function
>raster_in(cstring) does not exist
>psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:58: ERROR: could not
>I am try the following command:
>su - postgres -c '/usr/local/pgsql-9.0/bin/psql -p 5433 -d [dbname] -f
>/usr/local/pgsql/share/contrib/rtpostgis.sql'
>what is wrong here please?
>pg_config --libdir -> usr/local/pgsql-9.0/lib
>pg_config --pkglibdir -> usr/local/pgsql-9.0/lib
>really need help on this.Hope its a simple thing.
>thanks
>View this message in context: http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>in-database-tp31124425p31124425.html
>Sent from the PostGIS - User mailing list archive at Nabble.com.
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
