[postgis-users] Problem with WKTRaster: cannot get raster type in database
William Kyngesburye
woklist at kyngchaos.com
Fri Mar 11 09:37:13 PST 2011
On Mar 11, 2011, at 11:05 AM, AJ7 wrote:
> Hi William,
> I also think it might be a linking or not finding path issue. When I remove
> the $libdir in rtpostgis.sql and put the full path where the rtpostgis.so
> is, it seems to want to do it, but i didnt want to substitute all...
Try running the psql command as I specified below - does that work?
> Is there a way that I can change $libdir to point to /usr/local/pgsql/lib
> instead of /usr/local/pgsql-9.0/lib?
That should not be necessary.
> Pierre,
> I don't have the libgdal.so
And you shouldn't.
> William Kyngesburye wrote:
>> GDAL shouldn't be the problem. This is OS X, and GDAL is a framework, so
>> you won't see a library file in Postgres lib/ or /usr/local/lib.
>> rtpostgis.so is properly linked to the GDAL framework.
>> It looks to me like it's /usr/local/pgsql but can't handle the symlink to
>> /usr/local/pgsql-9.0. Or it doesn't like the mismatch? What about this:
>> su - postgres -c '/usr/local/pgsql-9.0/bin/psql -p 5433 -d [dbname] -f
>> /usr/local/pgsql-9.0/share/contrib/rtpostgis.sql'
>> On Mar 11, 2011, at 10:35 AM, Pierre Racine wrote:
>>> Well I can't open those .dmg files. The only important thing is that the
>>> gdal library is beside the rtpostgis.so library and is named libgdal.so
>>> Do you have that?
>>>> -----Original Message-----
>>>> From: postgis-users-bounces at postgis.refractions.net
>>>> [mailto:postgis-users-
>>>> bounces at postgis.refractions.net] On Behalf Of AJ7
>>>> Sent: 11 mars 2011 11:23
>>>> To: postgis-users at postgis.refractions.net
>>>> Subject: Re: [postgis-users] Problem with WKTRaster: cannot get raster
>>>> type in database
>>>> Hi Pierre
>>>> I installed from here:http://www.kyngchaos.com/software/postgres
>>>> I already had GDAL 1.8 complete installed on my machine, so didn't
>>>> bother
>>>> installing again. (all the installations from the link above worked
>>>> fine).
>>>> Pierre Racine-2 wrote:
>>>>> Is there any way I can see the list of file included in your kyngchaos
>>>>> package?
>>>>> libgdal is the base GDAL library. rtpostgis.so is dependent on it and
>>>>> should be able to find it in the same folder or any lib search folder.
>>>>> Pierre
>>>>>> Sent: 11 mars 2011 11:17
>>>> type in database
>>>>>> Yes I do have the rtpostgis.so file in "usr/local/pgsql-9.0/lib", but
>>>>>> I
>>>>>> don't have any libgdal. where should I get this from? Is this why its
>>>>>> not
>>>>>> working?
>>>>>>> Do you have the "rtpostgis" shared library in
>>>>>>> "usr/local/pgsql-9.0/lib"?
>>>>>>> There should be "libgdal" as well.
>>>>>>> Pierre
>>>>>>>> Sent: 11 mars 2011 07:02
>>>>>>>> Subject: [postgis-users] Problem with WKTRaster: cannot get raster
>>>>>>>> type
>>>> in
>>>>>> database
>>>>>>>> Hi,
>>>>>>>> I installed postgis1.5 and the corresponding wkt package for the Mac
>>>>>>>> OS
>>>>>>>> Leopard 1.6...using the packages from kyngchaos. While I believe
>>>>>>>> that
>>>>>>>> wktraster has been installed properly (i.e. i could run the
>>>>>>>> gdal2wktraster.py script on a tiff file), when I try to enable my
>>>> database
>>>>>>>> for the raster type support, this is not working. I get the error:
>>>>>>>> psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:32: ERROR: could
>>>>>>>> not
>>>>>>>> access file "$libdir/rtpostgis": No such file or directory
>>>>>>>> psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:37: ERROR: type
>>>> raster
>>>>>>>> does not exist
>>>>>>>> psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:45: ERROR:
>>>>>>>> function
>>>>>>>> raster_in(cstring) does not exist
>>>>>>>> psql:/usr/local/pgsql/share/contrib/rtpostgis.sql:58: ERROR: could
>>>>>>>> not
>>>>>>>> I am try the following command:
>>>>>>>> -f
>>>>>>>> /usr/local/pgsql/share/contrib/rtpostgis.sql'
>>>>>>>> what is wrong here please?
>>>>>>>> pg_config --libdir -> usr/local/pgsql-9.0/lib
>>>>>>>> pg_config --pkglibdir -> usr/local/pgsql-9.0/lib
>>>>>>>> really need help on this.Hope its a simple thing.
>>>>>>>> thanks
>>>>>>>> View this message in context:
>>>>>> http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-
>>>>>>>> in-database-tp31124425p31124425.html
>>>>>>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>>>>>> _______________________________________________
>>>>>>>> postgis-users mailing list
>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>>>>> in-database-tp31124425p31126445.html
>>>> in-database-tp31124425p31126499.html
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> "We are at war with them. Neither in hatred nor revenge and with no
>> particular pleasure I shall kill every ___ I can until the war is over.
>> That is my duty."
>> "Don't you even hate 'em?"
>> "What good would it do if I did? If all the many millions of people of the
>> allied nations devoted an entire year exclusively to hating the ____ it
>> wouldn't kill one ___ nor shorten the war one day."
>> <Ha, ha> "And it might give 'em all stomach ulcers."
>> - Tarzan, on war
> View this message in context: http://old.nabble.com/Problem-with-WKTRaster%3A-cannot-get-raster-type-in-database-tp31124425p31126877.html
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
