[postgis-users] postgis raster : getting pixel value
Jorge Arévalo jorge.arevalo at deimos-space.com
Tue Mar 15 05:17:33 PDT 2011
2011/3/15 Ackbar Joolia <ackbar at ackadij.com>:
> Hi Jorge,
> My geom table is of type MultiPolygon - I don't see where else a
> MultiPolygonE type would be coming from.
I don't know... could you compile PostGIS with --enable-debug option
and check log messages? Or send us a sample of your table?
> 2011/3/15 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> On Tue, Mar 15, 2011 at 11:36 AM, AJ7 <ackbar at ackadij.com> wrote:
>> > Jorge Arévalo-2 wrote:
>> >> Hello,
>> >> This error is probably caused because last PostGIS version from trunk
>> >> uses a modern version of GEOS library. Could you update your GEOS
>> >> version?
>> > Hi Jorge,
>> > I am using postgis 1.5.2-2 (from Kyngchaos), and My GEOS version is
>> > 3.2.2-1
>> > View this message in context:
>> > http://old.nabble.com/postgis-raster-%3A-getting-pixel-value-tp31146394p31152534.html
>> > Sent from the PostGIS - User mailing list archive at Nabble.com.
>> > _______________________________________________
>> > postgis-users mailing list
>> > postgis-users at postgis.refractions.net
>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Mmmm... I'm using GEOS 3.3. Looking at the code (I've tried to
>> download GEOS 3.2.2 sources but download.osgeo.org looks down), I see
>> that exception is thrown when constructing a Geometry object and you
>> add a object different from Point, LineString, Polygon or
>> GeometryCollection. The type " N4geos4geom12MultiPolygonE" looks
>> weird. I guess only the last part is taken into account
>> (MultiPolygonE). Does it exist?
>> I don't know if it helps. I've not used KingChaos packages.
>> Jorge Arévalo
>> Internet & Mobilty Division, DEIMOS
>> http://es.linkedin.com/in/jorgearevalo80
>> http://mobility.grupodeimos.com/
>> http://gis4free.wordpress.com
>> http://geohash.org/ezjqgrgzz0g
Jorge Arévalo
