[postgis-users] postgis 2 installation failing
Nicklas Avén nicklas.aven at jordogskog.no
Fri Mar 18 07:18:42 PDT 2011
Yes you are right
My fault. The problem is if you use GEOS trunk, then you have to update
it since the configure script makes no difference between latest geos
trunk and an older trunk since they both is 3.3
/Nicklas
/Nicklas
On Fri, 2011-03-18 at 09:10 -0500, William Kyngesburye wrote:
> On Mar 18, 2011, at 8:40 AM, Nicklas Avén wrote:
> >> Does postgis2.0 have dependencies on particular library versions? like geos?
> > Yes. You must use latest GEOS trunk with PostGIS trunk.
> > I think the latest changes in GEOS needed for PostGIS trunk is less than
> > a month old.
> Don't know about that - I just compiled with released GEOS 3.2.2 with no errors in lwgeom.  It looks like the error is in shp2pgsql, which doesn't need GEOS.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
> postgis-users mailing list
