[postgis-users] Problems with ST_Within in an island of a multipolygon
Larry Reeder
lnreeder at gmail.com
Tue Mar 22 06:17:26 PDT 2011
Anybody have any ideas on this one? Do you think I should post it
to the developer list?
Thanks........ Larry
On Fri, Mar 18, 2011 at 8:43 AM, Larry Reeder <lnreeder at gmail.com> wrote:
> I have a layer called "foo" of about 5000 polygons. One of the
> polygons is a multipolygon with island shells. ST_Within isn't
> working as expected for points within that island shell.
> Here's my table:
> foo_spatial=# \d foo
> Table "public.foo"
> Column | Type | Modifiers
> gid | integer | not null default nextval('foo_gid_seq'::regclass)
> the_geom | geometry |
> Indexes:
> "foo_pkey" PRIMARY KEY, btree (gid)
> "foo_the_geom_key" gist (the_geom)
> Check constraints:
> "enforce_dims_the_geom" CHECK (st_ndims(the_geom) = 2)
> "enforce_geotype_the_geom" CHECK (geometrytype(the_geom) =
> 'MULTIPOLYGON'::text OR the_geom IS NULL)
> "enforce_srid_the_geom" CHECK (st_srid(the_geom) = (-1))
> ST_Within returns true when asked if a point inside the island belongs
> to the polygon that contains the island:
> foo_spatial=# select ST_Within(ST_GeomFromText('POINT (-115.04252
> 36.05137)', -1), the_geom) from foo where gid = 4933;
> st_within
> t
> (1 row)
> However, when I ask if any polygons contain this point, I don't get any back:
> foo_spatial=# SELECT gid from foo where
> ST_Within(ST_GeomFromText('POINT (-115.04252 36.05137)', -1),
> the_geom);
> gid
> (0 rows)
> Does this make sense? I know PostGIS can handle the general problem
> of ST_Within for island sub-polygons because when I extract this
> multipolygon into a separate table by itself, the queries work as
> expected. There seems to be something happening with other polygons
> in the layer that is breaking this. Initially I did have some bad
> polygons in the layer, but I used the cool script here:
> http://linfiniti.com/2010/07/cleaning-geometries-inside-postgis/.
> That fixed my bad polygons, and now all polygons are valid:
> foo_spatial=# select count(*) from foo where ST_IsValid(the_geom) = 'f';
> count
> 0
> (1 row)
> But still ST_Within isn't working as expected. Here's my version info:
> foo_spatial=# select version();
> version
> PostgreSQL 8.4.7 on x86_64-pc-linux-gnu, compiled by GCC gcc-4.4.real
> (Ubuntu/Linaro 4.4.4-14ubuntu5) 4.4.5, 64-bit
> (1 row)
> foo_spatial=# SELECT postgis_full_version();
> POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23
> September 2009" LIBXML="2.7.6" USE_STATS
> (1 row)
> dash_spatial=# select count(*) from foo where ST_IsValid(the_geom) = 'f';
> count
> 0
> (1 row)
> Anyone have any ideas?
> Thanks............ Larry
