[postgis-users] Geocoder questions (PG 9.0/ Posgis 2.0 SVN)
Paragon Corporation
lr at pcorp.us
Tue Mar 22 11:37:56 PDT 2011
> Hi all,
> I am trying to install the geocoder on a windows machine (blech), using
the included batch file (yay). I have a few questions.... One piece of
background:
> I am running postgis within its own schema and setting search_path
appropriately; this usually works just fine, but it might be part of the
problem here.
> Sorry for the generality of this post, but I can give more specifics/
cut-and-pastes later.
> 1. I am getting an error to the effect that geometry type is not found in
a database, but I am able to find it with \dT and I have successfully
installed postgis in its own schema with search_path. Any ideas?
In the create_geocode.sql, and tiger_loader.sql files, there is a set
search_path at the top. Add your postgis schema to the end of those
statements and that should fix your first issue
> 2. Is there a reason the install *.sql functions aren't wrapped in BEGIN/
END?
Not that I can think of
> 3. There are a couple of (other) typos and outdated things -- is there a
place/ person to send a patch?
Submit a ticket with your patch and make sure to choose component "tiger
geocoder" and it will be assigned to me
http://trac.osgeo.org/postgis/newticket
4. Is this code now sort of officially in the PostGIS trunk?
Yes kind of sort of especially now that we have it documented :)
http://www.postgis.org/documentation/manual-svn/Extras.html#Tiger_Geocoder
Thanks,
Regina
http://www.postgis.us
