[postgis-users] How to create a point geometry from two text fields?
pcreso at pcreso.com
Fri Mar 25 09:44:30 PDT 2011
Concatenation of strings & geomfromtext or cast to numeric & makepoint, I'm not sure which would be faster, but both will work.
So (as below)
update mytable set the_geom=ST_GeometryFromText('POINT(' || long || ' ' || lat || ')',4326)
or
update mytable set the_geom=setsrid(makepoint(long::numeric(7,4), lat::numeric(6,4)),4326)
HTH,
Brent Wood
--- On Sat, 3/26/11, Charles Galpin <cgalpin at lhsw.com> wrote:
Subject: Re: [postgis-users] How to create a point geometry from two text fields?
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Date: Saturday, March 26, 2011, 4:34 AM
But his lat/lon are character varying so I think it would be more like
On Mar 25, 2011, at 11:26 AM, Stephen Woodbridge wrote:
update mytable set the_geom=st_setsrid(st_makepoint(lon,lat),4326);
On 3/25/2011 10:44 AM, Gis Mage wrote:
Hello!
I have a table with two text fields "lat" and "long" of character
varying type.
I've created a field the_geom with type geometry.
How do I calculate the_geom field with an sql query?
The table is huge - about 1.5 million records, so I think the fastest
way to do this is to use pointfromtext function, but I can't figure out
how to put in the values of "lat" and "long" fields inside function
arguments.
Can anyone help me out?
Thanks.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
-----Inline Attachment Follows-----
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20110325/5d79f0fb/attachment.html>
