[postgis-users] Sorting/ordering linestrings
Stephen Woodbridge woodbri at swoodbridge.com
Wed Mar 30 16:47:43 PDT 2011
Charles Galpin<cgalpin<at>  lhsw.com>  writes:
> Does anyone have any bright ideas on how to sort linestrings (with postgis
> or  anything else for that matter).
ok, need some more criteria here. Sorting linestrings is a proposed
solution to an undisclosed problem. What is your problem?
If you have not additional criteria, then:
select *
  from my_table
  order by st_x(st_startpoint(the_geom)), st_y(st_startpoint(the_geom));
or maybe just:
select *
  from my_table
  order by the_geom::text;
-Steve
